johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 570 Location: South of Raleigh
Posted: Sun Sep 26, 2021 11:44 am Post subject: distributor info |
So at an auction of a recently closed up shop, I managed to buy a bunch of distributors. All are original Bosch Germany built. I think I have a handle on what most of them are, but if anyone can clear up the question marks, and maybe make any other pertinent comments, it would be appreciated.
023178009
(basic 009)
043905205
113905205T
113905205AA
(standard SVDAs?)
311905205L
(SVDA for Type 3?)
ZV/JU 4R3 (cast iron)
(from a 36hp?)
Thanks for any input on confirming what they are and what the best use is for them. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sun Sep 26, 2021 12:04 pm Post subject: Re: distributor info |
johnnyvw164 wrote: |
023178009
(basic 009)
043905205 (Beetle 1974 * 1600 Federal Manual Trans)
113905205T (Beetle 1970 * 1600 Manual Trans)
113905205AA (Beetle 1969 * 1500 Auto-Stick Trans)
(standard SVDAs?)
311905205L (Type 3 69-69 * 1600 Fuel Injected Manual Trans)
(SVDA for Type 3?)
ZV/JU 4R3 (cast iron) (Type 3 1964 * 1500S)
(from a 36hp?)
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Sep 26, 2021 12:45 pm Post subject: Re: distributor info |
Ah, that's great info Glenn, thanks! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Sep 26, 2021 11:38 pm Post subject: Re: distributor info |
Glenn wrote: |
023178009
(basic 009)
113905205T (Beetle 1970 * 1600 Manual Trans) 1969 and for Bus too
(standard SVDAs?) the 043 and 113 AA are SVDA the 113 T vacuum advance only.
(SVDA for Type 3?)
(from a 36hp?) It does use 36 hp Beetle points and the vacuum canister matches the specs for a 36 hp Beetle but has a slip on vacuum nipple.
_________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Frederik Samba Member
Posted: Mon Sep 27, 2021 1:44 am Post subject: Re: distributor info |
(from a 36hp?) |
I guess it's a typo, but ZV/JU 4R3 is a aluminum vacuum only distributor, ZV/JCU 4R3 is the cast iron -64 1500s |
Posted: Mon Sep 27, 2021 3:40 pm Post subject: Re: distributor info |
Well, apparently I can't read my own writing...LOL
The correst number on that cast iron dist. is: ZV/PAU 4R5 |
Glenn Mr. 010
Posted: Mon Sep 27, 2021 4:11 pm Post subject: Re: distributor info |
61 to 64 40hp _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Sep 27, 2021 4:54 pm Post subject: Re: distributor info |
Again, thanks!!
How does the advance curve on that compare to a 205? Am I correct to assume it's vacuum advance only? |
Posted: Mon Sep 27, 2021 8:27 pm Post subject: Re: distributor info |
The ZV/PAU 4 R 5 is a vacuum advance only and needs the vacuum signal from a 28 PICT series carburetor. The 113 T (all distributors are 205's) needs a vacuum signal from a 30 PICT series Solex carburetors so the two can't really be compared. _________________ Roads Scholar &
Posted: Tue Sep 28, 2021 3:25 am Post subject: Re: distributor info |
Thanks for that info! |
