dogmeat Samba Member
Posted: Fri Sep 17, 2021 11:21 pm Post subject: 1700-1800 engine build |
I'm gearing up for a build. the case is a 1500 single port. it is supposed to be a running engine with low miles (but old). all subject to change, but my plan is to buy new Dual Port heads, 88mm slipons, 5.325 rods, and a 74mm crank from Aircooled. the cam is a consideration too. the main thing that I'm hung on now is the carb(s). I have all the stuff to go single barrel on DP. all I need is the unobtainium Webber progressive, not made in chinee. if I could find a used one I would rebuild it but I'm thinking maybe the EMPI 38E Carb might be the one. what do you guys think? |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Sat Sep 18, 2021 2:06 am Post subject: Re: 1700-1800 engine build |
Well, IMHO, donīt go with the Egas carb. its a POS set up on a ACVW engine. If you want something like that stay with the progressive, - OR a modified 34 Solex and intake.
Stay on the mild side cam wise. Centermount carbs "like" short duration high lift. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Sat Sep 18, 2021 5:12 am Post subject: Re: 1700-1800 engine build |
Most important in a Bus in my view is to tap the case for full flow filter and an auxiliary oil cooler. At the very least a newer doghouse should be added and monitor those oil temperatures closely.
I would also reconsider the 88mm slip-ins as they are thin wall. You want a thick wall cylinder in a heavy Bus. Also as Alstrup says, keep the cam well on the mild side to preserve your low end torque. You will soon tire of a temperamental high revving low torque engine in that big heavy echo chamber you bought! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat Sep 18, 2021 11:04 am Post subject: Re: 1700-1800 engine build |
hmmmm... confused about the 88mm slip ins from Aircooled. they are thin on the bottom but supposed to be 5mm thick up top for strength. is there problems with these cylinders?
modified Solex.... so what, a bigger venturi & jets? got any numbers? would a Solex 32-34 PDSIT- 3 be a good start?
yes, the oil filter is on the list of things to do |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Sat Sep 18, 2021 12:54 pm Post subject: Re: 1700-1800 engine build |
dogmeat wrote: |
hmmmm... confused about the 88mm slip ins from Aircooled. they are thin on the bottom but supposed to be 5mm thick up top for strength. is there problems with these cylinders?-- |
they are fine
I would go with chinese IDF or IDA copies before I'd use a progressive on a flat 4, even kads would be better and in my opinion run cooler |
Posted: Sat Sep 18, 2021 3:11 pm Post subject: Re: 1700-1800 engine build |
dogmeat wrote: |
Yes, they are like that, and it is a way to increase displacement without machining the case (with a better cylionder compared to regular 88 slip ins.) These are still paper thin at the case end and you have to be VERY carefull when installing pistons after cleanup because even the slightest angle of the pistons can easily crack the cylinder skirt, which is why I personally do not like them. But, opinions vary.
NO. you need a normal (but modified) 34 Solex Pict3 if you want to go that route, along with a CB/Empi centersection. That can give you an easy and trouble free 80 hp, or if you are ready to invest in a custom cam up around 90 hp still with almost stock idle.
But, as mention often before, these types of engines are very combo dependant. You canīt just buy whatīs on sale that week and slap it together, because it will not function optimal.
RWK Samba Member
Posted: Sat Sep 18, 2021 4:23 pm Post subject: Re: 1700-1800 engine build |
You should deck the case anyway, so thick walls should be considered, old case's most likely sunk or corroded on deck seal anyway, besides head seal surface not much more important. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Sat Sep 18, 2021 4:30 pm Post subject: Re: 1700-1800 engine build |
The 88mm non-machine in cylinders are only advertised available from Mahle. It seems that AA is only selling the non-machine bottoms. Huge price difference for most folks. |
oprn Samba Member
Posted: Sat Sep 18, 2021 4:46 pm Post subject: Re: 1700-1800 engine build |
Erik G wrote: |
dogmeat wrote: |
they are fine |
I do believe the ones that machine in on the heads are fine as mentioned but the ones that slip in the heads without machining would be sketchy on a Bus.
Erik G wrote: |
Your Webers are not necessarily the best choice here. The OP has not told us where he lives and if he will be driving his Bus in the winter. If he is in a colder climate he will want to retain the gas heater and the stock air cleaner shell and mounting bracket to be able to use the VW supplied warm intake air system. With Webers (maybe Kadrons too) there is no room for those. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sat Sep 18, 2021 6:06 pm Post subject: Re: 1700-1800 engine build |
hmmmm.... food for thought. I can see the decking as a good thing but too much will affect the pushrod length and rocker geometry. how much leeway is there. I've done some looking and see lots of options.... I'm still getting the feel.
