zapgar Samba Member
Posted: Mon Sep 09, 2019 6:01 pm Post subject: Has anyone installed GoWesty's 3-point rear bench seat belt kit? |
Here is the problem I came across when installing the 3-Point Retracting Seat Belt (KT122-VANO Rear Seat, Left or Right Side) in my hard top 87 Syncro.
The instructions say to install the new seat belt on the outside side of the Z bench frame (see black/white photo from install instructions ). However there is a spacer welded onto the metal frame. (see the Red Arrow in the attached photo and red circles in separate photo ).
This spacer (which passes through the wall and insulation) prevents the belt from being connected between the frame and the interior wall as the instructions suggest.
A GoWesty restoration mechanic instructed me to install the seatbelt BEHIND that spacer. Doing so will twist the metal frame out of plumb by about 3/4”. If I add an additional lock nut plus both left and right side seat belts into the equation I’ll be racking it even further.
Seems like it puts unnecessary stress into the bench frame, so wanted to ask before taking a sawzall to my van.
Has anyone installed these belts on their hard top vanagon and figured out a good way to install these puppies?
Thanks! |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Tue Sep 10, 2019 9:58 am Post subject: Re: Has anyone installed GoWesty's 3-point rear bench seat belt kit? |
I would call or email GW with your question. They are usually pretty helpful with technical questions. You could also link them to this thread for reference. _________________ 89 Westy 2.1 Auto |
hoveypdx Samba Member
Joined: September 23, 2020 Posts: 1 Location: Portland, OR
Posted: Mon Sep 13, 2021 12:26 pm Post subject: Re: Has anyone installed GoWesty's 3-point rear bench seat belt kit? |
hey Zapgar,
I see it's been a couple years, so I'm guessing you found a solution to this issue? I have the exact same issue right now (same bench, same GW seat belts) and curious what you came up with?
Thanks! |
zapgar Samba Member
Posted: Sat Sep 25, 2021 3:37 pm Post subject: Re: Has anyone installed GoWesty's 3-point rear bench seat belt kit? |
You know, I did hear from a sales rep at GoWesty. He sent me some pictures of another hole I could try for mounting the lap portion of the belt.
I got distracted with other things and never actually moved the bolts on my van. I think it's worth trying this hole and see what happens.
Let us know if it works for ya!
