Going CRAZY pulley size
Paulinpa
Paulinpa is offline
PostPosted: Fri Sep 17, 2021 5:11 pm    Post subject: Going CRAZY pulley size Reply with quote
Ok bought a stock belt ref: my last post too freakin big the only missing part is ….could the crank pulley be small ? Pan on buggy was a 1965 and the guy I bought it from bought a crate engine
If he used a 1965 pulley is it smaller diameter? This is nuts
bugguy1967
bugguy1967 is offline
PostPosted: Fri Sep 17, 2021 8:27 pm    Post subject: Re: Going CRAZY pulley size Reply with quote
WAT
"A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine"
madmike
madmike is offline
PostPosted: Sat Sep 18, 2021 3:10 am    Post subject: Re: Going CRAZY pulley size Reply with quote
Maybe a "Power Pulley" ? got a pic? or a Tape measure?
'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
"If I'm ever on Life Support,UNPLUG Me, Then Plug me back In see if that Works"
Rome
Rome is offline
PostPosted: Sat Sep 18, 2021 7:49 am    Post subject: Re: Going CRAZY pulley size Reply with quote
Appears OP is asking if the crank pulley of a 6 V engine, either a 1200 cc 40 hp or a 1300 cc 50 hp has a smaller diameter than that of the 12 V engines (1500 cc+). And I think they are smaller- not much- maybe 1/4" diameter. I don't think I have a 6 V pulley in basement to measure.
Paulinpa- if you measure the diameter of your current "small" pulley, I'll measure the diameter of a 12 V engine'd pulley which I do have. 6 V pulley should be around 6 1/2"; 12 V about 6 3/4" " or 7". A power pulley is much smaller, approx. 5 3/4".
Lingwendil
Lingwendil is offline
PostPosted: Sat Sep 18, 2021 9:31 am    Post subject: Re: Going CRAZY pulley size Reply with quote
Aftermarket generator stand? Some are shorter.
Get us some pics of the engine.
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
