1976 Bus Powered by EZ36 Subaru Motor and 6 Speed Trans
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 30, 31, 32  Next
scirocco_crazy
scirocco_crazy is offline
PostPosted: Sun Sep 19, 2021 8:44 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
scirocco_crazy wrote:
Cleaned the shop today and put all the tools away. I did a test patch with 1000 grit to start and finish with 2000, I think the peel will cut down pretty easily. I do need to get foam pad for the DA to help keep it from cutting too fast though. That will have to wait till next weekend. My plan is to start organizing all the parts to install over the next couple of nights. So many boxes!
Current Build 1976 VW Bus Subaru with EZ36 https://www.thesamba.com/vw/forum/viewtopic.php?p=9443081#9443081
Second Current Build 1979 Porsche 911SC
https://www.thesamba.com/vw/forum/viewtopic.php?p=10117349#10117349
Previous Builds 78 Westy with matching trailer
http://www.thesamba.com/vw/forum/viewtopic.php?t=589790&highlight=westy
78 Bay with Acura 3.2 Type S engine
http://www.thesamba.com/vw/forum/viewtopic.php?t=516038&postdays=0&postorder=asc&start=0
vwwestyman
vwwestyman is offline
PostPosted: Sun Sep 19, 2021 8:51 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
I'll admit I was skeptical before, but I really like the color combo when looking at them together on the Bus!
Dave Cook
1973 Wild Westerner
My Thing
deathman68
deathman68 is offline
PostPosted: Mon Sep 20, 2021 9:00 am    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Congrats on the paint. Looks really fantastic! Now the best/most rewarding part begins...
1973 Riviera “Annie”
Build Thread: 1973 Riviera+Subaru 2.5+5 Speed
EJ25+5 Speed Conversion Part/Cost Tracker
scirocco_crazy
PostPosted: Mon Sep 20, 2021 5:56 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
If you like the green color I used, here is the paint code. Keep in mind Olive Drab Green doesn't cross reference so this is the closest I could match.
scirocco_crazy
PostPosted: Fri Sep 24, 2021 6:15 am    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Last night I spent two hour just on the drivers door wet sanding and buffing. I am super happy with the finish, it has just enough peel to help with imperfections that will happen during camping. For those of you doing the same, I started with 1000 grit, then 1500, and final with 2000. Then a combo wool pad and cutting compound at about 1500 rpm, and finaly with foam pad with polishing compound. Now on to the rest of the bus. At two hours just for one door I figure this will take about 20 hours to complete.At least then I can move on to assembly easier.
scirocco_crazy
PostPosted: Fri Sep 24, 2021 11:35 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
more and more sanding and buffing, I will admit the more it do it the better the results are getting. I also started adding the sound deadening later in the night. I try to shut the compressor off if it gets to late. You all know what I am talking about. Neighbors can only handle so much of the rattling.
The previous owner had bought these red seatbelts. I think I am going to run with them. Free makes them look even better
scirocco_crazy
PostPosted: Fri Sep 24, 2021 11:44 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Back to the wheel conversation from a couple of pages back. I bought the tires for the 14" rims then found that one rim was bum and the other I have no idea what it came off of. Well yesterday a really cool guy was giving this set of 15" wheels off a B5 Passat away for free. Now I need some help as to the largest size you have seen on these rims that wont rub a ton. That really nice orange one I believe is using 215 R75 15. What do you all think?
notchboy
notchboy is offline
PostPosted: Sat Sep 25, 2021 8:08 am    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
What is the offset on those 15"s?? ET??
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
scirocco_crazy
PostPosted: Sat Sep 25, 2021 3:05 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Looks like it’s a et 37
notchboy
notchboy is offline
PostPosted: Sat Sep 25, 2021 4:35 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Dude you are solid. I think the stock off set is 37 - look on one of your 14's. Its either that or 38. No biggie. You have my rims then. The center and the stud holes need to be opened.
Then with a lift kit you will be taller. Cool Laughing
1964 1500 S
scirocco_crazy
PostPosted: Sat Sep 25, 2021 10:27 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
[quote="notchboy"]Dude you are solid. I think the stock off set is 37 - look on one of your 14's. Its either that or 38. No biggie. You have my rims then. The center and the stud holes need to be opened.
This is great news, I will order the tires tomorrow and prep the wheels for Powder coating. I like the silver color, thanks for the guidance guys.
scirocco_crazy
PostPosted: Sat Sep 25, 2021 10:32 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Had a late start to the night but made pretty good progress on the bus. I was able to wet sand and buff the slider door and mount all its hardware. I also spent about 2 hours organizing all the nuts bolts and hardware. The guy I bought the two busses from had boxes of extra parts in them and a lot of items taken apart. This was a good chance to organize and inventory the parts. I seem to have double and triples of a lot of parts. I will just pick the best of them to install and sell off the extras.
Have you ever seen bolts with he VW and Audi logo on them? This is strange for the pre 79 bus
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Sep 25, 2021 10:34 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
looking good
i bet you'll have closer to 50 hours doing a cut and buff if you plan on doing the roof.
when i did the deluxe we did a 100 mph cut and buff then did it again after it was built. no need to do it that way but no matter what you'll have some scrapes putting it together.
i can appreciate the work put it. every fucking inch of it sucks. first chip hurts the most too
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
scirocco_crazy
PostPosted: Sun Sep 26, 2021 9:49 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
skills@eurocarsplus wrote:
looking good
Without a doubt, 50 hours might even be a bit light. I did almost three hours just on the rear hatch tonight. Tomorrow I am going to venture on the front end. Pray I don't break through the clear on all those edges. I have left the bottom 6-8 inches with the peel on purpose to give a textured look though.
scirocco_crazy
PostPosted: Sun Sep 26, 2021 9:54 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Got the Rear hatch cut and buffed, and installed. I also made a tool for installing the rear hatch springs. I fought these before and I figured there had to be a better way. I just ground away on this bar until it fit the spring, easy peasy after that. Before with a prybar I was taking my life in my hands the many times it slipped and un sprung.
scirocco_crazy
PostPosted: Tue Sep 28, 2021 11:27 am    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Im going to stop stating more wet sanding and buffing and just show the end results. On a much much more fun area I was able to lay down a ton (about 50lbs) of sound deadening. I need to order the insulation portion now for the next step. This will both insulate and work on absorbing road noise.
vwwestyman
PostPosted: Tue Sep 28, 2021 7:13 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
You may have posted before and I simply forgot, but what are the tabs for that are between the front seat pedestals?
Dave Cook
1973 Wild Westerner
My Thing
panel
panel is offline
PostPosted: Tue Sep 28, 2021 7:45 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Getting excited to watch the mechanical part of this build !
My '65-Subaru EJ20 Turbo conversion
scirocco_crazy
PostPosted: Tue Sep 28, 2021 8:13 pm    Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline Reply with quote
Those tabs will allow a panel to be mounted for the shifter and house the AC/Heater unit. I will have to cut some of the floor out to fit the Subaru unit but that will be another day. The plan is to connect into the existing pipe to the front vents and install rear vents at the back of the enclosure. There is also a rear air unit for under the Z-bed. These units were harvested from the Tribeca donor. I just figured better to weld in the tabs prior to paint.
scirocco_crazy
That my favorite part also
Page 7 of 32
