Bugeye54487 Samba Member
Posted: Thu Sep 16, 2021 6:53 pm Post subject: Doghouse oil cooler VS vacuum leak |
I have been chasing a rough start idle along with a warm start issues. Have not found any vacuum leaks yet. Is it possible to have a vacuum leak from oil cooler seals being bad? Pretty sure that it is leaking oil. Running 1600 single port, 30-pict 3, 205T distributor. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Thu Sep 16, 2021 7:03 pm Post subject: Re: Doghouse oil cooler VS vacuum leak |
Bugeye54487 wrote: |
Is it possible to have a vacuum leak from oil cooler seals being bad? |
You'd have oil leaking not air. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Sep 17, 2021 7:24 pm Post subject: Re: Doghouse oil cooler VS vacuum leak |
I should have mentioned it is leaking oil. Sorry. I meant along with the oil leak, can u have a vacuum leak? |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3847 Location: San Jose, CA
Posted: Fri Sep 17, 2021 9:13 pm Post subject: Re: Doghouse oil cooler VS vacuum leak |
Yes, you can definitely have vacuum leaks and oil leaks at the same time.
But your rough running and warm start problems are not related to your leaking oil seals, and your oil leaks are not related to any potential vacuum leaks that you may discover. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Sat Sep 18, 2021 6:59 am Post subject: Re: Doghouse oil cooler VS vacuum leak |
I'd address the oil leak first !
And if you really do have a doghouse oil cooler on a 1600cc single port, I'd triple check that you are using the correct type of oil seals between engine case and the doghouse adapter. Difference between a 1500cc "H" case and a later 1600cc "B" case or 1971-on case. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
