Jay Pearson Samba Member
Joined: September 26, 2004 Posts: 128 Location: Reno, NV
Posted: Thu Sep 16, 2021 7:14 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
wcfvw69, Bill I see your distributor restorations here on the Samba, great work!
Should I ever have an issue with the 205Q I will get in touch definitely.
After a check of the fuel lines & brakes and seeing no red flags.
I took the Bus out for a 10 mile drive early on Sunday around the neighborhood when the roads were empty.
Very pleased! It runs like a top- shifts smoothly, clutch has no slippage or chatter, brakes nicely, idles and accelerates without any noticeable issues. The Horn even works!
Big smile the rest of the day |
TrollFromDownBelow Samba Member
Joined: January 04, 2005 Posts: 414 Location: Metro Detroit
Posted: Thu Sep 16, 2021 1:25 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Jay Pearson wrote: |
But does the rear defroster work? That will be the true litmus test whether it is a bona fide 30k original mile bus. _________________ 1976 Westy (aka Tripod)
2.0 liter FI solid lifters
212k miles |
Abscate Samba Member
Posted: Thu Sep 16, 2021 4:57 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Hmmm. Look at that nice 1971 four bolt apron….😎 _________________ .ssS! |
SGKent Samba Member
Posted: Thu Sep 16, 2021 5:49 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Abscate wrote: |
Hmmm. Look at that nice 1971 four bolt apron….😎 |
my 1971 VIN 2212225009 was a two bolt apron. There is some question as to what vin that changed _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
vwmerckx Samba Member
Joined: August 12, 2012 Posts: 195 Location: Phoenix, AZ
Posted: Thu Sep 16, 2021 6:00 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
My 71 (12/1970) is a two-bolt apron |
Posted: Fri Sep 17, 2021 5:03 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Carburetor rebuilt and back in with a little clean up of the fuel pump and air intake tube. Put in new plugs at the time as well went with the NGK BP5HS fired right up, will get it on the tach, dwell and timing light tomorrow after a drive around warmup.
Silly question but is any one refreshing the German Bosch WR8 & 7's even just for posterity pieces. Hesitating on throwing them out.
Stumbled onto a new cleanup "tool" the magic sponge, great for getting into tight spots, removes grunge without scratching up or giving the over done look.
As in the famous Seinfeld episode it was Sponge Worthy!
Sunday will be big smile day again I can feel it
Take Care!
Posted: Sun Sep 19, 2021 7:31 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Well on Saturday I thought I would do an easy clean up of the middle and back seat. I soon realized a "super sized" coke had been spilled on the floor at some time in the past and put a coke layer under the floor mat in the passenger area.
Took six plus hours to "uncoke" the floor. Cleaned up nicely after using multiple cleaning products and a lot of time.
Net net floor looks like it should and will stay that way. No eating in the car going forward.
Take Care!
Posted: Sun Sep 19, 2021 7:37 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Looks factory !! |
SGKent Samba Member
Posted: Sun Sep 19, 2021 8:07 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
glue that one strip back on. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jason1 Samba Member
Posted: Mon Sep 20, 2021 4:49 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
This is a great thread. What a treasure this bus is!
Not sure if it's been covered back when you posted the tires pic...
Old tires are dangerous. they get hard and even though you can have all the original tread, the sidewall even if not cracked the thing can just shred on you on the highway.
I replaced my "perfect" 15 year old tires and the difference is amazing (quieter, track better, easier to turn) and peace of mind to boot. |
Posted: Mon Sep 20, 2021 7:56 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Jason1, picked up new tires today.
Went with the Hankook Kinergy 205/70 /R14.
Plan is to get the wheels to the media blaster and powder coated then new tires mounted.
The 1996 tires have less than 1000 miles on them but are not worth risking it on.
Will keep them around as they are part of what confirms the actual miles on the Bus.
Take Care! |
richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Mon Sep 20, 2021 8:33 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
If you’re set on keeping it stock, why would you buy the wrong tires? The Kinergy 205/70r14 are passenger car tires. The bus is going to handle poorly and will have terrible wind wag. The correct tire to buy would be the Hankook Vantra 185r14c and if you wanted to go bigger the Vantra 195r14c is the next size up. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 20, 2021 8:49 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
richparker wrote: |
If you’re set on keeping it stock, why would you buy the wrong tires? The Kinergy 205/70r14 are passenger car tires. The bus is going to handle poorly and will have terrible wind wag. The correct tire to buy would be the Hankook Vantra 185r14c and if you wanted to go bigger the Vantra 195r14c is the next size up. |
Agreed, that's going to feel mushy to drive. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Sep 21, 2021 5:59 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Rich & Bus Daddy, thank you for the input. I don't want to put the wrong tires on the Bus.
