Mike313 Samba Member
Posted: Mon Sep 06, 2021 3:26 pm Post subject: Seeking input: Putting my 73 Fastback on blocks |
Hey everyone,
It's been a couple years while I worked on other goals, but I'm back to work on my 73 Fastback now. Once I get the interior back together I want to put the whole car up on blocks to thouroughly go through the wheels, brakes, and suspension. This could take a couple months with my schedule so I'm not comfortable leaving it on jackstands with my family going in and out of the garage all the time. I'm going to blast, paint and reuse the stock rims and need new tires all around so I want all 4 corners up. I'm thinking of cinder blocks and 2x6's built to height, but want to be careful about where I place them. I don't want to stress anything or block access to suspension components that I might need to get to.
What do you guys think about a good block placement? Any other advice is welcomed as well.
Thanks!
Mike |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Mon Sep 06, 2021 4:49 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Put wooden blocks under each corner of the pan. That leaves the front beam and rear subframe available for removal if you should desire. The pan is strong enough at the corners to support the weight of the car.
The balance point will be close to the jack points. If you remove the beam first the front of the car may tilt upwards so be careful.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Posted: Mon Sep 06, 2021 4:59 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Thanks for the input Max. I have plenty of 8x8 beams laying around that I can cut to blocks, so that gives a fair amount of surface area on each corner to spread the weight...
Mike |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Sep 06, 2021 6:40 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Mike313 wrote: |
Mike |
I agree with Max on the placement, In the rear I'd probably go under the rear torsion bar tube with a wooden block above it. Up front, I'd look at the spot where the 2 bolts on each side go up from the pan to the body. I use this as a jacking/jack stand point as it's nice thick solid metal. And unless you plan to pull the body off, the block can stay there. It'll be a nice solid stable place to put them. However, if you plan to remove the rear subframe you'll probably have to reset the rear blocks to somewhere near the jack point mounts, as any further rearward and you won't be able to remove the subframe. I wouldn't leave the blocks there long term with the rear subframe and engine in place (unless I had the blocks under the rear torsion tube), as the floor will eventually bend due to the weight at that location (engine, trans, and subframe weigh quite a bit by themselves). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Sep 06, 2021 7:07 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Thanks Bob, excellent info! Very much appreciated guys!
Mike |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Tue Sep 07, 2021 11:25 am Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Never use cinder blocks. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Tue Sep 07, 2021 1:48 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Quote: |
so I'm not comfortable leaving it on jackstands with my family going in and out of the garage all the time |
you're using the wrong jack stands
I have the 6 ton stands, and it won't move on those, although you need the high lift jack to go with them if you use them at their max height of 24 inches. It sure makes working under the car a lot easier
https://www.princessauto.com/en/6-ton-jack-stands/product/PA0008760688
My buddy uses the 12 ton stands for his thing _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Qldelsie Samba Member
Joined: September 22, 2019 Posts: 518 Location: Queensland Australia
Posted: Tue Sep 07, 2021 5:12 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
KTPhil wrote: |
100% agree. NEVER. |
Posted: Tue Sep 07, 2021 6:11 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Thanks for the advice on the cinder blocks. As much as I like collecting tools, I don't have room for 6 ton stands. I have some nice 3 ton stands that I use to support the Camaro when I pull the wheels one side at a time, and a 3.5 ton low profile Arcan jack. I do have an abundance of wood beams, 6x, 2x, and plywood so I can put something solid together from that. I assume you guys have had some cinder blocks fail/crush? I appreciate the warning for sure.
Thanks for all the input!
Mike |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Tue Sep 07, 2021 7:59 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Mike313 wrote: |
Mike |
I am using these.......
https://www.harborfreight.com/dirt-bike-stand-67151.html
I have four but am using two for the front end right now with the rear wheels on the ground. My car was on them for four years....all four corners ....so they work fine. The wide pad and riveted on rubber landing make it soft on the pam corners. Mind you my car is a 412.
When I needed extra height I made a beam of three 2" x 8" boards....bolted together from both sides by 3/16" X 6" "Spax" bolts. Stand this on edge....just like a rafter in a house....and span it from stand to stand.
I also have 6 ton jack stands. But the jack stands....do not go this high. And....no matter what anyone says...with their small upper contact patch they are not stable for something that is going to spend a long time up in the air with lots of people bumping around it and inside and out.....and they put all the pressure one small 1" square spot.
Not sure off the top of my head about type 3....but there is no place on a 411 or 412 to put 6 ton jack stands that will drop into the groove in the top of the 6 ton jack stand. So...really...its a lot of pressure on a small area.
My car weights 2300 lbs with all the guts in it. With no engine or trans it weighs about 1900. With two wheels on the ground and these cycle lifts up front....it would be rare to have more than 500 lbs on each.....and its spread over a far wider contact patch.
Just one way to do it. Ray |
Posted: Fri Sep 10, 2021 7:22 pm Post subject: Re: Seeking input: Putting my 73 Fastback on blocks |
Thanks Ray! Appreciate the photo. I agree with spreading the weight as much as feasible. Just makes sense to prevent an accident in case there's a weak spot we don't know about from corrosion or subpar previous repairs.
Mike |
