legotech7 Samba Member
Joined: May 09, 2009 Posts: 879 Location: North Carolina
Posted: Wed Oct 14, 2020 8:33 am Post subject: New MC. Hard Brake Peddle |
I recently replaced a single circuit MC whit a dual circuit one. I replaced all the brake shoes, wheel cylinders, hardware and the rubber hoses. I bled the brakes using a power bleeder. Easy bleeding. But I push the brake peddle and it barely moves. Perhaps maybe an inch or so. I raise the car up on jacks and the wheel are very tight, maybe a half rotation. Has anyone run into this? And what might remedy this? I've done brakes before on VW"s.. never a problem, so I'm somewhat perplexed with this one.. Any help is very much appreciated. Oh ,.. almost forgot....I have no brake lights as well. I might have wired them wrong. Any diagram on how to wire dual circuit?.. Thanks again.... |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 849 Location: South Florida
Posted: Wed Oct 14, 2020 8:59 am Post subject: Re: New MC. Hard Brake Peddle |
Did you try backing off brake shoe adjusters? |
jspbtown Samba Member
Posted: Wed Oct 14, 2020 10:29 am Post subject: Re: New MC. Hard Brake Peddle |
Switches for the brake lights is just power in and power out. You can just wire one switch and leave the other unwired as a spare for when the first one fails. |
rayjay Samba Member
Joined: March 26, 2008 Posts: 1501 Location: Buford GA
Posted: Wed Oct 14, 2020 12:10 pm Post subject: Re: New MC. Hard Brake Peddle |
Make sure the pushrod has a small amount of clearance when the brake pedal is fully released and against the stop. Could also have the brakes adjusted too close to the drum. |
Posted: Wed Oct 14, 2020 12:27 pm Post subject: Re: New MC. Hard Brake Peddle |
The brake shoes are all backed off. The wheels are hard to rotate. I did notice that I had a hard time putting back the drums, but they could still move. I will check the push rod, might have to readjust it. ?...... Thanks all.. |
7sam7 Samba Member
Joined: June 19, 2020 Posts: 35 Location: Southern Washington
Posted: Wed Oct 14, 2020 4:25 pm Post subject: Re: New MC. Hard Brake Peddle |
Quote: |
The brake shoes are all backed off. |
Are you very very very sure?
Two star wheels per wheel right? Tighten both shoes until they are firm against the drum. Then back off each little star wheel the same amount of clicks. |
Posted: Wed Oct 14, 2020 4:34 pm Post subject: Re: New MC. Hard Brake Peddle |
Well I had some time this evening. I got the wiring done , wala.. The brake lights work, But still brake peddle to hard . I lifted up the front of the buggy. and checked the driver side wheel. Wouldn't budge. ,passenger side turned one and a half revolutions. Guessing the back ones might be the same. Guess I know what I'm doing this week end.!....Hopefully...I'll readjust them, then check the peddle rod...Fun...... |
Posted: Wed Oct 14, 2020 5:12 pm Post subject: Re: New MC. Hard Brake Peddle |
Check whether shoes are oriented correctly. One end goes in wheel cylinder piston; other end is angled and goes in adjuster screw head slot, which also is angled. Be sure it's angled to urge shoe toward cylinder. |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1102 Location: North East Pennsylvania
didget69 Samba Member
Joined: July 22, 2004 Posts: 4925 Location: Raleigh, North Carolina
Posted: Thu Oct 15, 2020 8:41 am Post subject: Re: New MC. Hard Brake Peddle |
legotech7 wrote: |
You'd do well to invest in a repair manual.
You always adjust the drums before bleeding.
And set pedal travel & pushrod clearance between MC & pedal...
B _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Thu Oct 15, 2020 9:04 am Post subject: Re: New MC. Hard Brake Peddle |
Didn't adjust the free play yet, but I was talking to VW vendor here by me, he's says sometimes when you introduce air into the lines after MC install you might get whats called hydrolic lock. He's sometimes you might have to just open one of the brake valves , if you will,...and let some of that pressure out. Might have to do it to all valves,to see if the might make a difference.. Then readjust the brakes, then if need be readjust the push rod. Can't today but this week end.. to be continued... |
rayjay Samba Member
Posted: Thu Oct 15, 2020 5:50 pm Post subject: Re: New MC. Hard Brake Peddle |
legotech7 wrote: |
Umm... No.
Your VW vendor is incorrect.
Posted: Fri Oct 16, 2020 10:31 am Post subject: Re: New MC. Hard Brake Peddle |
Will be working on the brakes next week, I'll post what I find. This Sunday is the VW show in Farmington NC. I'll be there. You all are welcome to come as well, if your near by... |
Posted: Sat Sep 18, 2021 12:07 pm Post subject: Re: New MC. Hard Brake Peddle |
I know this is an older thread, but I'm having the same issue I had on my last post. A hard brake peddle when depressed but no brakes. And the brake peddle bounces back, or peddle to far forward towards the rear of the buggy. I purchased a new MC rod for some where on ebay, and I suspect it may be to long. Are there different lengths of these pushrods for different years of bugs? I thought I had this fixed, but the buggy has been sitting around for a few months while I took care of other issues with it. Got those done, now this again. Never ends. Any other input would be greatly appreciated.....
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Sep 18, 2021 12:58 pm Post subject: Re: New MC. Hard Brake Peddle |
Hard pedal and no free play at drum's (drum's should rotate freely with only slight whisper of contact) usually indicate free play in pedal not set correctly and "lock up" of brakes and MC are because port(s) from MC to reservoir is blocked..
Would be ports 1 & 2 in bottom of sketch...
_________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8687 Location: Sunset, Louisiana
If the drums were hard to get on, you have a problem. Pull the drums and check that the adjusters are installed correctly. With the adjusters backed off the drums should spin freely.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
