Rhino1966 Samba Member
Posted: Fri Sep 17, 2021 9:20 pm Post subject: Cooling Tin Flaps |
Just found out that my Type 4 motor does not have the flaps that go on each side of the cooling tin. How important is this on cooling the motor? I am not running any heater boxes and do not have any heat or defrosters. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12709 Location: Western Canada
Posted: Sat Sep 18, 2021 5:43 am Post subject: Re: Cooling Tin Flaps |
It makes no difference on cooling the engine down but it makes a big difference on getting it to warm up properly, stay warm enough, hold a tune and to the lifespan of the engine. The thermostat and flaps have nothing to do with heat and defrost and everything to do with keeping the engine at the correct temperature under changing load and weather conditions. Any effects on the heating system are incidental, not intentional.
Find all the correct parts and adjust them properly. Your engine will thank you by running better and lasting longer. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Sat Sep 18, 2021 6:04 am Post subject: Re: Cooling Tin Flaps |
You will also need a 85-90C thermostat, pulley, and cable to open and close the flaps. I believe you can still get the thermostats new from Awesome Powder Coat. |
gt1953 Samba Member
Posted: Sat Sep 18, 2021 7:56 am Post subject: Re: Cooling Tin Flaps |
I see you are in Arizona....even in the desert your engine would benefit from having those installed. Start sourcing out parts. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
jsturtlebuggy Samba Member
Posted: Sat Sep 18, 2021 8:14 am Post subject: Re: Cooling Tin Flaps |
The flap on the left side is very important to have as it directs air flow to the oil cooler. Without it being there air will flow will cross over top of oil cooler and and not down through it.
Hopefully you have the tin in place that sits on top of and under lip of fan housing. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
oprn Samba Member
Posted: Sat Sep 18, 2021 10:20 am Post subject: Re: Cooling Tin Flaps |
I forgot about the oil cooler on the type 4, yes that is so! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Sep 18, 2021 1:06 pm Post subject: Re: Cooling Tin Flaps |
jsturtlebuggy wrote: |
Hopefully you have the tin in place that sits on top of and under lip of fan housing. |
Exactly. It might be worth tracking down a stock setup. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Sat Sep 18, 2021 2:03 pm Post subject: Re: Cooling Tin Flaps |
This!! _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
