VWScrew Samba Member
Posted: Mon Apr 09, 2012 5:35 am Post subject: Hella turn signal switch bulb |
I just bought a pair of Hella turn signal switch and for the one with the red tip, the bulb is missing. Can someone give me some information about this bulb ?
Thanks in advance.
VWScrew from France.
_________________ http://vwscrew.skynetblogs.be |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Mon Apr 09, 2012 6:18 am Post subject: |
the bulbs are listed in the '71? hella catalogue as:
6V W61.2
12V W121.2
SAMBA VAN MAN Samba Member
Joined: June 18, 2006 Posts: 146 Location: MANCHESTER ENGLAND
Posted: Fri May 09, 2014 11:33 am Post subject: |
But what bulb is it? is it a Ba7s? |
joshbuchan Samba Member
Joined: April 12, 2007 Posts: 712 Location: victoria bc canada
Posted: Fri May 09, 2014 4:00 pm Post subject: |
I have a red tip semaphore switch but it's a bosche version..
Not sure if it runs the same bulb but I can pull the number and email you a pic in the next couple days |
Posted: Fri May 09, 2014 7:52 pm Post subject: |
Good Morning
Yes that would be great.
Many Thanks
Paul |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Fri Mar 09, 2018 9:56 pm Post subject: Re: Hella turn signal switch bulb |
Hello, I'm looking for a wiring diagram for installing one of the red tipped hella switches (above) in my split bus with semaphores - can anyone point me in the right direction please? I've found this but it is for flashing indicators:
https://images.classiccult.com/hella-turn-signal-semaphores-switches-2.jpg
Many thanks,
Dave |
Hazza6542 Samba Member
Posted: Fri Mar 09, 2018 11:41 pm Post subject: Re: Hella turn signal switch bulb |
I'll have a look at stock wiring diagrams and the switch and draw something up for you. Just need to know how many wires you switch is and what year bus? _________________ 55 build: https://www.thesamba.com/vw/forum/viewtopic.php?t=680057 |
Posted: Sat Mar 10, 2018 1:11 am Post subject: Re: Hella turn signal switch bulb |
Here you go. 54BL for power in, use your stock WHT/GRN/BLK indicator power wire from the fuse box. Separate power to K, or in my diagram I used power from 54BL, might not be practical in real world, I'll let you figure that part out. Then the other K needs to be connected to the blue wire to the speedo indicator light. That should make the red tip light up just as the speedo light would. HR and HL are connected normally to the corresponding WHT/BLK and GRN/BLK semaphore wires. The other 3 terminals should need to be connected to anything.
Should install pretty clean, basically only one extra wire under your dash. Good luck, lemme know how it goes but that should work.
bally Samba Member
Posted: Sat Mar 10, 2018 1:46 am Post subject: Re: Hella turn signal switch bulb |
Brilliant. Thanks. I'll get to it this week and report back. Cheers Dave |
bally Samba Member
Posted: Sat Apr 28, 2018 6:20 pm Post subject: Re: Hella turn signal switch bulb |
I got to pulling this switch off yesterday and here is what I found:
I have four terminals, K, L, R and 54
I assume my green/white/black (need to source that cable from an old loom to get the right colours) goes to the 54, L and R are feeds tot he semaphores and therefore I assume my only K would be an output to the dash light - is this correct?
My bus is Oct 59 Australian CKD PMG bus
Cheers, Dave |
Posted: Sun Apr 29, 2018 1:13 am Post subject: Re: Hella turn signal switch bulb |
Gimme a little bit, I'll draw up another one tonight and edit it in.
EDIT: Never mind, I'm pretty sure you're right there. Same as any other semaphore switch. Grab a multimeter and check for continuity through K at the terminal and where the bulb + would touch. Assuming K is the bulb, I reckon a factory install would just run another thin blue wire from the speedo indicator bulb up to K. If you're using a stock loom I could rip out some of my original blue wiring from a beetle and ship it down to you (Building a new loom) so it would look period and original. If you do run a new wire from the speedo indicator bulb I'd put a bicycle shift cable cap over the three sections of bare wire and clamp it down like they did at factory back then. Any bike shop will have em, usually free or under a buck. Closest thing you'll get and ensures a good solid connection. Get plain steel, not anodized.
bally Samba Member
Posted: Mon Apr 30, 2018 2:42 am Post subject: Re: Hella turn signal switch bulb |
Thanks for the advice and links, I'll test it this weekend. I have an old loom I can rob for the cable. Thanks. I don't follow what you mean by the bike part; I was planning to out some black heat shrink over the cables. Can you elaborate please? Cheers. Dave |
Posted: Mon Apr 30, 2018 6:23 am Post subject: Re: Hella turn signal switch bulb |
OK so on the old style screw terminals sometimes where there were two separate wires going into one terminal they had a metal sleeve that was crimped onto the wires to hold them together. Those bike bits will do the same, shove it over the multiple wires and crimp it down. Easy to slide into the terminal and good connection between wires. _________________ 55 build: https://www.thesamba.com/vw/forum/viewtopic.php?t=680057 |
bally Samba Member
Posted: Mon Apr 30, 2018 4:51 pm Post subject: Re: Hella turn signal switch bulb |
Great tip. Thanks. Was that used at the fuse box too? |
46split Samba Member
Posted: Sun Sep 26, 2021 2:34 pm Post subject: Re: Hella turn signal switch bulb |
Hi All Not sure what make this is but does anyone happen to know how to wire up to a Lowlight ghia
Any help would be greatly appreciated |
