Compression check numbers
Nate RS
Nate RS is offline
PostPosted: Thu Sep 23, 2021 5:14 pm    Post subject: Compression check numbers Reply with quote
Once again, VW newbie. Digging in to a ‘67 cabriolet project. Engine is a ‘68. Hadn’t run in years, filled the carb bowl with gas and started it up. Did this a few times for a total of 5? Minutes of running. Tonight (engine cold) I pulled all the plugs, propped the throttle open and did a compression test. 120,125,130,145 I’m thinking this is a close enough group and high enough to indicate good rings and valves. Only used to big block American cars though. Would you leave it alone? I’m thinking I will at the moment.
Sharp64
Sharp64 is offline
PostPosted: Thu Sep 23, 2021 6:30 pm    Post subject: Re: Compression check numbers Reply with quote
Those are good numbers. Leave it alone and send it
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu Sep 23, 2021 7:54 pm    Post subject: Re: Compression check numbers Reply with quote
Numbers look good! 145 is starting on the upper edge of not good, so keep an eye on that cylinder. Run that thing!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Nate RS
Nate RS is offline
PostPosted: Fri Sep 24, 2021 2:45 am    Post subject: Re: Compression check numbers Reply with quote
Thank You! Looking forward to NOT ripping this apart!
downsbs1
downsbs1 is offline
PostPosted: Fri Sep 24, 2021 1:33 pm    Post subject: Re: Compression check numbers Reply with quote
Laughing Laughing Laughing Laughing Laughing
