When did they change the transmission mount on the torsion tube?
Busted-bolt
Busted-bolt is offline
PostPosted: Mon Sep 13, 2021 5:51 pm    Post subject: When did they change the transmission mount on the torsion tube? Reply with quote
I what is left of a 59 bus that has a late model two bolt mount on the torsion tube. does that mean that some time in 59 they they updated the nose cone on the split style transmission ? I don't have the original transmission any more because it had a big nut in it when i got it . m plate =04 06 9 4780xx
Vw collection 60 combi ,61 panel ,62 deluxe micro,82 diesel Westfalia,88 Vanagon synchro,98 Jetta tdi,11 Jetta tdi mt ,11 Jetta tdi dsg.
I do all my own work,body,engine and transmission.
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Mon Sep 13, 2021 7:22 pm    Post subject: Re: When did they change the transmission mount on the torsion tube? Reply with quote
IIRC, it was sometime in late August 59 that the tunnel trans became standard in buses.
Edit: Wrong! See later posts below.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
bonewso
bonewso is offline
Yes. Sometime in mid-1959. I have an April '59 single cab and it has the early mount.
Busted-bolt
PostPosted: Mon Sep 13, 2021 7:34 pm    Post subject: Re: When did they change the transmission mount on the torsion tube? Reply with quote
I might be wrong but I thought the tunnel transmission started sometime in mid 60 "61 model year" . But maybe they used a beetle nose cone on a split transmission from the factory from some time after April or May 59 busses.
PostPosted: Mon Sep 13, 2021 10:20 pm    Post subject: Re: When did they change the transmission mount on the torsion tube? Reply with quote
Another thread said
Clara wrote:
splitcase was used through mid May 1959.
I couldn't find an exact date or VIN # though in a few threads I researched
Lind
Lind is offline
PostPosted: Tue Sep 14, 2021 5:43 am    Post subject: Re: When did they change the transmission mount on the torsion tube? Reply with quote
469447
Wanted:
BulliBill
BulliBill is offline
PostPosted: Tue Sep 14, 2021 6:09 am    Post subject: Re: When did they change the transmission mount on the torsion tube? Reply with quote
I'm pretty certain that the change from "splitcase" to "tunnel" transaxle case happened with the end of the 36hp engine and the introduction of the new "Bastard" 40hp engine on May 19th, 1959.
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
