davidmeigs Samba Member
Posted: Thu Sep 16, 2021 11:26 am Post subject: 1974 Ghia Steering Assembly |
It’s not clear to me where these 2 parts fit on the 74 Ghia steering assembly. It’s not obvious in the parts diagram. It looks like the plastic bushing fits under the steering wheel with slots away from the wheel as installed. I guess the other part pinches the steering column near the steering gear box but it must attach to the body somewhere?
Vladiiiii Samba Member
Joined: February 24, 2019 Posts: 518 Location: Munich, Germany
Posted: Thu Sep 16, 2021 11:40 am Post subject: Re: 1974 Ghia Steering Assembly |
About the bushing, I don't know / recall installing it in my 72, but maybe I'm wrong.
The U-shaped part you have to clamp on the column on the outside of the cabin. In case of the crash, it stops the column being pushed towards the cabin, it just jams against the "tube" in which the column goes.
You will struggle, but may be able to see it in the picture, clamped to the crushable zone of the column :
Vlad _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746 |
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Thu Sep 16, 2021 12:20 pm Post subject: Re: 1974 Ghia Steering Assembly |
Vladiiiii wrote: |
Vlad |
Lose that urethane steering coupler before it kills you. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Sep 16, 2021 12:37 pm Post subject: Re: 1974 Ghia Steering Assembly |
That's not my picture, you stalker, you
I have an original style one, besides, would not really fancy something that rusty _________________ Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Thu Sep 16, 2021 2:05 pm Post subject: Re: 1974 Ghia Steering Assembly |
In regards to that U clamp in the second pic, like Vlad says, that goes on top of the "crush cage tube" on the steering column. After you run the column through the fire wall and through the tube, you slip that U clamp over the top of the crush tube. Those little tabs with the rubber on them then bend into cut out areas to hold in place. There should be some play between that clamp and the tube attached to the fire wall. Hope that makes sense.
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
Posted: Tue Sep 21, 2021 3:31 pm Post subject: Re: 1974 Ghia Steering Assembly |
Thanks. Installed the pinch clamp.
