Paulinpa Samba Member
Posted: Fri Sep 17, 2021 5:11 pm Post subject: Going CRAZY pulley size |
Ok bought a stock belt ref: my last post too freakin big the only missing part is ….could the crank pulley be small ? Pan on buggy was a 1965 and the guy I bought it from bought a crate engine
If he used a 1965 pulley is it smaller diameter? This is nuts |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Fri Sep 17, 2021 8:27 pm Post subject: Re: Going CRAZY pulley size |
WAT _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Sep 18, 2021 3:10 am Post subject: Re: Going CRAZY pulley size |
Maybe a "Power Pulley" ? got a pic? or a Tape measure? _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Sat Sep 18, 2021 7:49 am Post subject: Re: Going CRAZY pulley size |
Appears OP is asking if the crank pulley of a 6 V engine, either a 1200 cc 40 hp or a 1300 cc 50 hp has a smaller diameter than that of the 12 V engines (1500 cc+). And I think they are smaller- not much- maybe 1/4" diameter. I don't think I have a 6 V pulley in basement to measure.
Paulinpa- if you measure the diameter of your current "small" pulley, I'll measure the diameter of a 12 V engine'd pulley which I do have. 6 V pulley should be around 6 1/2"; 12 V about 6 3/4" " or 7". A power pulley is much smaller, approx. 5 3/4". |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
