lamasoup Samba Member
Joined: September 16, 2021 Posts: 2 Location: Denver, CO
Posted: Sun Sep 19, 2021 10:36 am Post subject: The hunt for a 15" steel wheel... |
Apologies if this has been covered exhaustively in another topic... I realize there's at least one other thread about wheel options
Is there a recommendation for a 15" steel wheel that isn't the current GoWesty offering that are strong, bolt on with little modification, and will fit a bigger brake kit?
The idea of Chinese made rims (current GoWesty offering) brings me pause.
Missed the boat on the last of the Mefro's, though from what I understand they don't fit a bigger brake kit without extensive caliper grinding.
I know there's a vast offering of alloy options, though none are really doing it for me besides the SA Starburst (which are near impossible to get these days).
Thanks so much! |
RGS Paul Samba Member
Joined: April 20, 2007 Posts: 663 Location: Los Alamos, NM
Posted: Sun Sep 19, 2021 11:24 am Post subject: Re: The hunt for a 15" steel wheel... |
VW Buli Parts in Germany sells the Merfo 15” and 16” steel wheels. I’ve had good luck shipping with them, it’s slow but not heinously expensive. That’s where I ordered my stainless exhaust.
https://www.vwbulliparts.de/en/brake-wheels/rims-fastening-material/
Paul _________________ '87 Syncro 7-Pass. Adventure Touring Vehicle
"Simplicate, then add lightness." Colin Chapman |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
connorsvw2 Samba Member
Joined: August 16, 2008 Posts: 347 Location: Denver, CO
Posted: Mon Sep 20, 2021 9:36 am Post subject: Re: The hunt for a 15" steel wheel... |
Don't know about the big brake question, but my current go-to is the Passat steel 15x6 ET37 wheels from ECS tuning. OEM VW, $69 + free shipping. A Diablo carbide 67 mm hole saw and you are good to go. _________________ '85 Westy Wolfsburg camper/2002 2.5 Subaru since 2003.
'85 GTI 1.8L 1-owner 8v-gave up on 9A 2.0L 16v transplant. Keeping her stock!
'99 Passat 1.8T Variant-AKA "The Money Pit". Still limping along...
'09 Subaru Outback XT 5-speed, 245 hp rocket (wife's car) |
danfromsyr Samba Member
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Mon Sep 20, 2021 8:48 pm Post subject: Re: The hunt for a 15" steel wheel... |
connorsvw2 wrote: |
Don't know about the big brake question, but my current go-to is the Passat steel 15x6 ET37 wheels from ECS tuning. OEM VW, $69 + free shipping. A Diablo carbide 67 mm hole saw and you are good to go. |
this is the correct answer.
these wheels can be had dirt cheap if you are resourceful. they require no spacers and fit factory hubcaps or lug covers and certain big brake/rear disc kits AND fit in the clamshell!!
it should be noted that they do require "late model" (17mm--M14x1.5) lug bolts that are "small ball" seat that are also readily available. not so much for the matching nuts that can be had through T3 technique. get some bespoke ball joints while you're there! _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
clift_d Samba Member
Joined: December 02, 2012 Posts: 265 Location: Hackney innit, UK
Posted: Tue Sep 21, 2021 12:01 am Post subject: Re: The hunt for a 15" steel wheel... |
Whether your big brakes fit will depend on the kit - I'm aware that some of the big brake conversions are recommended for use only with a 16" wheel. You'd be advised to check compatability before you click 'Buy' for either the wheels or brakes. _________________ 1988 LHD T25 1.6TD Westfalia Club Joker syncro |
tjet Samba Member
Posted: Tue Sep 21, 2021 11:50 am Post subject: Re: The hunt for a 15" steel wheel... |
Thats a great deal for some rare, no longer made, extreme duty rims |