I haven't got the engine stripped down yet to assess the condition of the parts I intended to re-use. the project may take a different direction once I get it apart (prolly a week or so)(busy time of the year)
so as you may have guessed I am new to VW, but I'm not a noob mechanic. 45 years as an aircraft mechanic & inspector. I have also scratch built aircraft, motorcycles, hovercraft and other odd stuff. I have a mill & a lathe and some experience as a machinist.
there is no gas heater in the bus. it will be a summer camper. I'm in Alaska |
Posted: Sun Sep 19, 2021 4:29 am Post subject: Re: 1700-1800 engine build |
Well, it is a bit premature to talk about this if you donīt even know if the case etc is reusable. But the older Sgl relief cases should really have the oil galley enlarged when you increase displacement and performance. But first youi need to find out whether it is worth to reuse. Check for warping, lifter bore wear, main bearing saddles of course and straightness of the cam saddles. Also check that the head studs have good material around the and the threading is good, or you need to use oversize studs or bush/Vcoil the threading. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Posted: Sun Sep 19, 2021 5:13 am Post subject: Re: 1700-1800 engine build |
I suspect then that someone drug that Bus up there from the south. VW put gas heaters in their whole line up of cars slated for cold climates from about '68. They were optional for us before then. You would still find one very useful for the cold mornings in the summer. You could run them on the 15 minute timer VW supplied without starting the engine. It would extend your camping season considerably by taking the chill off for crawling out of your sleeping bags in the morning.
Yes in Alaska you will want to preserve or duplicate all the cold weather features that Bus came out with even for your summer use. Thermostat, heat riser including an exhaust that gives good flow for it, air cleaner pre-heat system and defrost/heating system to keep the fog and dew off the windshield in the morning and on rainy days.
Your summers will be colder then 1/2 the guys on this site experiance in their winters especially if you go camping at higher altitudes. They have no idea... _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
modok Samba Member
Posted: Sun Sep 19, 2021 6:17 pm Post subject: Re: 1700-1800 engine build |
The aircooled.net stuff is for people who want a quick fix, and that's a large %
But YOU claim to know what your doing, if so
then I doubt you will LIKE
Thin slip in cylinders, crappy chinese conrods, nor ford pinto carburetors.
The progressive carbs I don't like them but they are OK AS LONG AS...
you can say they are worth every $ as long as they are cheap and so is your time, but if they cost over 300$ then.... that's some monkey see monkey do fools game.
Economics has it's limits.
So my grab box of pinto carbs is now worth THOUSANDS of dollars? Yeah right.
They can stay on the shelf for when they are truly needed. You do not need any of that for your vw. |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1475 Location: Westfield, MA.
Posted: Mon Sep 20, 2021 3:31 am Post subject: Re: 1700-1800 engine build |
I was under the impression that he was talking about the Thick Wall 88mm with Slip in bottoms. I've used these before and they're great...except i wasn't happy with the rings, I just couldn't get them to break in. To the O.P. I'm starting an 1800 build myself using the AA slip in bottom 88s, 5.325 rods and going to used Deves rings and an Engle W90 cam. An IMPORTANT note with this setup...you will need to clearance the piston skirts. It isn't hard to do and there are some vids on it. As far as carb, well mine is F.I so I can't help you there |
Posted: Mon Sep 20, 2021 3:33 am Post subject: Re: 1700-1800 engine build |
Also be careful if buying new heads. I have a pair of the AA 500s. When I bought them a few years ago they were marketed as 56cc chambers. They are 59cc. This messed up my compression big time because I was lazy and didn't measure for myself... |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Sep 20, 2021 6:44 am Post subject: Re: 1700-1800 engine build |
dogmeat wrote: |
That all sounds good EXCEPT for the carb. Stick with a rejetted 34 pict 3 and new center section. You also MUST upgrade to a offset doghouse oil cooler and larger fan set up or you will overheat the engine.(full flow isn't necessary but it is a good idea) That is not a suggestion, that is a guarantee. Back in my early building days, I would let customers talk me into doing as little as possible sometimes because they didn't want to pay. Now, I will turn down the job if they won't pay to do it correctly. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Sep 20, 2021 6:55 am Post subject: Re: 1700-1800 engine build |
So basically you have a 1500 engine and the only thing you'll be reusing is the case.
I'm not a fan of the 1500 case, the 1600 dual relief case is a better foundation to build a larger displacement semi-performance engine.
If you're going to do it, might as well spend a bit more and have something that will last.
90.5 cylinders with a 74 stroke and dual IDFs will run stronger, run cooler and last longer. _________________ Glenn
Member #1009
#BlueSquare |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
early Samba Member
Joined: January 19, 2012 Posts: 190 Location: Glen Carbon, IL
Posted: Tue Sep 21, 2021 1:41 pm Post subject: Re: 1700-1800 engine build |
Following this thread,
because I too am interested in building the same engine. a 74 x 88
to power my split window 67 Westy. it is a bit slow with a 1600 dual port right now.
i would be starting with a later 1600 dual relief case and would want to run
heater boxes , stock muffler and intake with dual port heads with a 34 pict 3.
not to hijack , just following along to see what the op decides to do. and have been reading the 1800 build mentioned in aircolled.net website.
cheers.. _________________ early-
Barnfind westy project
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M gone now
67 Westfalia
57 oval window ragtop - sold june 2021
61 sedan
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn |
