slayer61 Samba Member
Posted: Mon Aug 23, 2021 6:53 am Post subject: Re: What did you do to your Bug Today? |
I had the Hurst shifter in high school, in my '73. All "Hurst" shifters now are chinese
Very cool |
radstude Samba Member
Joined: January 29, 2005 Posts: 397 Location: Lynchburg Va.
Posted: Mon Aug 23, 2021 7:17 am Post subject: Re: What did you do to your Bug Today? |
slayer61 wrote: |
Very cool |
This one is from the late “70”’s, use for years then
Taken off & put in a box. Sold old bug with stock shifter. |
irvanm Samba Member
Joined: January 09, 2008 Posts: 609 Location: Lawrence, Kansas
Posted: Mon Aug 23, 2021 2:00 pm Post subject: Re: What did you do to your Bug Today? |
I kinda did the opposite, I took the old aftermarket shifter out and put in an original type I bought in the classifieds. Its also night and day improvement in driving and i like the looks better. The pictures show the old one and then the new stock one installed.
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Wed Aug 25, 2021 7:58 pm Post subject: Re: What did you do to your Bug Today? |
Cut some weeds from underneath of it. Even though the driveway is gravel the weeds still come up under it. Unfortunately with me working almost 60 hours a week I don’t really have time for it except on weekends now and I’m usually busy then too. . Next thing to do is probably get tires as the ones on it are dated 1995 and they are cracking and going flat. Might do some suspension work too. Of course I’ll post when I do more. |
unclewede Samba Member
Posted: Thu Aug 26, 2021 11:21 am Post subject: Re: What did you do to your Bug Today? |
We replaced the original steering wheel (that literally broke in half) with a smaller diameter one, with color, so that my sons/my legs would more easily fit when getting in.
Today I'm dropping it off to have a horn path created, and connected to the center of the new wheel. While in there, also going to R/R the signal cancel.
I'm dropping with mechanic, electrical is a bit over my head. He seems to think he can do this for 1.5 hours labor - SOLD! |
regordracis Samba Member
Joined: June 16, 2019 Posts: 148 Location: Hamilton Ontario Canada
Posted: Fri Sep 10, 2021 6:48 am Post subject: Re: What did you do to your Bug Today? |
... finishing up a tough job I was procrastinating on
...decided to try some heat and it worked great on the first , thicker layer of a black rubber substance that had a layer of brown paper over it
This rubber wheel on a drill is my new best friend - vertical surface complete
Now , the luggage shelf , this is how far I got the last time i left the job , many hours of scraping and penetrating oil , just for half the area
The finished product , heat for that first layer , came off like butter , then ran out of penetrating oil , luckily , just as I finsihed the job
So impressed with the heat / rubber wheel , I'm moving to the front footwells and front firewall , nap hat area , whatever you want to call it ...
_________________ Roger ... "Lost in the haze of alcohol-soft middle age" |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Fri Sep 10, 2021 8:39 am Post subject: Re: What did you do to your Bug Today? |
regordracis wrote: |
What is this rubber wheel that you are using? I have to strip the glue off of my footwells as well. _________________ Where would this hobby be if no one shipped parts.
crukab
Feb. 11, 2021
Smokey says.... only you can prevent Bug fires!
zerotofifty
May 16, 2023 |
That_One_Chick Samba Member
Joined: October 05, 2020 Posts: 9 Location: California
Posted: Fri Sep 10, 2021 8:50 am Post subject: Re: What did you do to your Bug Today? |
... thicker layer of a black rubber substance that had a layer of brown paper over it |
I had the same stuff. My progress doesn't look as clean as yours. lol
I added some rust reformer on the rail and a little on the firewall.
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Fri Sep 10, 2021 9:29 am Post subject: Re: What did you do to your Bug Today? |
Big Bull Shooter wrote: |
What is this rubber wheel that you are using? I have to strip the glue off of my footwells as well. |
Eraser:
https://www.amazon.com/Stripe-Wheel-07498-Diameter-Mandrel/dp/B00063VT0G/ _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Posted: Fri Sep 10, 2021 10:09 am Post subject: Re: What did you do to your Bug Today? |
The response from the Shark is pretty much it. There were a few other options that looked pretty beefy , but maybe too big for some of the areas under the dash so I stuck with a small 4"
I imagine that 3M brand to be really good quality , although mine cost less than $20 CDN and I'm happy with it.
