bsairhead Samba Member
Joined: October 08, 2008 Posts: 3562 Location: viroqua wi.
Posted: Thu Sep 23, 2021 11:28 am Post subject: Re: Type 2s [buses], used in advertising products & services |
What does Coors Light and sex in a canoe have in common? Both are fu--ing near water. |
Jetfxr69 Samba Member
Joined: December 28, 2018 Posts: 1293 Location: White mtns nh
Posted: Fri Sep 24, 2021 5:23 am Post subject: Re: Type 2s [buses], used in advertising products & services |
Been there and got the tshirt as they say.
Took Seamus and found about 6 other busses in the lots. Most were camping in the lot for the night. We, unfortunately had to drive home. _________________ You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. Zappa
‘77 westy Seamus
‘76 tintop Crusher
‘77 westy The Judge
‘72 tintop bastard westy Hudson |
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Mon Nov 15, 2021 12:37 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
One of my friends recently received an advertising leaflet for Cox & Cox in their mail box, of which this is the front cover featuring a 1968~73 VW Type 2 campervan; which noting the absence of a separate sliding-door lock is probably of 1968~73 model-year.
ttps://www.thesamba.com/vw/forum/album_cat.php?cat_id=46
https://www.coxandcox.co.uk
https://www.coxandcox.co.uk/christmas/ _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Nov 16, 2021 9:32 am Post subject: Re: Type 2s [buses], used in advertising products & services |
Yes, I added the speech bubble. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
danfromsyr Samba Member
Posted: Tue Nov 16, 2021 9:37 am Post subject: Re: Type 2s [buses], used in advertising products & services |
every hippie (boho) chick is a diva...
yes they need a pedestal
yes someone needs to knock them off if it.. _________________
Abscate wrote: |
Posted: Thu Dec 09, 2021 10:11 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
from AAA
Quote: |
BUFFALO, N.Y. (WIVB) — AAA has offered some helpful tips for keeping your Christmas tree on top of your car.
“If it isn’t properly secured on a vehicle, the tree can become a dangerous projectile, endangering others on the road,” AAA says.
According to AAA research, road debris caused more than 200,000 crashes over a four-year period. Those crashes resulted in roughly 39,000 injuries and 500 deaths.
Improperly secured Christmas trees could also result in up to $1,500 in repairs for drivers.
Here are some tips for getting it home safely, courtesy of AAA:
Do not visit a tree lot if you or anyone from your family has tested positive for COVID-19 or are experiencing COVID-related symptoms.
Call the lot ahead of time and ask about their policies for visiting. It is possible they may have reduced operating hours or are limiting the amount of people who can visit the lot at one time. It is also a good idea to ask when they are slow and plan to visit then, when crowds may be smaller.
Although most lots are located outside, it is recommended to wear a face covering and practice social distancing. Bring hand sanitizer and keep it nearby while shopping.
Make sure to bring strong rope or nylon ratchet straps, an old blanket, gloves and of course – the right vehicle. One with a roof rack is ideal but a pickup truck, SUV, van or minivan can work just as well.
Once you’ve found the perfect tree, have the lot wrap it in netting before loading it. Loose branches can also be secured with rope or twine to help protect the tree from damage.
Prior to loading the tree, cover the roof with an old blanket to prevent scratches to the paint and protect the car from any damage.
Place the tree on the roof rack or in the bed of the truck with the trunk facing the front of the car. If the vehicle does not have a roof rack and is a SUV, CUV, van or minivan – place the tree inside. If not, rent or borrow a proper vehicle.
Secure the tree at its bottom, center and top using strong rope or nylon ratchet straps. Avoid using the twine offered by many tree lots. Use fixed vehicle tie-down points and loop the rope or strap around the tree trunk above a branch to prevent any side-to-side or front-to-rear movement.
Once tied down, give the tree several strong tugs from various angles to make sure it is secured in place and will not come loose.
Drive slowly and take back roads if possible. Higher speeds can create significant airflow that can damage your tree or challenge even the best tie-down methods. |
Abscate wrote: |
Posted: Mon Dec 13, 2021 11:39 am Post subject: Re: Type 2s [buses], used in advertising products & services |
[quote="danfromsyr"]from AAA
A Christmas tree of that size would not fit in most British homes and it's debatable whether one could readily obtain one of that size anyway.
Traditionally, since the end of World War 2, Norway has sent a very large FREE Christmas tree to Great Britain for public display, in recognition of our major contribution to their defense from the Nazi invaders, in which we sank a large proportion of the German naval destroyers in a single engagement, years before the USA entered the war. People were also ferried secretly to and from Norway, by means of the "Shetland Bus" during much of the war. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
creative native Samba Member
Posted: Wed Jul 13, 2022 8:33 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
_________________ "The holy land is everywhere." ~ Black Elk
1979 Westfalia P27, California FI emissions spec. 100% VW fleet: '79 Westfalia, 2013 Touareg Lux (Toffee Brown/Cornsilk Beige), 2005 Passat GLX. |
Posted: Wed Jul 13, 2022 9:03 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
EverettB wrote: |
Clothing ads:
The girl in the first picture has the eyes. The second picture of the three hippie chicks are cute. As long as there not waving goodbye. It will look like they have buckwheat in a head lock. |
Posted: Sun Jul 17, 2022 8:44 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
Who is old enough to remember Protein 21 shampoo (or Body on Tap or Gee, Your Hair Smells Terrific shampoos)?
