HERE WE GO!! .... 1990 Tintop!
Page: Previous  1, 2, 3 ... 39, 40, 41 ... 81, 82, 83  Next
DuncanS
DuncanS is offline
PostPosted: Sat Sep 11, 2021 1:00 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Unless? More about that later.
djkeev
djkeev is offline
PostPosted: Sat Sep 11, 2021 1:04 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Well....... 13mm x 2.5mm I've got!
Let's see what tomorrow brings.........
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat Sep 11, 2021 1:06 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Abscate wrote:
Aftermarket trans coolers are the second most marketed, useless accessories put on cars, trucks, vans, and Busses
Well the logic here is the originals rust internally and turn your ATF into a pink milkshake.
But then again, radiator based American ATF coolers have been rusting out for decades!
Does one roll the proverbial die and gamble?.......
Dave
Ghia
Vanagon
Beetle
dabaron
dabaron is offline
PostPosted: Sun Sep 12, 2021 9:17 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
i went with the FAS heatsink - $300 is pretty cheap insurance.
1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC
djkeev
djkeev is offline
PostPosted: Sun Sep 12, 2021 1:02 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Went out to the Van with Jack and jack stands.
Jacked it up and crawled under all prepared to put new Orings on the Oil Cooler.
With the increased space (I usually don’t bother jacking it up to work underneath) I had a real clear view of the lower oil cooler mating to the case.
No matter what angle I looked at it from there was no evidence of a leak.
I decided to clean up the entire area and see if I can locate the exact leak source.
A can of brake cleaner and I cleaned everything from the oil cooler to the differential mount area.
After it dried I started up the Van and let it run. I varied the rpms but didn’t drive anywhere.
After the radiator fan kicked on I crawled under while it was still running with my flashlight.
My leak originally seemed to come from the oil pan front edge.
Absolutely dry!
Dipstick tube?
Dry
Oil pan sides?
Dry
Oil cooler seal areas?
Dry
2nd gear piston?
Dry
Seal to differential?
Dry
Lower left nut holding the transmission to the Differential.
Soaking WET!!!
I let it run longer and eventually the oil filled the seam between the two units….
You could watch the oil bubble out of the washer below the nut ….
I removed the nut and washer, cleaned the area up, smeared it with Hylomar and reassembled.
Started it up…….
It promptly leaked!
Ok …… split lock washer ….. no good.
I had a heavy 8mm washer and an 8mm cap nut.
Cleaned everything up, used my Hylomar and reassembled.
Went for a 20 minute drive…….
Dry as a bone!
YES!
I realize it isn’t fixed……
But it isn’t leaking either!
Dave
Ghia
Vanagon
Beetle
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Sep 12, 2021 1:16 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
i did a B&M cooler on mine. with the Derale thermostat and fittings, gauge etc i was under what many ask for their coolers plus it's nice being able to watch the temps. and no annoying buzz/whine like some folks complain about.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
djkeev
djkeev is offline
PostPosted: Sun Sep 12, 2021 2:39 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Yeah……. I’m undecided about an oil cooler change.
I read it is also a transmission warmer.
This is a daily driver even in the Winter.
I’m thinking any help to warm up the oils and mechanicals is a good thing.
There is a risk of Strawberry milkshake but how big is that risk?
Dave
Ghia
Vanagon
Beetle
DuncanS
DuncanS is offline
PostPosted: Mon Sep 13, 2021 5:39 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
A gillion years ago, my company bought:
It came with a 6 cylinder flathead Hercules motor? which didn't have enough power for a full load of crazies and Vermont hills. We tossed in a something bigger with an auto tranny. Blew through a couple of trannies and then installed a cooler. No more issues.
Duncan
P.S. Ours was yellow, but came with maroon fenders and stripes. Very classy. Wish it were still around.
djkeev
djkeev is offline
PostPosted: Mon Sep 13, 2021 6:20 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
In case you’ve been wondering why I’ve been obsessed over fixing leaks!
Dave
Ghia
Vanagon
Beetle
DuncanS
DuncanS is offline
PostPosted: Mon Sep 13, 2021 7:37 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Do you not need license plates for the front in Pennsy? Something otta go there.
djkeev
djkeev is offline
PostPosted: Mon Sep 13, 2021 3:27 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
No........ Pa is rear plate only.
My front bumper needs work I know.
It is on the short list before Cold settles in....... but so are 29 other projects.
Firewood may trump them all!
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Tue Sep 14, 2021 1:24 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Crap crap crap crap crap CRAP!
(Auto trans to Differential leaking)
But I have a plan..........
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Wed Sep 15, 2021 4:33 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Cleaned up...... again.....
Repairs made ...... again ......
Repair cured over night ........
Now for a nice "high speed" drive to see if it stays dry.
It's kinda "Rube Goldberg" but if it works, is it yet another Duncanization?
Fingers crossed.
I have a spare transaxle I hope to rebuild over the Winter. I just want to stop dripping oil wherever I park right now.
Dave
Ghia
Vanagon
Beetle
Abscate
Abscate is offline
PostPosted: Wed Sep 15, 2021 4:45 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Dave..a drywall mixing tub from Lowe’s will slide right under there, and costs $6
If you get rainwater in it, just add 50 ml of gas, touch it off to burn the HC, then dump the residual in a safe place away from a well
.ssS!
DuncanS
DuncanS is offline
PostPosted: Wed Sep 15, 2021 5:30 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
If you light off the mixing tub with the gas in it while still under the car, then you won't have to worry about the leaking tranny.
djkeev
djkeev is offline
PostPosted: Thu Sep 16, 2021 4:57 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
I could write a Children's book ...... "The Big Messy Dripping Engine"
It would be about drive train leaks and the adventures and frustrations of finding them and fixing them.
It wasn't a long ride Yesterday but we are still dripping!
Absolutely isolated to the dipstick tube fitting!
Will it never end?!?
Dave
Ghia
Vanagon
Beetle
dabaron
dabaron is offline
PostPosted: Thu Sep 16, 2021 7:13 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
if he waits until it gets cold outside he won't even need fire wood. a win-win if you ask me Cool
as for Dave's leak, i have been frustrated by a leaking crank seal at the pulley end so i totally empathize with him.
Vanagons.
BiWerks Design, LLC
djkeev
djkeev is offline
PostPosted: Thu Sep 16, 2021 12:15 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
So I just dropped the ATF again.
Simply pulled the dipstick tube and let it drain for an hour or so.
Goobbered up any sealing surfaces with Hylomar and reassembled.
3 quarts ATF added back in.
Tomorrow is a Jersey run, if it is going to leak, this will
Reveal it fairly quickly.
I’ll check the level after it warms up on the way tomorrow.
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Fri Sep 17, 2021 3:44 pm    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
Welcome home from NJ!
200 miles, and a Van full of used Vanagon Parts.
I stopped on the way and added about 6 oz of ATF, just a smidge over half way between the dots now.
On the way home I stopped at Huff’s Church and used their empty parking lot as a check up place.
I crawled under with a flashlight and saw a dry dipstick tube and a dry oil pan!!!!
Cue Charlie Brown’s Snoopy happy dance music!
https://m.youtube.com/watch?v=_gRpyAGCsiw
Dave
Ghia
Vanagon
Beetle
djkeev
djkeev is offline
PostPosted: Sat Sep 18, 2021 4:50 am    Post subject: Re: HERE WE GO!! .... 1990 Tintop! Reply with quote
I’m thinking I might do some bumper and cladding repair this weekend….. mild temps, dry….. it will make a huge 20’ visual difference!
Ghia
Vanagon
Beetle
Page 40 of 83
