vwnc Samba Member
Posted: Mon Sep 27, 2021 7:39 am Post subject: Fuel Gauge not working |
Got a '67 bus with a fuel gauge that wasn't working. Took out the gas tank and cleaned in before reinstalling along with installing a new sending unit. Made sure the sending unit was properly grounded. Reinstalled motor and hooked up all the electrics accordingly. When I turn the ignition on, the fuel gauge makes a funny noise and the needle goes back and forth between empty and full and the stops for 20 seconds and then goes back to noise and the needle going back and forth. Thought about buying a good "aftermarket" one, but didn't want to rule out the possibility of fixing the existing one. Any thoughts? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 27, 2021 8:16 am Post subject: Re: Fuel Gauge not working |
Does it still do that if you disconnect the wire from the sender on the tank? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 560 Location: I don't recognize it anymore
Posted: Wed Sep 29, 2021 5:05 am Post subject: Re: Fuel Gauge not working |
First-off, "A fuel gauge is supposed to work in a Split?"
Since 78 I've been struggling w this gauge.
Some guys build them Ok, and some don't-The idiom Grasping straws really.
Your issue is drawing power/resistance, then letting go>strange.
I have several gauges as many of us do including senders and I have soldered new chrome wires into senders before, but the sender is simple electronics, I would replace the gauge in your case< But then again, the "wiper" inside the sender could be corroded (common) at the top which would lose resistance as soon as the float reaches upward (no contact) That is why I say try to replace the gauge instead of bumper, valence, wires, gas, clutch, MOTOR. Under $75 diagnostic before you remove the motor & tank _________________ kaiser kills kids.com |
chgrec Samba Member
Joined: October 29, 2016 Posts: 103 Location: Fernandina Beach Fla
Posted: Wed Sep 29, 2021 5:26 am Post subject: Re: Fuel Gauge not working |
I chased sender/gauge issues for a bit but finally got it fixed (I had 2 brand new, bad senders). Here is how I tested things.
Pull the sender wire from the tank sender unit and ground it, does it behave the same way or send the needle to Full?
Pull both wires from the gauge, ground one side & put 12v on the other side of the gauge, does it do the same thing or send the needle to Full?
If so, I'd replace the gauge as has been suggested....If it behaves normally then your sender unit or wiring may be compromised... _________________ Life's to short to drive a boring car!
Follow my latest project: https://www.thesamba.com/vw/forum/viewtopic.php?t=668542&highlight=
My previous project: http://www.mgexp.com/journal/chgrec/ |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Wed Sep 29, 2021 2:02 pm Post subject: Re: Fuel Gauge not working |
If I remember right, the gauge has to be reliably grounded to the dash, too.
Or maybe that's just for the light. Who knows. I fill up every 200 miles. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Wed Sep 29, 2021 4:54 pm Post subject: Re: Fuel Gauge not working |
If the issue is the sender, see this link. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Clara Samba Member
Posted: Thu Sep 30, 2021 4:18 pm Post subject: Re: Fuel Gauge not working |
Culito wrote: |
This. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