I got these based on size and load capacity, many 185 & 195 tires I viewed did not meet the load capacity.
Are you referring to the Vantra LT tire from Hankook?, looking for it on their website and via a large national tire chain, it does not show it available in a 185 to 205 size at this time.
Appreciate additional input, no new tires have been mounted yet.
Take Care! |
Posted: Tue Sep 21, 2021 6:16 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Rich & Bus Daddy
Further searching shows the Vantra LT is out there in a 185 and 195, may have a little delay in getting them.
Is this the tire you recommend based on your experience?
Take Care! |
71whitewesty Samba Member
Joined: February 25, 2010 Posts: 1544 Location: oregon
Posted: Tue Sep 21, 2021 6:40 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
I have the hankook vantras on both of my westys and recommend them highly. I’ve used them in every condition you can imagine. I’ve probably put 100k on them altogether and never had a flat except for a set that the valve stems failed. 3 failed in a matter of a couple months and then I caught the 4th one just before it failed. The centrifugal force split then right at the rim. _________________ 71 Westy 1600 DP, all stock Bus 1
1970's Snow Trac 1600 SP (sold 12/2016)
1968 Tucker sno cat, sold 2021
1969 Tucker Sno cat 542
2017 VW Alltrac
71 tin top stock 1600 DP (project but runs)
Twin 71 White Westy, Bus 2, that I pulled from a 15 year slumber in a dry eastern WA field in 2015.
1966 Sundial Camper "Boomer" |
Posted: Tue Sep 21, 2021 6:52 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Rich & Bus Daddy
Take Care! |
Yes, they are great tires. Everyone has there own ideas on pressure, but I ran mine at 35 PSI. Some like 40 in the rear, but I never had issues at 35. I could be mistaken but I think the 185 has a diameter of 25.5” and the 195 is 26.5”.
I have found many good deals on eBay.
https://www.ebay.com/itm/4-195R14-Hankook-Vantra-L...632-2357-0 _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Tue Sep 21, 2021 7:51 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Thanks for the recommendation's, will look to return and replace with the Vantra's.
One reason I started and continue the posting is to get experienced input and feed back as I go along.
Take Care! |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Tue Sep 21, 2021 6:11 pm Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
I can give two thumbs up on the Vantras too. <--...or two pointy fingers...
Just had the second set installed last month, and the first set lasted close to 65k miles.
That's much better than what I would get with my SUV. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Xevin Samba Member
Posted: Wed Sep 22, 2021 2:06 am Post subject: Re: 1971 Bay "time capsule" 32,000 og miles |
Another option with a good track record in the Vanagon world is:
Yokohama SuperVan 356
Y356 LT185R14 8 Ply Rating
Load Range D 1850 lbs @ 65psi cold
They’d be nice on a bus too.
Full disclosure I run Hankooks on the 72 Campmobile (RA08) and 85 Westy (Vantras) They’ve treated me well for my driving needs. I also run the recommended air pressure VW suggests on both cars.
Xevin wrote: |
After all my research on tires. I decided to stay stock size for an 85 1.9wbx. I did put VW alloys on it
If stock was good for the PO and 200,000 miles. Its good enough for me. I don’t do snow in the PNW since they started salting roads a couple years ago. What I need is good grip in rain on hilly freeways and fire road traction.
I went Hankook 185/14” skateboard wheels I’ve put 300 miles on them. For windy wet freeways. I dig them.
Xevin wrote: |
So Dave, with you in mind. I took the Van on an off road tour to see how the Hankooks would do on some slippery stuff when I go camping. This should be all I need. Your requirements may be different.
And some wet muddy grass. I had no problems.
What I couldn’t take a picture of is the steep off camber descent on the back side of this loop. It made my butt pucker but the van was sure footed and confident. The tires meet my needs. Hope this helps.
Look, dirt! Like some of the big boys
I’ve got 4K miles on these now. The tires still handle my off road needs and daily driving conditions just fine. I live in hilly, wet, traffic of Portland,OR. I’m sure the Hankooks will be just fine for you. But I wouldn’t hesitate to buy the Yokohama’s at a good price either. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
