67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Thu Sep 09, 2021 6:31 pm Post subject: Re: New Heads and 1.25 Rockers? |
mikelars wrote: |
Well, when I get Tim’s Ported SuperStock heads I am moving to 32 vent and 1.45 main jet as advised. But he also said that 28/1.15 is too lean with my current setup. It is gonna take 3-4 weeks before I have everything for the full 1968cc with SS heads so I thought maybe I would drop in the 1.3 main jets just to experiment…
I got Tim’s to put dual springs on the SS heads just in case I want to try 1.25 rockers, though that is not the main intent… |
Unless the heads are on the shelf. You might have to wait a little longer.
The Tim's build heads in batches. So when they have enough orders. They build um.
The last thing they do to them is flycut to your needs.
Keep us up to date on your experience with the heads.
I was extremely happy with my Stage II heads that I bought from Tim's a few years ago. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
sled Samba Member
Posted: Fri Sep 10, 2021 5:52 pm Post subject: Re: New Heads and 1.25 Rockers? |
mikelars wrote: |
Is this pretty easy to do with the engine in the bus? I am hoping this is like a 25 minute job, just to see if I get something noticeable out of it… |
it should take much less time than that.
1st, open decklid
2nd, remove air cleaner tops
3rd, remove aircleaner elements
4th, unscrew the main jet stacks
5th, swap main jets
6th, reinstall main jet stacks
7th, reinstall air cleaner elements
8th, reinstall air cleaner tops
9th, close decklid
10th, fire up engine and go give 'er hell!!
(most of those steps are a joke, I know you know how to access the engine) _________________ drive your split. |
Danwvw Samba Member
Posted: Sat Sep 11, 2021 10:56 am Post subject: Re: New Heads and 1.25 Rockers? |
mikelars wrote: |
Ok, well they said build time was 2-3 weeks, but then I changed the order to ported SuperStock 94s with dual springs - so who knows how long it will take.
I am going to try my new 1.3 main jets in the Weber 40 IDF carbs - just replacing the 1.15 and leaving the 28 vents and all else the same.
I tried about that jetting on my 1799cc or 1.8 whatever they're called. But the 94's will probably change everything, Are you increasing the Bore?
Build Sheet. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sat Sep 11, 2021 1:32 pm Post subject: Re: New Heads and 1.25 Rockers? |
I am changing out the 90.5s for thick wall 92s, so it will go from a 1904 to a 1968. But with that I will have ported SuperStock heads 37.5/32, and a 32 Venturi and 1.45 main jet. I have the option of trying 1.25 rocker arms (I ordered the arms) because I got dual springs on the heads. But I was advised not to use 1.25s with a 218 cam.
But it will be 4-5 weeks before I get both the heads and 92 pistons, so in the mean time, I have a 1904 with stock DP heads (AA500) and a 28 Venturi with 1.15 main jet. So I got a set of 1.3 main jets coming on Monday I will just pop in for the 4-5 week wait…
Looking forward to isolating a pesky oil leak (about a nickel drip per parking), painting and sound insulating behind the fuel tank. I think I might try more clear coat inside the engine compartment so some of the engine grime wipes off more easily… _________________ Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz |
Danwvw Samba Member
Posted: Sat Sep 11, 2021 2:22 pm Post subject: Re: New Heads and 1.25 Rockers? |
Probably the setup you have could handle 30 or 32 mm venturi's just fine, the thing to watch for is a crossover stumble or loss of low end torque. Kind of got to drive it and see how well it pulls uphill in 3rd at 25mph. I have the Dell 36X30mm drla's on my bus with a Webcam 163 that has 250' and .420" valve lift. But on the other (74mm 88mm engine) with 40x28 Webers and 1.25 rockers with the webcam 118 it comes out like a webcam 218 only my ratio rockers are giving it .460" valve lift. I think it's the better performing engine for sure.
That 1968cc is my dream engine for a bus. There are better 1.25 Rockers that you could get but I don't think your going to need the 1.25's with the Webcam 218 as it's a nice 242' and .455" lift. If you try the 1.25 ratio rockers it's going to need racing pushrods (that you may already have) and it's going to need a little more space at the (pushrod tube mouth) to not rub there.
