Original Location of Transmission Ground Strap
plywoodkid
plywoodkid is offline
PostPosted: Sun Sep 26, 2021 10:06 pm    Post subject: Original Location of Transmission Ground Strap Reply with quote
All,
1970 Bus. Original Transmission (Been Rebuilt).
I know there has been past threads regarding the Transmission Grounding Strap. However, I cannot find where the exact original placement of the strap is.
I also checked the Bentley. Maybe I'm missing something.
I realize that it probably doesn't matter since you can ground anywhere on the tranny to the chassis.
Does any one have a picture or can explain the original location points for installation on Early Bays?
I would appreciate it.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Sun Sep 26, 2021 10:43 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
You can just about see it in your owners manual:
Do yourself one better, and inspect the studs on your transaxle for a clean mounting point and enough threads left on the studs to engage the nut with the strap in place. A cone-shaped wire wheel in a Dremel is my favorite way to clean ground strap mounting points. Sometimes the holes in new straps are large enough to warrant a fender washer.
Robbie
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
Wildthings
Wildthings is offline
PostPosted: Sun Sep 26, 2021 10:50 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Left side of the nose cone about halfway up, to a stud on the left side of the torsion tube.
plywoodkid
PostPosted: Mon Sep 27, 2021 7:52 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Thanks All.
Finished Product.
Torque: 14 lbs on 13 mm nut on tranny
Torque: 25 lbs on 17 mm nut on torsion mount
skills@eurocarsplus
Samba Peckerhead
skills@eurocarsplus is online now
PostPosted: Mon Sep 27, 2021 9:24 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
stud is on the trailing arm mount
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
SGKent Premium Member
SGKent is offline
PostPosted: Mon Sep 27, 2021 9:30 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
correct.
From Samba Gallery
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
plywoodkid
PostPosted: Mon Sep 27, 2021 9:53 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Thanks guys……I finally found the stud. It’s on the passenger side, so I have to swap sides.
Should the end mounted to the transmission go to the 13 mm bolts or the 11mm bolts?
kreemoweet
kreemoweet is offline
PostPosted: Tue Sep 28, 2021 1:19 am    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
The transmission mount bolt, where you first connected the ground strap, is no good at all since it's isolated
from the chassis (i.e. ground) by rubber. The stock location for the strap is on one of the 8 mm studs (which
I suppose you mean above by "13 mm bolt") on the final drive housing.
'67 bug: seized by the authorities
SGKent is offline
PostPosted: Tue Sep 28, 2021 6:14 am    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
do it like the photo. The stud should be on the left side, driver side arm bracket.
plywoodkid
PostPosted: Tue Sep 28, 2021 10:10 am    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
All,
Thanks. I just corresponded a bit with SGKent.
What appears to be different, is that my chassis stud is on the passenger side vice the driver’s side.
With that said, I would assume that this doesn’t change the logic of the connection.
The Chassis connection is now a no brainer, it’s the transmission connection spot that is in question.
Elibomrod
Elibomrod is offline
PostPosted: Tue Sep 28, 2021 10:11 am    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Noticed that your ground strap won’t work as fitted in the picture.
You have bolted to the part of the transmission Mount which is insulated from the main body with rubber.
Would only work on body side of mount, or ideally as per pictures later on in thread.
Elibomrod
PostPosted: Tue Sep 28, 2021 10:14 am    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Oops repeat should have read the later posts Embarassed
mikewire
mikewire is offline
PostPosted: Tue Sep 28, 2021 11:44 am    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
plywoodkid wrote:
All,
Mine is also on the passenger's side...maybe it's an early Bay thing? Here's another angle:
-Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Classifieds Feedback
plywoodkid
PostPosted: Tue Sep 28, 2021 1:16 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Thanks Mike, I was beginning to think I was losing it. Looks like yours is on the 2nd Bolt of the case of the transmission.
I’ll swap it out tonight.
TomWesty
TomWesty is offline
PostPosted: Tue Sep 28, 2021 8:09 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
I just cleaned and tightened mine. I recall it being on the passenger side as well. ‘71 bus.
djdh68dlux
djdh68dlux is offline
PostPosted: Tue Sep 28, 2021 9:02 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
It's on the passenger side on my 68 as well. Been messing with brake lines back on that passenger rear wheel and the strap occasionally gets in the way.
1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org
plywoodkid
PostPosted: Wed Sep 29, 2021 4:25 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Thanks All…..correction
Passenger Side Stud…..
bsairhead
bsairhead is offline
PostPosted: Wed Sep 29, 2021 4:59 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Now that you have it in the correct place take it back off and make it functional.
Westfalia73
Westfalia73 is offline
PostPosted: Wed Sep 29, 2021 5:49 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
Plus the Ny-Lock nuts above the ones where you have your strap are not doing anything. No threads are in the Ny-Lock part.
1973 tintop westfalia weekender.
1973 beetle.
1981 Brazilian baywindow kombi.
plywoodkid
PostPosted: Wed Sep 29, 2021 7:26 pm    Post subject: Re: Original Location of Transmission Ground Strap Reply with quote
I’m missing something on the “make it functional” comment.
Not being sarcastic….I’m not getting it.