:2gunfire: Bullshooter : I picked my wheel up at Princess Auto , looks like there's a bunch of locations out on The Left Coast.
I'll leave with this one observation : warming that goo with a heat gun before the rubber wheel made it come off my S _ P _ R , super easy (tacky joke , sorry) ... _________________ Roger ... "Lost in the haze of alcohol-soft middle age" |
Posted: Fri Sep 10, 2021 10:49 am Post subject: Re: What did you do to your Bug Today? |
... oh by the way ... don't disturb those two blobs of seam sealer back there ...
Only an over-sized dollop of seam sealer keeping these little squares secured over these "holes - with - no - (apparent) purpose"
... another task added back onto the To-Do list ... sigh ... _________________ Roger ... "Lost in the haze of alcohol-soft middle age" |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Sun Sep 26, 2021 12:10 pm Post subject: Re: What did you do to your Bug Today? |
Put a new muffler on today
_________________ Repeat after me "I am smarter than metal!" |
Posted: Sun Sep 26, 2021 12:25 pm Post subject: Re: What did you do to your Bug Today? |
Tried to do a leakdown to figure out why there's high pressure in only the 3/4 valve cover.
Turns out sucky little air compressor is sucky. Couldn't maintain pressure even on a tight cylinder. Sigh.
I *think* the #3 cylinder is passing air through the valve somehow. Still not sure why only one valve cover would be under pressure, but that happens to be the cylinder that got a screw caught in the exhaust valve. The valve, guide, and seat were all replaced by a shop, but I don't believe in coincidences... _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
IamZardoz Samba Member
Posted: Wed Sep 29, 2021 10:16 am Post subject: Re: What did you do to your Bug Today? |
Well, solved two irritating issues today; my fuel guage has been haywire since I bought my 74 bug and last night I decided to change out my sending unit as I already had a spare and that didnt solve the issue. I traced the wire up to the guage back and it seems like the nut that holds the wire was a tad loose.
Tightened it and all seems good. Second problem I had has the rear seat back latch grab handle had somehow become unattached. I had a hell of a time stuffing my fat fingers back in there but finally got my seat to fold down after a year and a half. I reattached the plastic pull handle I and works like a charm. Thanks to whoever posted the pics of the latch so I could figure out by braille how the darn thing worked! _________________ 2005 Dodge Ram Hemi Quadcab
2020 Chevy Tahoe |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1104 Location: North East Pennsylvania
Posted: Wed Sep 29, 2021 6:03 pm Post subject: Re: What did you do to your Bug Today? |
I fit up a fiberglass air dam that I picked up at the Carlisle, PA Import show 20 or 30 years ago. It was made to fit a Super beetle with wider fiberglass fenders. I cut it down and am trying the fit. No idea who made it.
Mike T
_________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9638 Location: Pearl River, NY
Posted: Wed Sep 29, 2021 6:12 pm Post subject: Re: What did you do to your Bug Today? |
Those 2 squares were likely well-placed drain holes for the factory primer when the entire body was dipped into the huge vat. When the body would rise back up at an upward angle from the overhead conveyor line, the holes helped the pooled-up primer run out so that you had a more uniform film thickness on the rear cargo floor. Once the primer had dried, the holes were covered with the squares and held in place with the seam sealer. |
Posted: Thu Sep 30, 2021 12:27 pm Post subject: Re: What did you do to your Bug Today? |
I sprayed this star on my hood. The dark square around it is stencil adhesive. Hopefully it comes off at the car wash after the paint cures.
flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Fri Oct 01, 2021 11:08 am Post subject: Re: What did you do to your Bug Today? |
Installed a Magnaspark II distributor and dry pack coil.
_________________ Type 1 1968, Lotosweiss. 2109 oxyboxer engine
Early Bay 1970, Montana Red. Under construction |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9753 Location: Oregon
Posted: Sat Oct 02, 2021 8:56 am Post subject: Re: What did you do to your Bug Today? |
flat4olsen,
How do you like that LoGMech throttle cable system?
http://logmech.se/eng/products/carburator/throttlecontrol-cable-kits/
I have clearance issue with the Magna Spark II dist and CSP center pull linkage. The left rod contacts the dist body. And hangs the throttle open on that carb.
Curious, why did you change from the CB BlackBox to the Magna Spark II? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