Here is a Photo:
Danwvw Samba Member
Posted: Sat Sep 11, 2021 4:37 pm Post subject: Re: New Heads and 1.25 Rockers? |
I just multiply 1.25 or whatever (my rockers measured 1.3) X the cam lift. When only valve lift is given cam lift is (Valve Lift/1.1) ACN has the Cam Duration and Lift Specifications. Also the webcamshaft.com Site has all the cam cards for their Type 1 VW cams: _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
modok Samba Member
Joined: October 30, 2009 Posts: 26779 Location: Colorado Springs
Posted: Sat Sep 11, 2021 9:46 pm Post subject: Re: New Heads and 1.25 Rockers? |
Web 218 has about .420 lobe lift
Are you looking at a 218/119 split grind? |
Danwvw Samba Member
Posted: Sat Sep 11, 2021 9:52 pm Post subject: Re: New Heads and 1.25 Rockers? |
I reverse calculate .5216" or .525" lift and ratio rockers are a little off my Scat measured 1.29 so maybe .538" or more valve lift. It's pretty simple to measure durning mock-up.
sled Samba Member
Posted: Sun Sep 12, 2021 8:04 am Post subject: Re: New Heads and 1.25 Rockers? |
mikelars wrote: |
modok wrote: |
I got the 218 with a 108LC from Aircooled.net |
AC.net lists the 218 with .455 lift with 1.1 rockers
Webcam's website lists it at .459
so thats around .417 cam lift. multiply that by 1.25 as you have done, and thats .521
you must have been looking at the 218/119 split cam _________________ drive your split. |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1668 Location: Niagara Region, CANADA
Posted: Sun Sep 12, 2021 12:02 pm Post subject: Re: New Heads and 1.25 Rockers? |
Ask your head guy what the optimum lift is for a 37mm valve.
Probably less than .490...So anything higher is a waste of spring. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3286 Location: Rapid City, SD
Posted: Sun Sep 12, 2021 12:05 pm Post subject: Re: New Heads and 1.25 Rockers? |
Is this a road trip bus you are planning to put a lot of miles on, or will it stick to driving across town for ice cream?
I don't think the ratio rockers and extra .060" lift are worth the extra wear, and noise. Sure it will work, but I am guessing your 1.25 rockers will really measure out to over 1.3, and the 218 is not designed for large ratio rockers. I have built lots of engines with a 218 and stock rockers. It works great every time, runs quiet, and I don't need to worry about it being over stressed.
My 37x33 heads will flow just past .525" and they start to taper off. I would imagine Tims are similar. If it was going into a ripper fun bug, I would say use the extra lift, but at that point, I would also be using a different cam.
One of the major keys to a long lasting successful engine is make sure none of the parts are over stressed, or working past their designed limits. If you want it to last.....Don't try to push the limits of everything.
Brian _________________ www.type-emotorsports.com |
Danwvw Samba Member
Posted: Sun Sep 12, 2021 12:09 pm Post subject: Re: New Heads and 1.25 Rockers? |
Not terribly extreme but the dual valve springs will be rough on the cam and lifters. Cam and lifters can sometimes fail to break-in without galding. Good oil like VR-1 or add ZDDP "Zinc" to your oil. I would think that swivel feet adjusters would save Valve Guide Wear. A better way to achieve this much lift is with Ratio Rocker Cams. Also be sure the valve doesn't hit the head. I would use something like a putty to check it doing a mock-up! And! make sure that the dual valve springs don't bind any. Maybe consider breaking the cam and lifters in with the 1.1 ratio rockers. first.
Posted: Sun Sep 12, 2021 12:31 pm Post subject: Re: New Heads and 1.25 Rockers? |
Brian_e wrote: |
Brian |
Ok, I think I will stick to the 1.1 rockers. This is a daily driver bus and I am trying to get quiet low end power.
One more question - if I use dual springs in the heads, but stick with 1.1 rockers, is it much extra wear on the valve train over just having single springs? _________________ Here is my 1961 Beetle Restoration:
