dhaavers Samba Member
Joined: March 19, 2010 Posts: 7754 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Feb 05, 2019 7:07 pm Post subject: Re: DIY flywheel hub refinishing... |
tencentlife wrote: |
You can ... shorten the lip tension spring about 1/8 - 3/16" to increase lip pressure a bit. |
Cool! Learned another thing today...Thanks!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10075 Location: Abiquiu, NM, USA
Posted: Wed Feb 06, 2019 12:49 pm Post subject: Re: DIY flywheel hub refinishing... |
It's an old trick, you just pull the tension spring out, find the joint, unscrew and with a sharp dykes trim a little off the female (larger diameter) end. To reassemble, counter-wind the ends a few turns first, then screw them back together. Don't overdo it, a little makes a big diff, like I said keep it to 1/8 - 3/16". _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Sun Oct 25, 2020 2:41 pm Post subject: Re: DIY flywheel hub refinishing... |
Late season follow up...now over 50k on this repair with no trouble, no leaks, no gnashing of teeth...
"The WonderVan"
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4770 Location: Bemidji, MN
Posted: Sun Oct 25, 2020 4:17 pm Post subject: Re: DIY flywheel hub refinishing... |
thanks for the check in on this, Dave. you done good. _________________ -dan
www.thefixitworkshop.com |
4Gears4Tires Samba Member
Posted: Mon Oct 26, 2020 6:38 am Post subject: Re: DIY flywheel hub refinishing... |
Forums were certainly vibrant 8 years ago. The age of "ThE iNtErNeT iS sErIoUs BuSiNeSs."
Nice job on the durability of the fix! _________________ '87 Syncro
Robw_z Samba Member
Posted: Sat Sep 25, 2021 2:09 pm Post subject: Re: DIY flywheel hub refinishing... |
dhaavers wrote: |
- Dave |
More folks need to update like this! I'm debating new flywheel vs polish atm, having a hard time deciding if my flywheel groove is bad or not.
-Rob |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
