Manfred58sc Samba Member
Posted: Sun Aug 23, 2020 8:34 am Post subject: Re: Daniel`s 66 Panel Van |
What happened to "Autocraft is the best" ? Learning the hard way. Buy KF panels or OG to finish a job.
Good to see an update _________________ Fat chick owner/operator |
3B(G) Samba Member
Joined: June 12, 2006 Posts: 37 Location: Cleebronn / Germany
Posted: Sun Aug 23, 2020 11:32 am Post subject: Re: Daniel`s 66 Panel Van |
The step from the side part must be 22mm, the AC part it is 24mm, so the side part protrudes a little from the sill. I'll make a 10cm long slot and weld it back together
There is no part that fits 100% correctly. All replica parts must be adapted. I think AC and KF are 98% correct.
_________________ greetings from Germany
Daniel
65 Panelvan
05 Multivan |
1970PAKombi Samba Member
Joined: July 10, 2019 Posts: 264 Location: Denver, PA
Posted: Mon Aug 24, 2020 11:09 am Post subject: Re: Daniel`s 66 Panel Van |
Great find and a nice panel, hope to see it finished - glad you picked it up again |
3B(G) Samba Member
Posted: Sun Sep 13, 2020 12:27 pm Post subject: Re: Daniel`s 66 Panel Van |
Hello everybody
Unfortunately I could not weld the sheets with the old electrodes for the spot welding gun. I had to buy others.
There was also the wish to have a spotter, unfortunately they are very expensive.
So I'm building one myself from old microwaves.
Daniel
65 Panelvan
05 Multivan |
LJay Samba Member
Joined: August 05, 2007 Posts: 584 Location: Arbroath,Scotland
Posted: Wed Sep 16, 2020 2:37 am Post subject: Re: Daniel`s 66 Panel Van |
Great work so far! You should’ve took an sold on the Ford transit, it’ll be rarer than the split _________________ 1962 Turkis Westfalia so34.
My build thread.
https://www.thesamba.com/vw/forum/viewtopic.php?t=742279 |
Two Glove Boxes Samba Member
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Wed Sep 16, 2020 1:44 pm Post subject: Re: Daniel`s 66 Panel Van |
How does that triangle tool work? What is the spring on the grip do? What was wrong with the spotwelder probes? |
3B(G) Samba Member
Posted: Mon Nov 16, 2020 1:07 pm Post subject: Re: Daniel`s 66 Panel Van |
I have now also received the jack mounts and adjusted them so that they fit. I will start welding at the weekend.
[/img] _________________ greetings from Germany
Daniel
65 Panelvan
05 Multivan |
ippocamp Samba Member
Joined: January 16, 2018 Posts: 20 Location: Auvergne -Rhône-Alpes FRANCE
Posted: Mon Nov 16, 2020 2:24 pm Post subject: Re: Daniel`s 66 Panel Van |
Hello Daniel
Wow, it's crazy but you'll do it, I own a '65 too, with less work to do, and seeing such a topic helps me...
Good job! _________________ ippocamp is Philippe. '79 Vanagon and '65 Bus: https://www.thesamba.com/vw/forum/viewtopic.php?t=692792 |
3B(G) Samba Member
Posted: Thu Nov 19, 2020 11:35 am Post subject: Re: Daniel`s 66 Panel Van |
ippocamp wrote: |
Hello Daniel
Good job! |
Thank you
Hello everybody,
since I only got the rear floor pan for the older model years, I have to adjust this. I cut off the corner with the large radius (190mm). I will manufacture a new sheet with the smaller radius (67.5mm) and use it, I will take extra pictures.
Daniel
65 Panelvan
05 Multivan |
3B(G) Samba Member
Posted: Thu Nov 19, 2020 11:48 am Post subject: Re: Daniel`s 66 Panel Van |
BarryL wrote: |
The triangle can be used to pull small dents out of the sheet metal. I only built this device for myself because I can't use the spot welding gun for everything. I built it according to this model:
Daniel
65 Panelvan
05 Multivan |
LowOrks Samba Member
Posted: Fri Sep 24, 2021 1:38 am Post subject: Re: Daniel`s 66 Panel Van |
Hello,
That's great! |
