Yannvanh Samba Member
Joined: November 07, 2020 Posts: 143 Location: Belgium
Posted: Sat Sep 25, 2021 5:49 am Post subject: Hockeystick oil vs grease? |
Hi guys,
I am currently doing a straight axle swap on my 65 splitbus
When i took off the nosecone on my splitty transmission i saw it was all oil that was in there:
But when i took off the nosecone on my beetle transmission i saw it was all grease and no oil:
Everything is greasy in the beetle gearbox:
did VW changed it after some years?
Is this normal and can i just fill it with the correct oil?
Thanks! |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Sat Sep 25, 2021 9:09 am Post subject: Re: Hockeystick oil vs grease? |
no vw did not switch to grease . not normal . use normal gear lube.
was there any gear oil in it? does not look like it. too clean. odd.
looks like it was re-built greased up and not run? that's a new one.
Steve. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
desertwrx Samba Member
Joined: January 18, 2007 Posts: 351 Location: Borrego Springs, CA
Posted: Sat Sep 25, 2021 10:26 am Post subject: Re: Hockeystick oil vs grease? |
That middle photo looks like brand new grease was put on it for the photo. _________________ 2 fiberglass buggies, 2 non-running Corvair Sandrails!
SCCA |
74 Thing Samba Member
Posted: Sat Sep 25, 2021 12:23 pm Post subject: Re: Hockeystick oil vs grease? |
It is not uncommon to have a builder use grease on the main bearing since not a lot of gear lube gets to the nosecone. |
Posted: Sat Sep 25, 2021 10:39 pm Post subject: Re: Hockeystick oil vs grease? |
I bought it from a guy which didn't know the condition it was in.. (he bought it in a clean up sale)
I bought 3 gearboxes from him so i think i have got myself a rebuild one,
Nothing is worn, there was no oil in it and the grease looks like brand new indeed..
But no what? Can i just fill it wil oil and wil the grease an oil 'mix'? |
Posted: Sat Sep 25, 2021 10:48 pm Post subject: Re: Hockeystick oil vs grease? |
Not a good pic but here you can see that the pinion was also full af grease:
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sun Sep 26, 2021 5:33 am Post subject: Re: Hockeystick oil vs grease? |
That's an old trick to quiet a gear box noise _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Dale M. Samba Member
Posted: Sun Sep 26, 2021 6:56 am Post subject: Re: Hockeystick oil vs grease? |
I would imagine the whole gear assemblies internally are grease coated too...
You can reassemble, add gear oil and run it, the gear oil will eventually break down the grease... But all will still be lubricated .... I would be inclined to change gear oil after the first 500 miles or so in any case.... Real question may be the quality of the actual rebuild and not the grease... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Mon Sep 27, 2021 6:55 am Post subject: Re: Hockeystick oil vs grease? |
I paid 230$ for 3 gearboxes including axles and tubes so if it breaks down i still got 2 left |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Sep 28, 2021 5:56 am Post subject: Re: Hockeystick oil vs grease? |
I'm surprised MCMSCott hasn't chimed in to mention what kind of Hack puts grease in their trans.
No grease. oil only.....
Grease will get throw off real fast never to return. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Thu Sep 30, 2021 12:10 am Post subject: Re: Hockeystick oil vs grease? |
Lingwendil wrote: |
Maybe it was shipped in assembly grease, and expected to be filled with oil by the installer?
Hopefully? |
Yeah that's what i think also.. but i realy dunno what to do right now,
Fill it with oil and hope they will mix? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Thu Sep 30, 2021 7:31 pm Post subject: Re: Hockeystick oil vs grease? |
Lingwendil wrote: |
Fill it, drive it, then change it? |
This is what I'd do! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Thu Sep 30, 2021 11:56 pm Post subject: Re: Hockeystick oil vs grease? |
Okay ill just give it a go!
Thanks guys |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Fri Oct 01, 2021 1:01 pm Post subject: Re: Hockeystick oil vs grease? |
Now that I'm starting to dig into transaxles it would be fun to see the results of an experiment like this.
I'd imagine if you filled it with oil to the level plug with the grease there like it is,
That the level would go up as the grease dissolved into the oil.
Pull the level plug before you drain it, as I'm curious to see..!
Also,
Would be fun to only put like a hundred miles on then pull the nose cone.
See if there is enough oil to the mainshaft bearing to wash the grease away..
Bet you the mainshaft bearing would be the last place where oil would dissolve the grease.
People do this kind of thing with motors all the time.
Why not to a transaxle? _________________ Bus Motor Build
What’s That Noise?!? |
modok Samba Member
Joined: October 30, 2009 Posts: 26789 Location: Colorado Springs
Posted: Fri Oct 01, 2021 8:07 pm Post subject: Re: Hockeystick oil vs grease? |
Looks like moly grease.
Moly grease is good for gears, acceptable for precison ball bearings but not ideal, potentially bad for syncros.
Packing bearings with grease is often a good idea, but be careful to use the right kind of grease. needs to be compatible with the oil. |