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Mon Jul 18, 2022 9:15 am Post subject: Re: Type 2s [buses], used in advertising products & services |
Those last three should still be in school, it’s before 2 pm
Ick. _________________ .ssS! |
Posted: Sat Mar 11, 2023 7:31 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
here's a image from Outdoorsey. you know advertising for you to rent your (prized) bay to Other people
Umm, that's a hard pass. $100bux in my pocket so you can let yer rug rats run amuck in the bus.. or so that you can 'make more' in the back... I think not..
Abscate wrote: |
Posted: Sat Mar 11, 2023 8:09 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
danfromsyr wrote: |
I can smell the Patchouli from here. |
Hubster43 Samba Member
Joined: June 03, 2013 Posts: 43 Location: Northern CA
Posted: Sat Mar 11, 2023 8:15 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
I saw this for some bike shop in Cotati,CA. Oh, yea, it’s our bike shop. |
richparker Samba Member
Joined: November 24, 2011 Posts: 6981 Location: Durango, CO
Posted: Sat Mar 11, 2023 11:21 pm Post subject: Re: Type 2s [buses], used in advertising products & services |
Hubster43 wrote: |
That graphic is cool, but your website leaves a lot to be desired.
If you’re gonna pimp the bus, you best be representing. Look me up on Strava, my user name is Rich Parker there too… _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
TornadoRed06 Samba Member
Joined: August 30, 2020 Posts: 198 Location: Porto - Portugal
Posted: Sun Jun 18, 2023 11:28 am Post subject: Re: Type 2s [buses], used in advertising products & services |
Hey, summertime is... Baywindow Time!
Lidl & Intermarché supermarkets kick-off the season prominently featuring the Baywindow in their marketing communications.
Posted: Thu Jun 22, 2023 9:38 am Post subject: Re: Type 2s [buses], used in advertising products & services |
TornadoRed06 wrote: |
It's interesting to note that those two blue-coloured VW Type 2s, appear to be RIGHT-HAND DRIVE . Perhaps they were owned by some of the many British expatriates living in Portugal. I hope that hammock wasn't attached to the cab-door handle!?!
Note the single-burner Camping Gaz stove (or very similar) mounted on the small, disposable butane-gas cartridge, which people typically use for back-packing camping trips. For those, I have a small, petrol-fired, classic Optimus cooking-stove that I bought in the early-1970s, for Duke of Edinburgh Award expeditions.
https://www.katadyngroup.com/int/en/brands/Optimus~b4909/overview
https://classiccampstoves.com/threads/history-of-the-optimus-no-111-work-in-progress.16556/
I have yet to see this Lidl advertisement / promotion in Great Britain, where LiDL and Aldi are progressively increasing their market share.
https://www.campaignlive.co.uk/the-work/advertiser/lidl/10153
I have yet to count how many 1968~79 VW Type 2s turn up in their car parks!?! _________________ Regards.
Nigel A. Skeet
Posted: Sun Apr 07, 2024 10:42 am Post subject: Re: Type 2s [buses], used in advertising products & services |
On various British television channels last week, I noticed an advertisement for Vitalin dog food, which briefly featured a 1974/75 VW 1600 Type 2 Westfalia motor-caravan
RHD orange & white, 1974/75 VW 1600 Type 2 Westfalia motor-caravan [reg. No. RWV 258N – 1974~75 registration year]
WIN a HOLIDAY with your DOG
(£250 worth of Petspyjamas, Dog-Friendly Holiday Voucher)
Submit your email below to be entered into our prize draw
Vitalin Pet Food, Lodge Farm, Wigsley Road, North Scarle, Lincoln, LN6 9HD
Tel: +44 (0)1522 778 001
Email: [email protected]
https://vitalinpetfood.co.uk/about-us/
https://vitalinpetfood.co.uk/our-recipes/
https://vitalinpetfood.co.uk/competition/
Kevin White, “Cranswick petfood brand Vitalin launches first TV ad”, Petcare, The Grocer, 28th March 2024
https://www.thegrocer.co.uk/petcare/cranswick-petf...00.article
« Meat giant Cranswick has unveiled a major investment in its Vitalin petfood brand, including a first major TV campaign. »
David Rees, Vitalin brand backed by major TV campaign, Pet Business World News, Thursday, 28th March 2024
https://www.petbusinessworld.co.uk/trade-news/manu...paign.html
« The campaign breaks today (March 28) with a 30-second TV ad and accompanying online campaign running across ITV, Channel 4, Channel 5, and Sky, plus online display and social channels. It represents parent company Cranswick’s first brand investment in the pet category and the first TV advertising campaign in Vitalin’s 71-year history. »
Marianne Calnan, “Cranswick-owned Vitalin dog food unveils first TV ad”, Campaign Live
https://www.campaignlive.co.uk/article/cranswick-owned-vitalin-dog-food-unveils-first-tv-ad/1867336
« Studio Yes created and produced the work. » _________________ Regards.
Nigel A. Skeet
