More power please
buguy
buguy is offline
PostPosted: Fri Sep 17, 2021 5:34 pm    Post subject: Re: More power please Reply with quote
Paul.H wrote:
madmike wrote:
Ha,, had a tiny bit when I had a Weber Sidedraft Rolling Eyes
upgraded ,, no 'Lag' with a Holley 680 Quickfuel ,runs 11.85 @113mph(17 psi boost) and gets 26-28 mpg on Premium Pump gas,, I do spray water/meth(pissor juice) aka: windshield solvent Wink
Ah that's slow as f*** are you sure you had all the plug wires on ?
What are you working with that makes an 11.80 slow?! Especially a street driven car on pump gas!
Paul.H
Paul.H is offline
PostPosted: Fri Sep 17, 2021 6:16 pm    Post subject: Re: More power please Reply with quote
First the meme gets taken seriously now this
It's just an old pit joke Rolling Eyes
buguy
buguy is offline
PostPosted: Fri Sep 17, 2021 7:33 pm    Post subject: Re: More power please Reply with quote
Thank goodness! My wallet can't take too many more hits!
StefansBus
StefansBus is offline
PostPosted: Fri Sep 17, 2021 11:43 pm    Post subject: Re: More power please Reply with quote
Paul.H wrote:
First the meme gets taken seriously ...
Just to be clear: I didn't really take the meme all that seriously but when you posted "can't argue with that" in response to the meme I felt the silly urge to post that yes, it could indeed be argued with. That's all. Meme or not, I think it would be just as funny but more factual it i read something like: Turbo lag, the brief moment when the other guy thinks he still has a chance... Or something like that.
UK Luke 72
UK Luke 72 is offline
PostPosted: Sun Feb 06, 2022 1:21 am    Post subject: Re: More power please Reply with quote
What's the latest on this Baz?
Assume you've got it back together now?
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
challomoner
challomoner is offline
PostPosted: Sun Feb 06, 2022 3:05 am    Post subject: Re: More power please Reply with quote
Hi Luke, haven't got the heads and manifolds back from torben yet so it's still gathering dust right now. 😐
Alstrup
Alstrup is offline
PostPosted: Sun Feb 06, 2022 6:02 am    Post subject: Re: More power please Reply with quote
They are just around the corner.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
UK Luke 72
PostPosted: Sun Feb 06, 2022 6:57 am    Post subject: Re: More power please Reply with quote
Exciting stuff.
What work has been done and what are the expected gains?
challomoner
PostPosted: Sun Feb 06, 2022 8:12 am    Post subject: Re: More power please Reply with quote
UK Luke 72 wrote:
Exciting stuff.
Will wait and see once I have it back together but hopefully a worthwhile increase.
Alstrup
Alstrup is offline
PostPosted: Sun Feb 06, 2022 8:56 am    Post subject: Re: More power please Reply with quote
Yes, it will be interesting to see how close theory and real life is.
challomoner
PostPosted: Sun Apr 03, 2022 12:48 pm    Post subject: Re: More power please Reply with quote
Very close now to finding out how much we have gained
Intakes now 44mm. Ports straightened. Exhaust rockers switched to 1.25s. Intake manifolds greatly improved and correctly shaped. Cam advanced 2 degrees. Map sensor added.
Old dyno reading was 155hp, shooting for 170 now and better mid range.
challomoner
PostPosted: Sun Apr 10, 2022 8:57 am    Post subject: Re: More power please Reply with quote
Rocker side play is only thing left to do other than some more assembly, should be running next weekend 😁
challomoner
PostPosted: Sun Apr 10, 2022 9:00 am    Post subject: Re: More power please Reply with quote
Nice work from torben on the heads
UK Luke 72
PostPosted: Mon Apr 11, 2022 12:45 pm    Post subject: Re: More power please Reply with quote
They look spicy Twisted Evil
Look forward to results from this one. How do you imagine it should compare to the generic FK8/86b kinda builds with off the shelf heads?
challomoner
PostPosted: Mon Apr 11, 2022 1:02 pm    Post subject: Re: More power please Reply with quote
I really couldn't tell you as its my first and only hot engine. The aim was to get everything to work together as best we could, it wasn't a bad engine to begin with really but should definitely be quite a bit better now.
Stuff like the intake manifolds being corrected should help, the IE ratio will be closer to ideal with the 1.25s on exhausts. The porting work should help airspeed. Better ring seal with properly honed cylinders. So long as I get it tuned correctly it should be much nicer all over.
I should get to find out over the coming weekend 😁
Once it's up and running we're looking at building a better exhaust system that should help a little more.
UK Luke 72
PostPosted: Mon Apr 11, 2022 1:49 pm    Post subject: Re: More power please Reply with quote
What exhaust do you have?
challomoner
PostPosted: Mon Apr 11, 2022 11:03 pm    Post subject: Re: More power please Reply with quote
Speedshop sidewinder
UK Luke 72
PostPosted: Tue Apr 12, 2022 4:45 am    Post subject: Re: More power please Reply with quote
Ah yeah I do remember seeing that.
challomoner
PostPosted: Tue Apr 19, 2022 6:56 am    Post subject: Re: More power please Reply with quote
I think it's fair to say we have made some decent improvements, clutch won't hold above 4k in second or third. And it's still not fully tuned.
Near disaster has stopped play for a few days though, the oil pump to filter hose blew off the pump! I won't be using push lok fittings again.
74 Thing
74 Thing is online now
PostPosted: Thu May 05, 2022 12:53 pm    Post subject: Re: More power please Reply with quote
Any updates on this engine?
Performance, how does it compare to the older version after putting some more mileage on it etc..
Page 4 of 5
