andersonj Samba Member
Joined: January 17, 2011 Posts: 138 Location: Windhoek, Namibia - South Africa
Posted: Wed Jan 22, 2020 12:54 am Post subject: Which spring and shock for a syncro? |
Hi
I have been reading alot about what coils and shocks are mainly suggested and what to stay away from and Im still as confused as when i started the research
I have a 86 westfalia syncro with a slanted vw 2l conversion with 235/75/15 AT tires and complete powerflex front bushings installed, no extra weight mods. It currently has stock rear coils and shocks with a spacer and front is stock coils with monroe black shocks not sure on the model.
On rough corrugated roads it feels pretty unpleasant, does not seem to soak up the road very well, feels as if it bounces along, not sure if its because its to soft or hard but its not a comfortable drive imo, tires were at 1.6bar.
i am under the impression the front is to soft and cant handle the weight.
I have been looking at the gowesty 2inch lift springs and the schwenk.
Who has the gowesty springs and are really impressed with them on a westfalia syncro.
Schwenk says their springs are a "little" stiffer than stock designed to work with the OME shocks, then if i read on gowesty about the OME shocks they sell, "are not for extended 4x4 use as they are stiff". How stiff would schwenk be?
So with all this conflicting info on the web its making the whole process real complicated because coils and shocks are not a cheap purchase, but i understand its all about preference so now i would rather like to see who has what setups and how you guys feel about what you have on your loving money pit syncro |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Wed Jan 22, 2020 2:56 pm Post subject: Re: which spring and shock for a syncro? |
Springs only support the weight of the vehicle, and are what calculates the ride frequency. If I had to choose any spring over stock, it would be Schwenk springs. The engineers did a fantastic job setting up the van to ride with stock parts.
Shocks are personal preference. FOX are decent, but don't expect a huge difference in adjustability. My syncro westy shocks are WAY stiffer than anyone else's, but are valved properly, for my setup. My personal favorite off the shelf shocks are Bilstein Touring. I don't care one bit for GW springs or revalved shocks.
If you do a lot of washboard, you might want a rear shock with an external reservoir, because the rears can heat up and fade after a while.
I'm betting the Monroe shocks have a lot to do with the poor feel of your van _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
human compass Samba Member
Joined: June 04, 2013 Posts: 423 Location: Flagstaff,AZ
Posted: Wed Jan 22, 2020 3:29 pm Post subject: Re: which spring and shock for a syncro? |
burley radflo set up is amzing
_________________ 84 Westy Syncro- 3.3L SVX stage 2 tune,subaru gears 6speed with tbd, front locker, porche brakes x4, aux tank, radflo susp |
Syncro Jael Samba Member
Posted: Wed Jan 22, 2020 5:52 pm Post subject: Re: Which spring and shock for a syncro? |
I first went with GW progressive springs and Old Man Emu Shocks. This was a 2" lift for my Syncro. Luckily I have traveled in Utah lot and Hans has always told me "soft springs and firm shocks". He has his Syncro set up perfectly. So after the Progressive springs started to sag I purchased Schwenk springs, T3 sway bar w/end links, and Fox adjustable remote reservoir shocks. I can adjust the front ride height on the spring perches and the rear with spacer pads.
The ride difference is amazing. On the road I can set the shocks to firm and all the swaying and wind buffeting has been reduced to almost nothing. Off road I can adjust all four shocks down to soft, reduce tire pressure, and it rides comfortably over bumpy roads and washboards. I have had a few people ride with me out in Moab and they cannot believe how well the ride is. It soaks up all the bumps and is really pleasant to ride in even at speeds. My wife agrees that it rides so much better.
There are so many options out there, but I am really happy with my choices.
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
Posted: Thu Jan 23, 2020 2:51 am Post subject: Re: which spring and shock for a syncro? |
hans j wrote: |
I'm betting the Monroe shocks have a lot to do with the poor feel of your van |
thanks for the info, ive read alot of good things about the schwenk springs, which shocks would still work nicely with them besides the OME.
