67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Sep 18, 2021 7:26 am Post subject: Re: Oil leaking from inside tire area and tire angle |
Robert,
Have you read through this thread on Mexi Beetles?
https://www.thesamba.com/vw/forum/viewtopic.php?t=583972
Also, Hopkin seems to be the resident expert on these cars.
Antonio Trejo sells part for Mexi Beetles too. He may be able to lend a little knowledge to ya.
https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=14183
Regarding the valve cover gasket. I am under the impression that they are not any different than a standard 1600cc engine valve cover. I could be wrong in this thought.
Any mainline auto parts store, should be able to order a gasket set for your engine.
Don't the Mexi Beetle engines, have hydraulic lifters? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
robertsfd2002 Samba Member
Posted: Sat Sep 18, 2021 11:40 am Post subject: Re: Oil leaking from inside tire area and tire angle |
Here's a picture of the cover with the gasket I bought. At the widest point, the cover is 9 and 7/8 inches.
Thanks for the other thoughts/tips/links.
vamram Samba Member
Posted: Sat Sep 18, 2021 1:01 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Can you post a picture of the head that belongs to that valve cover? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
AutoMechanic Samba Member
Joined: December 28, 2019 Posts: 483 Location: Roanoke Virginia
Posted: Sat Sep 18, 2021 1:24 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Gear and hub oil smells like onions it’s gross lol. Worst stuff ever to try to get the smell off your hands so don’t get it on your hands. |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3855 Location: San Jose, CA
Posted: Sat Sep 18, 2021 2:40 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
robertsfd2002 wrote: |
That looks like a super early gasket, like 25 hp, or 36 hp. Is there any chance you clicked and ordered the wrong ones? The lower corner radii are too tight on that gasket to boot. You need good ol' 1600 gaskets.
(Yes, I know I said all the gaskets were the same earlier...but 36hp?) |
Posted: Sat Sep 18, 2021 3:23 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
Here is the valve box:
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Sep 18, 2021 6:10 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
36 hp gasket...probably just sent you the wrong ones |
Posted: Sun Sep 19, 2021 7:59 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
How do I determine what I need? JBugs has these:
valve cover gaskets are used on 1200cc 40 Horse through 1600cc Type 1, 2 & 3 engines as well as Vanagon watercooled 1.9 & 2.1 Liter engines. The valve cover gaskets fit 1961 through 1977 Beetles
OR
valve cover gaskets are used on 25 and 36 Horse engines. The valve cover gaskets fits 1954 through 1960 Beetles
I was told the 84 Mexican bug was essentially the same as the 1969 bug, which would suggest the first item description, but then you're suggesting it is a 36hp so this suggest the second item description.
Any idea which I should try? |
Posted: Sun Sep 19, 2021 8:02 pm Post subject: Re: Oil leaking from inside tire area and tire angle |
No, no, we're saying you got 36 HP gaskets, you want the later 40-horse thru 1600 gaskets. Yes, order some for a 1969. (Or 70, or 71, or 65, or 62...you get the picture ) |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Mon Sep 20, 2021 5:06 am Post subject: Re: Oil leaking from inside tire area and tire angle |
as the others said, that's an early gasket you have. BTW a 1984 mexican bug's engine for the internal mexican market in its original spec has no fuel injection nor hydraulic lifters, and it is in most respects similar or the same as a late (pre-FI) german 1600. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
Posted: Mon Sep 20, 2021 6:13 am Post subject: Re: Oil leaking from inside tire area and tire angle |
I got it. Thank you everyone. Very helpful for a slow guy like me. |
