Hammerhead69 Samba Member
Posted: Thu Sep 09, 2021 1:44 pm Post subject: ‘71 Standard firing order |
Hey all, long time no see. My current project on the Beetle is installing electronic ignition with a Pertronix distributor. In the process I noticed that the firing order on the current distributor is completely opposite of what the diagrams show ( #1 is where #3 should be, # 2 is where #4 should be). It runs fine in this order but why is it like this? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Thu Sep 09, 2021 1:52 pm Post subject: Re: ‘71 Standard firing order |
The engine firing order is 1-4-3-2 clockwise and that doesn't change.
Don't get confused with the spark plug wire location on the distributor cap. Once you have located #1, the wires go 1-4-3-2 clockwise. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 09, 2021 2:11 pm Post subject: Re: ‘71 Standard firing order |
Glenn wrote: |
Don't get confused with the spark plug wire location on the distributor cap. Once you have located #1, the wires go 1-4-3-2 clockwise. |
Thanks. Any idea why the distributor is aligned completely opposite of what the diagrams show?
This is what I’ve got….(looking from back to front)
Glenn Mr. 010
Posted: Thu Sep 09, 2021 2:15 pm Post subject: Re: ‘71 Standard firing order |
Yes, the driveshaft that spins the distributor has 11 teeth, so it's off a few teeth. This doesn't matter as long as you can turn the distributor body when setting the ignition timing.
Member #1009
#BlueSquare |
Posted: Thu Sep 09, 2021 2:20 pm Post subject: Re: ‘71 Standard firing order |
Alright. That helps me a lot. As usual, Thanks for the info! |
Posted: Mon Sep 27, 2021 3:59 pm Post subject: Re: ‘71 Standard firing order |
Ok so I’m back at this project. Can someone tell me what these wires are for? Particularly the fused one. The pos. side of the coil only has 3 prongs but I have 4 wires including the one from the new distributor. The opened up the fused link on the fused wire & the fuse was blown. I traced that particular wire & it connect s to something in what looks like the front of the transmission.
Glenn Mr. 010
Posted: Mon Sep 27, 2021 4:08 pm Post subject: Re: ‘71 Standard firing order |
The blue wire goes fro the choke and idle cut off to the positive side of the coil.
The fussed wire 8s for the reverse lights and also goes to the positive side of the coil.
The thicker black wire from the wiring harness is the keyed positive and goes to the positive side of the coil.
The wires from the pertronix, black to coil negative and red to coil positive _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Sep 27, 2021 4:25 pm Post subject: Re: ‘71 Standard firing order |
Thanks Glenn. Since there’s only 3 terminals on the positive side of the coil & I have 4 wires is it safe to splice any 2 of those wires together? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Sep 27, 2021 4:45 pm Post subject: Re: ‘71 Standard firing order |
You want the idle cutoff and choke on the same wire.
If the drive on the bottom of the distributor is installed backwards, it will move the wires 180*
You can remove the distributor, use a pick and take the circle spring off, and use a drift to remove the drive ears. Spin it 180* and reinstall.
But really it doesn't matter as long as the wires are in the right order starting at the compression stroke on #1. It only makes a difference if you have a vacuum advance distributor and it's hitting the case. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 27, 2021 4:52 pm Post subject: Re: ‘71 Standard firing order |
Hammerhead69 wrote: |
Better to use something like this:
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Glenn Mr. 010
Posted: Mon Sep 27, 2021 5:27 pm Post subject: Re: ‘71 Standard firing order |
That works. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Oct 05, 2021 3:06 pm Post subject: Re: ‘71 Standard firing order |
Ok. So I got the new Bosch coil & the Pertronix distributor in. I then got the timing in range using the test light method. We got it started yesterday but it wouldn’t idle & it was randomly dropping a cylinder & now it won’t start at all. I pulled a plug to see if it was getting fire & now I’m completely baffled. When the key is turned from “off to on” without actually turning the engine over the plug will spark but when the engine is turned over there’s no spark. Has anybody ever seen anything like that? |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Tue Oct 05, 2021 4:48 pm Post subject: Re: ‘71 Standard firing order |
Give Speedy Jim's page on troubleshooting engine start up a read: http://www.speedyjim.net/htm/eng_strt.htm
Remove all four spark plug wires from the distributor cap and follow the steps in the section "The test" to identify where #1 plug wire goes on the cap. Install the remaining wires CW around the cap in the order 1-4-3-2.
Oh, and replace the distributor cap with a solid colored one and not the cheap see-thru type. _________________ AshMan40
Posted: Tue Oct 05, 2021 5:15 pm Post subject: Re: ‘71 Standard firing order |
ashman40 wrote: |
Oh, and replace the distributor cap with a solid colored one and not the cheap see-thru type. |
Thanks for the link, I’ll check it out. As far as the cap goes, I replaced the entire distributor & cap with the Pertronix electronic ignition setup, & that’s when my problem started. |
Glenn Mr. 010
Posted: Tue Oct 05, 2021 5:18 pm Post subject: Re: ‘71 Standard firing order |
Another endorsement for Pertronix _________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Tue Oct 05, 2021 5:19 pm Post subject: Re: ‘71 Standard firing order |
i have heard this scenario before !!!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Starbucket Samba Member
Posted: Wed Oct 06, 2021 7:31 am Post subject: Re: ‘71 Standard firing order |
Make sure the pos. side of coil is getting 12 volts as the electronic "points" don't like lower voltage. |
Posted: Wed Oct 06, 2021 7:46 am Post subject: Re: ‘71 Standard firing order |
Check this...
Remove center wire from distributor cap and hold it near ground (2mm) so you can confirm ignition coil is sending a spark.
With the ignition ON, rotate the crank pulley by hand and watch for a (blue-white) spark to jump the gap from the wire end to ground as the rotor passes each of the four posts positions in the distributor cap. Rock the crank back and forth around the point where the spark fires and it should throw a spark each time the electronic points trigger the coil to spark. Repeat for each post on the cap. This confirms the electronic points are triggering the coil to spark as the rotor passes each of the posts.
Have someone crank the engine while you still hold the coil wire near ground and you should see the coil sparking at regular intervals. A starter bump switch is a big aid if you are by yourself. Odd spark intervals while cranking means one or more cylinders are not firing and you have a problem with the electronic points and its magnetic pickup.
If there is no spark from the coil wire while cranking... measure the voltage at the #15 (+) terminal of the ignition coil while the engine is not cranking and while it is cranking. You should see a voltage drop while cranking but if the voltage drops below 11.0v while cranking it will likely result in the electronic points no longer working. This is a common problem with old wiring creating high resistance such that insufficient current makes it to the coil/points.
To confirm it is a problem with voltage reaching the coil... run a wire from the battery positive post (use your battery jumper cables) and power the coil #15 directly from the battery. This is the highest voltage you can get. Test the voltage while cranking. If it still drops below 11.0v it means you have a weak/old battery (or a starter that is drawing too much current away from the battery). If powering the coil from the battery allows the coil to spark, reconnect everything and try to start the engine while the coil is powered by the battery. If you get the engine running when the coil is powered directly from the battery you know the no spark while cranking was caused by lack of current making it to the coil. _________________ AshMan40