Ive also found alot of good info on the trailmaster shocks and springs and it seems they are also up there with the best.
If i was to purchase shocks i would be looking at the bilstein b6's or the traillmaster comfort or HD, but still confused.
I would prefer a more stiff ride but i dont want to feel every bump through my spine.
Are stock coils and decent shocks an ok setup and what would be a nice fit for stock coils.
thanks guys |
Posted: Thu Jan 23, 2020 2:52 am Post subject: Re: which spring and shock for a syncro? |
human compass wrote: |
wow that looks amazing must set you back a fair bit from the pocket, where can one purchase such a kit? |
Posted: Thu Jan 23, 2020 2:56 am Post subject: Re: Which spring and shock for a syncro? |
Syncro Jael wrote: |
sounds like a sweet setup you have their now, the fox do seem to be amongst the best. Are the Scwenk on the softer side and thus the reason why they recommend OME?
so if the way to go is soft springs hard shocks then the stock coils are decent with bilstein b6 or trailmaster hd shock? |
Posted: Thu Jan 23, 2020 2:58 am Post subject: Re: Which spring and shock for a syncro? |
andersonj wrote: |
quick silly question what benefits are then from changing the upper control arm over stock?, |
Posted: Thu Jan 23, 2020 9:02 am Post subject: Re: which spring and shock for a syncro? |
andersonj wrote: |
check out burley motorsports website. more info on the kit there. expensive but worth it _________________ 84 Westy Syncro- 3.3L SVX stage 2 tune,subaru gears 6speed with tbd, front locker, porche brakes x4, aux tank, radflo susp |
Posted: Thu Jan 23, 2020 10:11 am Post subject: Re: Which spring and shock for a syncro? |
andersonj wrote: |
The added adjustment of threaded “BMS new-generation heim joints” allows you to achieve perfect camber caster settings for your wheel alignment every time. This design removes the need for the troublesome stock bushings that so many people complain about. Our heim joints are also made greasable zirk fittings, which ensures that everything stays lubricated and quiet! No matter how high your Syncro is lifted or you prefer it at the stock ride height, these control arms are the answer to getting performance, safety and comfort all in one product!
https://burleymotorsports.net/product/syncro-upper-control-arms/ _________________ 1987 Syncro Westfalia Hightop - NAHT
Syncrohilge Samba Member
Posted: Thu Sep 16, 2021 1:44 pm Post subject: Re: Which spring and shock for a syncro? |
Hi Syncro Jael,
In reading your post, you mentioned you switched to the Schwenk springs. I'm considering the Schwenke Springs with the adjustbale Fox shocks as well, wondering if you went with the Syncro Lift Springs or Standard Springs? I know GoWesty recommends for the Fox shocks that you stick with the standard height springs in front and adjust the height with the adjustable perch. Would this also apply to the Schwenk? Assuming you would then go with the lift springs in the rear? |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Thu Sep 16, 2021 2:25 pm Post subject: Re: Which spring and shock for a syncro? |
Syncrohilge wrote: |
Hi Syncro Jael,
F.Y.I. SyncroJael has sold his Syncro left the forum. _________________ This free advice is worth exactly what you paid for it.
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Sep 28, 2021 8:43 am Post subject: Re: Which spring and shock for a syncro? |
My shocks and springs have seen better days.
I finally worked up the courage to load up my Van Cafe shopping cart and buy new Schwenk Standard springs, new OME's, all new hardware, and rear CA Powerflex bushings, and...
Everybody, VC, GW, Burley, etc. is out of stock on OME's. I can't find them anywhere with our regular vendors.
Bilstein B6's are also out of stock with our normal vendors, but there appear to be some floating around at other places.
Now I'm torn between the B6's and waiting for OME's.
When am I going to muster the cajones to place a $1000+ order again? _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
