DC0046 Samba Member
Joined: April 24, 2021 Posts: 51 Location: Oklahoma City
Posted: Thu Sep 09, 2021 3:32 pm Post subject: Sticking Throttle |
Newbie here. Have a 77 Vert with a 2074 and dual EMPI HPMX 44s. Had problems with the accelerator pumps leaking on both sides and in spite of my efforts couldn’t get them to stop. Took car to a local VW tech and he planned them down and no leaks. Got car back and now the throttle sticks. I have literally 50 plus hours in working with the linkage, etc, but still problems. Helm joints are fee and lined up. There is no sticking until the car gets up to operating temp (about 250 CHT on number three). Sometimes I can blip the throttle and get the idle back to normal. Sometimes not. I am confident it is not in the throttle cable and I believe the cause is in the passenger side carburetor. Thanks in advance for your help. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12710 Location: Western Canada
Posted: Thu Sep 09, 2021 6:58 pm Post subject: Re: Sticking Throttle |
What have you got for return springs? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
DC0046 Samba Member
Posted: Thu Sep 09, 2021 7:41 pm Post subject: Re: Sticking Throttle |
Stock return springs, although I have cut about four coils on the passenger side carb to increase tension. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9756 Location: Oregon
Posted: Thu Sep 09, 2021 9:34 pm Post subject: Re: Sticking Throttle |
Most times a pic or 800 help solve a problem here.
I have a very busy engine compartment. But my linkage still moves freely with then stock dual carb springs.
You have a problem that is causing the throttle linkage to stick at a certain position.
Get the engine up to temp and see if you can get a pic of the position that the linkage is sticking open. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Fri Sep 10, 2021 12:27 pm Post subject: Re: Sticking Throttle |
Sometimes this can be the throttle butterflies catching on the side of the carburettor throat - try loosening the screws holding them in place on the spindle and then letting the butterflies settle into place as they close, then tightening the screws.
If they are fixed in place slightly too closely together on the same throttle spindle, as the body expands at a different rate to the spindle, the butterfly is more likely to catch. _________________ Ancient vehicles and vessels
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Sep 10, 2021 2:00 pm Post subject: Re: Sticking Throttle |
DC0046 wrote: |
What are stock springs?..... Only springs that come with dual cab system are clockwork springs on carb shafts?
This was my solution to throttle return problems...
And very positive return to closed if you loose throttle linkage... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
sled Samba Member
Posted: Fri Sep 10, 2021 2:26 pm Post subject: Re: Sticking Throttle |
well, before you go taking carbs apart and messing with internals, try slightly loosening the throttle shaft nut on the offending carb. You will have to bend the lock tabs back, and then back the nut off a hair. You might have to do this on both ends of the shaft, or try one at a time to find out which side is binding.
I had one carb on a customers engine that did this exact thing, when hot it would stick open slightly causing the engine to race. Slightly loosening the nut fixed this.
hopefully its something simple like that! _________________ drive your split. |
DC0046 Samba Member
Posted: Fri Sep 10, 2021 3:19 pm Post subject: Re: Sticking Throttle |
Thank you everyone for your replies. I will try loosening the the nut on the clock spring first and go from there. In reference to the return springs, they are very similar to the posted picture. I didnt build this engine and they were on the carbs when I purchased the car about four months ago. I cut about four coils off of the the passenger carb to stiffen the return spring. I will try to get pictures posted in a bit. Thanks again. These things have more moves then a belly dancer and really have me scratching my head. |
sled Samba Member
Posted: Fri Sep 10, 2021 5:57 pm Post subject: Re: Sticking Throttle |
additional springs should NOT be used. If you need additional springs other than the factory springs, you have a problem. _________________ drive your split. |
oprn Samba Member
Posted: Sat Sep 11, 2021 6:42 am Post subject: Re: Sticking Throttle |
Dale M. wrote: |
DC0046 wrote: |
And very positive return to closed if you look throttle linkage... |
That is what I did too. The stock carb springs are not sufficient to give a reasonable peddle pressure on our cars with our 8 feet of cable drag. Your foot gets very tired trying to hold it up after a short while on a long trip. I start to get leg and foot cramps at about the 2 hour mark.
Yes he has something not quite right too but additional springs help with drivability. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
sled Samba Member
Posted: Sat Sep 11, 2021 6:46 am Post subject: Re: Sticking Throttle |
I fail to see how additional springs would increase drivability or decrease fatigue. Its just going to make the pedal feel stiffer, and put undue stress on the cable and all of the links/connections/pivots.
I also ALWAYS install a soft braided cable in every bus of my own, and customers buses. Solid wire cables suck. _________________ drive your split. |
oprn Samba Member
Posted: Sat Sep 11, 2021 7:02 am Post subject: Re: Sticking Throttle |
Well, if you have tiny feet and wear ballet slippers... it might not be a problem. I am 6' 1" and take #13 boots so find most cars have gas peddles that are too light. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
sled Samba Member
Posted: Sat Sep 11, 2021 7:31 am Post subject: Re: Sticking Throttle |
then you should be adding a heavy spring at the pedal, NOT on the carbs. like I said, all its going to do is wear things out and potentially tweak things. That extra spring on the throttle shaft thats pulling in a linear motion will cause premature wear and tear.
and if we're comparing stature for pedal pressure, Im 6' and do not have ballerina feet. _________________ drive your split.
DC0046 Samba Member
Pics of the engine bay. Thanks again for any help.
Posted: Sat Sep 11, 2021 7:32 am Post subject: Re: Sticking Throttle |
sled wrote: |
I also ALWAYS install a soft braided cable in every bus of my own, and customers buses. Solid wire cables suck. |
You also have 6 more friction points on linkages for the cross bar linkages the clock springs on carb shafts were never designed to over come.....
Yes on soft braded cable and I always put second barrel connector on cable in case first one slips, it gives me a limp to safe place mode until proper fix can be done....
sled Samba Member
Posted: Sat Sep 11, 2021 7:36 am Post subject: Re: Sticking Throttle |
Dale M. wrote: |
this is very true, but if the joints are maintained and lubricated appropriately, then there should be little to no friction.
but, that (among other things) is also why I do not use crossbar linkages. _________________ drive your split. |
DC0046 Samba Member
Posted: Sat Sep 11, 2021 7:38 am Post subject: Re: Sticking Throttle |
Pics of the car.
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Sat Sep 11, 2021 7:52 am Post subject: Re: Sticking Throttle |
Nice looking ride you have there, bet it's fun to drive with the top down |
DC0046 Samba Member
Posted: Sat Sep 11, 2021 7:59 am Post subject: Re: Sticking Throttle |
Thank you. Hopefully I can get these carb issues worked out. |
oprn Samba Member
Posted: Sat Sep 11, 2021 8:09 am Post subject: Re: Sticking Throttle |
The whole car is junk! I am coming to do you a favor and take it off your hands before it costs you anymore money. What is your address?
By the way, I see what your spring problem is. Hang on and I will draw you a picture. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
