PWB Samba Member
Posted: Wed Sep 15, 2021 12:46 pm Post subject: EMPI Mini Sump w/ filter kit 17-2872 |
Does anybody have any experience with this kit? Thinking about getting one, but was wondering how effective it is and/or if it is worth installing:
The other "full-flow" style kits are pretty common, but I don't believe they fit with a stock exhaust? (which I enjoy having). I don't feel like drilling extra holes for a remoted filter system either.
I just use my car gently on the weekends. Nothing high performance.
Just want to provide any useful extra protection that I can to help of give my engine the longest life possible.
Thanks. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Sep 15, 2021 1:56 pm Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
Wasting your money...just change your oil every few months and don’t worry about it. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Wed Sep 15, 2021 2:47 pm Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
I'd put my $$$ into a combination pump/filter unit like CB Maxi2. I have those on both my VWs, the first for 4 decades now.....
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Wed Sep 15, 2021 3:14 pm Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
Cusser wrote: |
This won't work with a left side heat riser muffler.
It will with a right side heat riser muffler. Buy They're hard to find! And very expensive. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
EVfun Samba Member
Posted: Wed Sep 15, 2021 3:57 pm Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
I installed that kit in my first buggy, back in the early '90's. It worked just fine. It has a relief valve in the bottom so I don't see why it would be any more risky than a filter after the pump. There is even a motorcycle paper filter element that you can get at your FLAPS instead of using a cleanable stainless filter (that's how it came back in the '90's.)
With the cleanable stainless filter they have now it seems mostly like an improved version of the stock strainer. I may consider it for my current buggy. _________________
Wildthings wrote: |
txoval Samba Member
Posted: Wed Sep 15, 2021 6:43 pm Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
You can definitely run it, but for his low use vehicle, the stock setup will work just fine for a long time |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Thu Sep 16, 2021 5:59 am Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
EVfun wrote: |
With the cleanable stainless filter they have now it seems mostly like an improved version of the stock strainer. I may consider it for my current buggy. |
I have never seen this before and was thinking the restriction on start up with cold oil could be a problem. Then I saw the the relief valve. I personally would try it on an engine I couldn't or didn't have tapped for full flow. The Bus and type 3 come to mind where the mustache bar is in the way. It has to be better than the stock screen and it does protect your oil pump where a conventional full flow filter does not do.
These comments are made assuming that a temperature appropriate oil weight is being used. All those stuck on using road tar for oil, this would not apply! _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
slayer61 Samba Member
Posted: Thu Sep 16, 2021 7:27 am Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
I think if I was a pump, I would rather have a restriction on my discharge rather than on my suction side. It would keep me happier. |
EVfun Samba Member
Posted: Thu Sep 16, 2021 2:07 pm Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
Thought bubble...
I would only use this with a late style pickup tube that is bolted to the bottom of the engine. The spring on the bottom that compresses and seals the stack isn't stiff but I think the pickup should be supported with any spring tension against it. My old buggy engine was a DP engine. _________________
Wildthings wrote: |
frenchroast Samba Member
Posted: Sat Sep 18, 2021 7:03 am Post subject: Re: EMPI Mini Sump w/ filter kit 17-2872 |
If you're just puttin around town and generally kind to your motor, use a good quality high zinc sae 30 oil and change it every 1k. That's it. You can easily get 125k+ out of the bottom end of the motor this way. |
