DsplitWindowguy Samba Member
Posted: Sun Sep 26, 2021 3:39 pm Post subject: 63 split.. headlight problem |
U h-oh, me again.. I cannot get one of my headlights to go on. I tighten it down with big screw then other side pops off... I got one but,, now I a stuck, again... ideas anyone?? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sun Sep 26, 2021 6:25 pm Post subject: Re: 63 split.. headlight problem |
German original or aftermarket headlight/chrome ring? What body-to-headlight rubber company do you use? |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Sun Sep 26, 2021 9:56 pm Post subject: Re: 63 split.. headlight problem |
It's the same German engineering maddening enhanced design that's been used on every Porsche 356, 912 and 911 from what 1954 to at least 1989? In which case, final proper removal and fitment is accomplished with the open palm of your hand applied in very firm and fast condition.
But what I'd check first: Remove the outer chrome ring from the headlight assembly. Try fitting just the chrome ring to the headlight bucket that is welded to the chassis. If it doesn't fit quite right all the way around, remove it and massage with your hands the spots that don't quite fit right by slightly bending and twisting the chrome ring. Once you think you have it right, place the outer rubber gasket that fits between the chrome ring and bucket welded in the chassis in place then try to fit the chrome ring. IF you can get it all to fit correctly WITHOUT the headlight assembly then it ought to fit right WITH the headlight assembly inside the chrome ring. Right?
Now in the words of ESPN's Lee Corso...."Not so fast my friend!" don't be surprised when it all gives you problems once you try to install the headlight assembly to the chrome ring then try to put it all on your bus with or without the rubber seal.
One area to look at, is where the metal "spring" clips that hold the chrome ring to the headlight assembly are positioned relative to the "tab" on the headlight bucket welded in the chassis of your bus---which coincidentally is at the opposite end of the bucket where you put the screw . Try to have the metal "spring" clips in a spot where the chrome ring doesn't land on that "tab".
Good luck with it. They are almost always a fight. At least one of them usually is! |
Posted: Thu Sep 30, 2021 2:45 pm Post subject: Re: 63 split.. headlight problem |
Thanks all.. still fighting chrome headlight ring... fits great with no rubber gasket!!! But I live in a rainy area gotta have it.. so still at it.. |
Posted: Thu Sep 30, 2021 2:46 pm Post subject: Re: 63 split.. headlight problem |
Barry, the parts can with bus, so not sure what I have... |
BarryL Samba Member
Posted: Thu Sep 30, 2021 6:19 pm Post subject: Re: 63 split.. headlight problem |
Can you post a photo of the gasket especially the tee profile in focus. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Fri Oct 01, 2021 11:20 am Post subject: Re: 63 split.. headlight problem |
Do you have the spacer under the mounting tab? |
Posted: Fri Oct 01, 2021 2:58 pm Post subject: Re: 63 split.. headlight problem |
Here is my headlight.. all seems fine, other on went it great!! Spacer part???????
There they are headlight pics.. 63 bus |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Oct 01, 2021 6:32 pm Post subject: Re: 63 split.. headlight problem |
Also, start with the entire headlight aiming assembly aligned better. Adjust the screws and make the headlight retaining ring "match" or otherwise be evenly spaced with the plane of the main assembly "can." It may not be straight enough to screw into the headlight bucket at all. _________________
EverettB wrote: |
FU#5 |
Posted: Sat Oct 02, 2021 2:56 pm Post subject: Re: 63 split.. headlight problem |
OH, that white spacer. yes I have it!! And love all the help on here,, I read them and then work on projects,, so thence, I am still at it!! |
