T3 Technique Ball Joints - Not created equal
Page: 1, 2, 3, 4, 5, 6  Next
Christopher Schimke
PostPosted: Thu Sep 09, 2021 5:02 pm    Post subject: T3 Technique Ball Joints - Not created equal Reply with quote
This thread is sort of a continuation of this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=276274
But since these new T3 joints are actually coming to fruition, I figured it would be best to start a new thread. And just to keep things congruent, here's the info that was posted deep in that other thread about the new joints (originally posted April 28, 2021):
T3 Technique has taken on the HUGE (and expensive) challenge of having bespoke upper and lower ball joints made. The sample/prototypes of the new UBJs are excellent and are headed to production as we speak. The new lower ball joints needed a little refinement to get them up to my standards, but I think we are really close to pulling the trigger on those too. It will be a few months before we see tangible stock, but they are coming. Once I have some stock, I'd be happy to cut a sample apart to show you all the differences.
And, as some of you may have already read about, there will be a new tall version of the UBJs to help correct the geometry of a lifted van and help proved more UCA to spring clearance. In my lifted 2wd, these tall ball joints absolutely transformed the drivability, ride quality, stability, etc. It's like a completely different van. Below is a photo to show the difference between a stock length UBJ and the tall UBJ.
Today I received news that the new upper ball joints will be here right around the end of September, possibly early October. Pretty excited about that.
Last edited by Christopher Schimke on Thu Sep 09, 2021 5:03 pm; edited 1 time in total
Christopher Schimke
PostPosted: Thu Sep 09, 2021 5:03 pm    Post subject: Re: T3 Ball Joints - Not created equal Reply with quote
I also received my sample/prototype lower ball joints and I'm REALLY stoked on these. I worked really hard with the engineers to get exactly what I wanted out of the new joints. I cut one of our new joints apart, along side a brand new low quality Vanagon ball joint currently on the market, to show what makes these new joints so special and what makes all other Vanagon lower ball joints on the market today so inferior and prone to failing in short order. The low quality joint that I cut apart is indicative of all Vanagon lower ball joints in the market today. Yes, I have cut apart all of the currently available joints on the market to prove it. There are some variations of the plastic design, but none of them have the proper support to prevent the joints from failing prematurely.
First, a shot of the new joints untouched (sorry for the crummy, raw photos). You can see they come with the correct wire circlips that actually fit properly and if you have a keen eye (and experience with low quality Vanagon lower ball joints), you can see the solid metal insert.
Now for the guts of the matter. First, look at how much grease is in the new joint compared to the low quality ball joint. I did not add or remove any grease for either joint. This is exactly how they looked when the boot was removed.
New T3 joint:
Low quality joint:
And below is the crux of it all...the reason I went down this ball joint road to begin with. The new T3 joint is on the left, the low quality, joint is on the right.
1) On the new T3 joint, see above the ball how there is a thin plastic liner backed up with a solid metal insert that is crimped to the joint body? That's the key! Now look at the low quality joint. See how there is a big gap between the plastic liner and the stamped upper cap/insert? The reason these low quality joints fail is because the load path is directed toward that plastic part and the cap/insert. The constant pounding the tire hitting bumps drives the ball toward that area. With no support in the low quality joint, the ball becomes loose prematurely leading to failure.
Because the new T3 joint has a plastic liner with full support, this will not happen.
2) The other key feature of the new T3 joint, and a problematic issue with the low quality joint, is articulation. Look at the open area under the boot where most of the grease goes. Notice that angle of the walls and opening size of the new T3 joint is greater than that of the low quality joint. Many of the low quality joints actually restrict suspension articulation by restricting joint movement. The new T3 lower ball joints allow full articulation.
Anyway, that's the latest on the new T3 ball joints. I'm pretty excited about this and wanted to share. The lower ball joints are still in the testing phase, but I'm hoping to have them to market sometime in the Spring of 2022.
DanHoug
DanHoug is offline
PostPosted: Thu Sep 09, 2021 5:17 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
holy cow, what an undertaking!! and thank you for filling a real need. kinda makes me want to saw my stamped bottom TRW joints for a lookee. have one cast bottom.
anyway, thank you for serving our community so well. amazing. Belly Up, folks. we've whined for years about cheap parts that don't last. these will come at a price that is in line with their quality. do it right, once.
