Tie Rod Tool?
Big Bill
Big Bill is offline
PostPosted: Wed Sep 22, 2021 10:02 am    Post subject: Tie Rod Tool? Reply with quote
Does anyone have a suggestion for a Tie Rod removal tool? I have seen a few on Amazon, OTC branded but not sure if they will work on our bugs. It looks like there are 2 or 3 different styles to choose from , any info would be great. I have used a Pickle Fork before but would like to have the correct tool for this job, going to try and change them without removing the fuel tank. Thank You.
Erik G
Erik G is offline
PostPosted: Wed Sep 22, 2021 11:41 am    Post subject: Re: Tie Rod Tool? Reply with quote
I just bought this type. works for ball joints and tie rods
my advance auto had it, harbor freight has similar. they work great
https://shop.advanceautoparts.com/p/performance-tool-ball-joint-separator-w83022/11931903-p
Big Bill
Big Bill is offline
PostPosted: Wed Sep 22, 2021 1:28 pm    Post subject: Re: Tie Rod Tool? Reply with quote
Thanks Erik G I saw this type and thought it would work well on the inner tie rod ends. Smile
Cusser
Cusser is offline
PostPosted: Wed Sep 22, 2021 1:34 pm    Post subject: Re: Tie Rod Tool? Reply with quote
I just removed a tie rod end on my 1970 using this, because I own it.
https://www.harborfreight.com/tie-rod-and-pitman-a...eSEALw_wcB
PuddleRainbow
PuddleRainbow is offline
PostPosted: Wed Sep 22, 2021 1:50 pm    Post subject: Re: Tie Rod Tool? Reply with quote
+1 on the HF lever tool. Just used it last week on a tie rod end and ball joints. A bonus is the satisfying "bang" when the ball joint finally separates. $10
Pruneman99
Pruneman99 is offline
PostPosted: Wed Sep 22, 2021 1:53 pm    Post subject: Re: Tie Rod Tool? Reply with quote
Just make sure to oil the threads, or they may gaul.
Big Bill
Big Bill is offline
PostPosted: Wed Sep 22, 2021 4:01 pm    Post subject: Re: Tie Rod Tool? Reply with quote
I have a tool like the one Cusser posted. It doesnt look as Heavy Duty as his, I think it may be a Power Steering pully puller Very Happy Thanks for all of this info guys...
Cusser
Cusser is offline
PostPosted: Wed Sep 22, 2021 6:37 pm    Post subject: Re: Tie Rod Tool? Reply with quote
Mine actually came as a loaner tool from Autozone a decade or so ago. It was cheaper to keep it than actually buy one, Autozone doesn't care: you can return it any time, with receipt/online and the box.
RWK
RWK is offline
PostPosted: Thu Sep 23, 2021 5:19 am    Post subject: Re: Tie Rod Tool? Reply with quote
Take 2 ballpein hammers and hit the female side's of the joint ( what tie rod end is mounted in) simultaneously several times, it's provides enough shock and movement to the mount to loosen it, it's tapered so it generally pops up after a few tries. Have used this method on many types of ends, cars and trucks of all makes.
Its the way us home garage mechanics did it before Harbor Freight! and couldn't afford the proper tools!
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
Cusser
Cusser is offline
PostPosted: Thu Sep 23, 2021 7:30 am    Post subject: Re: Tie Rod Tool? Reply with quote
Just remember to wear safety glasses when working under the vehicle.
toxicavenger70
toxicavenger70 is offline
PostPosted: Thu Sep 23, 2021 9:46 am    Post subject: Re: Tie Rod Tool? Reply with quote
I use a floor jack to put some pressure on the bottom of the tie rod (threaded side) then pound a pickle fork in between to release it.
Big Bill
Big Bill is offline
PostPosted: Thu Sep 23, 2021 11:56 am    Post subject: Re: Tie Rod Tool? Reply with quote
Thanks for all of the info guys, I dug these out of the VW Tool box this morning. Between these 3 I should be able to get it done Smile .
vdubmyk
vdubmyk is offline
PostPosted: Thu Sep 23, 2021 12:06 pm    Post subject: Re: Tie Rod Tool? Reply with quote
I smack the knuckle with a hammer and they loosen up
64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker!
Erik G
Erik G is offline
PostPosted: Sat Sep 25, 2021 10:31 am    Post subject: Re: Tie Rod Tool? Reply with quote
the problem with most of these tools is it will rip the boot. if you are replacing the tie rod end and the boot, no big deal. but if you are just removing to do other work, you want this type. it saves the boot. actually easier touse anyways, I use this even if I don't need to save the boot
Cusser
Cusser is offline
PostPosted: Sat Sep 25, 2021 11:31 am    Post subject: Re: Tie Rod Tool? Reply with quote
I don't rip the boots with this tool.
If I didn't already have this tool, I'd likely get this type myself
Cabo9302
Cabo9302 is offline
PostPosted: Mon Sep 27, 2021 2:48 pm    Post subject: Re: Tie Rod Tool? Reply with quote
Pickle fork Laughing Laughing Laughing
Pruneman99
PostPosted: Mon Sep 27, 2021 3:38 pm    Post subject: Re: Tie Rod Tool? Reply with quote
When I was growing up, pickle fork was what I was taught to call it as well.
toxicavenger70
PostPosted: Tue Sep 28, 2021 2:21 pm    Post subject: Re: Tie Rod Tool? Reply with quote
Same
