Diesel Slave Bracket Support Problem [SOLVED]
vanagonjr
vanagonjr is offline
PostPosted: Sat Sep 10, 2016 9:01 am    Post subject: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
Mounting a Diesel bell housing to a WBX tranny and having problems with the slave bracket support not quite working out
I have two diesel set-ups, and the one I pulled from the van looks like the PO did not mount the support bracket to the tranny, since the threaded hole in the tranny looks like it was unused (see below) and the (rusty) bracket does not have evidence or a bolt head contacting it - but I could be wrong there.
Would the diesel bracket only with with a diesel (or air-cooled) tranny? This supposedly is an 84 WBX tranny. I can take the WBX bracket and re-drill and cut to make work, just rather make sure something is not amiss here.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Sep 10, 2016 9:44 am    Post subject: Re: Diesel Slave Bracket Support Problem Reply with quote
I think your issue is you need to install the diesel starter motor first and then that spaces the bracket out a little to tilt it down and line up the lower brace hole.
Mark
vanagonjr
PostPosted: Sat Sep 10, 2016 10:01 am    Post subject: Re: Diesel Slave Bracket Support Problem - SOLVED Reply with quote
Mark
Mark - exactly right and thank you so much! Was leaving the starter off to make moving the tranny a bit lighter and did not even see this!
PS-I enjoy reading your posts and your contributions to this community are simply awesome.
epowell
epowell is offline
PostPosted: Sat Sep 25, 2021 10:43 am    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
Having trouble getting the SLAVE bracket to fit.
Then noticed that at the STARTER BOLTS AREA the bracket is majorly bent.
...and seems that it is supposed to be straight like this.
So I am going to remove the bracket and try to hammer it straight again...
...Am I on the right track?
Thanks
Ed
www.edwardpowell.com
epowell
epowell is offline
PostPosted: Sat Sep 25, 2021 11:17 am    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
The question now is how to BEND the bracket?
I suppose I could remove the clutch lever but that might be near impossible... or somehow keep it attached to the starter and use a c clamp somehow to bend it back into shape?
epowell
epowell is offline
PostPosted: Sat Sep 25, 2021 12:41 pm    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
Got it done...
I hammered on the bracket from inside with a minisledge... got it enough back in shape to line up the holes. Smile
djkeev
djkeev is offline
PostPosted: Sat Sep 25, 2021 4:09 pm    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
Sledge hammers can fix any problem that arises I guess….
A tool not in my travel tool kit.
Ghia
Vanagon
Beetle
epowell
epowell is offline
PostPosted: Sat Sep 25, 2021 4:41 pm    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
I hear ya, I was very apprehensive about doing that because I imagined it might disturb lots of stuff in the engine etc.... but actually that was not the case, the vibrations didn't seem to go anywhere. I was surprised that it worked and didn't disturb anything. Keep in mind that in that position it was not even possible to wield much force.
I also don't carry a sledge hammer when traveling but that is because of its weight not it's lack of utility.
I'm sure I would have done a lot of unnecessary damage if I had tried to remove that clutch lever. The only other option would have been a sturdy c-clamp to try to bend it back - that might have worked, but I don't have a c-clamp here.
djkeev
djkeev is offline
PostPosted: Sun Sep 26, 2021 5:07 am    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
I’m honestly glad it worked for you…..
But life experiences have shown me how easily aluminum castings (such as a transaxle) can crack.
I’d think long and hard before pressing my good luck on a similar future repair.
Dave
Ghia
Vanagon
Beetle
crazyvwvanman
PostPosted: Sun Sep 26, 2021 5:27 am    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
In this case it is a massively thick casting in an area supported by a massive bolt clamping the casting to the thick iron block and holding the bracket steady. The bent bracket is comparatively flimsy.
Mark
djkeev
djkeev is offline
PostPosted: Sun Sep 26, 2021 5:30 am    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
Yeah …….. tell my Bell housing how tough he is for me……
Ghia
Vanagon
Beetle
epowell
epowell is offline
PostPosted: Sun Sep 26, 2021 8:14 am    Post subject: Re: Diesel Slave Bracket Support Problem [SOLVED] Reply with quote
Your concern is very appreciated Dave, but in this case it is misplaced. As I said, I began light pounding with major trepidation for the reason you mentioned... but you can easily FEEL it. NOTHING whatsoever was moving, vibrating, or anything. As Mark pointed out, it's like that wimpy bracket is being held by a 100KG vice Smile I was very very surprised myself.
So let me ask you... how would YOU have solved this problem. My way took 5 min. and caused no damage Smile
Using a c-clamp somewhere would have caused even more risk to the part you would clamp the bracket to.
Removing the clutch level would be near impossible and likely end up damaging something... what are you left with?