-dan
www.thefixitworkshop.com
bobhill8
bobhill8 is offline
PostPosted: Thu Sep 09, 2021 5:27 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Thank you Chris - looking forward to smoothing out my ride with both of these.
1986 Westy
1971 Squareback
chrismsnt
chrismsnt is offline
PostPosted: Thu Sep 09, 2021 6:46 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
If you need to test it on a higher van, just let me know! I'm a high flyer! Smile Since I'm already in line for your 25mm sway bar kit.. I can just hit all the work at once!
Chris
1989 T3 Vanagon 16" Syncro
1967 Squareback
https://vwvandiesel.com
Instagram @VW_VanDiesel
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Thu Sep 09, 2021 7:11 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Christopher, you're an amazing asset to the community. Thanks!
Casey--
'01 Weekender --> full camper
y u rune klassik?
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Thu Sep 09, 2021 7:22 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Yes please
candyman
Samba Trout Slayer
candyman is offline
PostPosted: Thu Sep 09, 2021 7:24 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
What ride height is considered lifted? Im right at 19.25” on my syncro
9.5isCanadian
9.5isCanadian is offline
PostPosted: Thu Sep 09, 2021 9:01 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
I’ll echo everyone’s appreciation and thanks.
Now that the pleasantries are out of the way.
How do I buy a set for my high top?
Take
My
Money
Very Happy
Owen
9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi
erste
erste is offline
PostPosted: Thu Sep 09, 2021 9:23 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Too good to be true!
hans j
hans j is offline
PostPosted: Thu Sep 09, 2021 9:25 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Glad I've been waiting years to replace my bad lower joints!
On those uppers, is the joint in a different location than the stock version? I'm wondering if the SAI or roll center is the same.
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
?Waldo?
?Waldo? is offline
PostPosted: Thu Sep 09, 2021 9:30 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Thanks for your efforts Chris!
VicVan
VicVan is offline
PostPosted: Thu Sep 09, 2021 10:02 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Impressive work! Can't wait for my current ball joints to fail.
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Sep 09, 2021 11:55 pm    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
i'm in for a set as well
question, are you going to make the lowers greaseable? i may have missed it but wanted to ask
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
turbotype1
turbotype1 is offline
PostPosted: Fri Sep 10, 2021 6:17 am    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
This^^^^^.
117harv wrote:
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel
DigiMatrix
DigiMatrix is offline
PostPosted: Fri Sep 10, 2021 6:44 am    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Chris, thank you for being a top supplier for us! Let us know if/when we can pre purchase these please. I want on the list.
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Sep 10, 2021 7:02 am    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
I'm down!!! I'll definitely buy a few sets when I'm back. This is great timing with the junk we're plagued with nowadays.
Sh!t, I would have loved testing a set of these on my Syncro, I'm currently in Central America, and everything is taking its toll even on brand new everything. All I do is off-road pretty much.
Chris, hit me up if you want me to put the lowers to the test in Baja, I can get them in La Paz and swap them there on my way back up from Central America.
I'm exactly at 6107 Lbs ,2770Kgs) fully loaded right now, stock height, it was 510mm but it's back down to 480mm now from spring sag, weight and all. Still plenty droop and suspension motion.
98mm 16" Syncro front outer cv's , 108x32 mm Audi front inner cv's and 108x40mm 930 cv's everywhere else.
Aloha!
dobryan
dobryan is offline
PostPosted: Fri Sep 10, 2021 7:10 am    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Oh my!
I'll order several sets.
Take my money.....
Dave O
The Western Syncro build
Jake de Villiers
Jake de Villiers is offline
PostPosted: Fri Sep 10, 2021 8:07 am    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
Beautifully done, Chris, as always!!
I knew there was a reason that I've been putting off replacing the lower ball joints for seventeen years... Cool
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
greebly
greebly is offline
PostPosted: Fri Sep 10, 2021 9:22 am    Post subject: Re: T3 Technique Ball Joints - Not created equal Reply with quote
From https://wagenswest.com/how_to/how_to_images/bus_vanagon_balljoints/IMG_6155.JPG
I understand that the Lemfoerder balljoints were becoming hard to obtain. Given your willingness to support the Vanagon community and exemplary customer service I would buy them from you if I had not obtained a set of moog a year or so ago for my suspension overhaul. Do you have any differences with the Lemfoerder/Moog joints?
Page 1 of 6
