dave1 Samba Member
Joined: September 12, 2003 Posts: 478 Location: United Kingdom, London
Posted: Mon Sep 27, 2021 3:04 pm Post subject: 65 RHD squareback |
Hi all,
I would like to know what looks like a metal contact/connector which are attached to each front door pillar at the bottom
Thanks Dave |
Tvättbjörn Samba Member
Posted: Mon Sep 27, 2021 3:10 pm Post subject: Re: 65 RHD squareback |
67 model has a backrest release function when you open the doors. Not sure about the earlier ones.
Post a picture of the part you are talking about. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
dave1 Samba Member
Posted: Tue Sep 28, 2021 12:29 pm Post subject: Re: 65 RHD squareback |
Hi all,
Yes that's the bit of kit. How does it work. Does it release the front upper seat to move forward?
Thanks Dave
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Sep 28, 2021 4:01 pm Post subject: Re: 65 RHD squareback |
It does release the front seat back so that it can be moved forward to allow access into the rear seat. This keeps the seat back in place during hard braking (while the door is closed, anyway) and allows for effortless access to the rear seat area when the door is open. |
dave1 Samba Member
Posted: Fri Oct 01, 2021 10:37 am Post subject: Re: 65 RHD squareback |
Hi all,
Thank you for your replies & pictures. How does it work? Should you be able to push the protruding bar down to release the seat? If so mines stuck solid
Thanks Dave |
Posted: Fri Oct 01, 2021 10:41 am Post subject: Re: 65 RHD squareback |
You've got the rough idea - push the lever closed and it releases the seat back lock.
I've had to take them apart in the past due to corrosion/dirt, etc. Or the cable is bad.
Another thing to check: Your carpet may be interfering with the operation if the covers are missing/damaged - there's a spring and lever under the carpet on the footwell - around the corner from the lever on the A pillar/door jamb - semi-adjacent to the vent at the floor - above and a bit forward.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Oct 01, 2021 11:14 am Post subject: Re: 65 RHD squareback |
Do you have the 80" long cables connecting the door releases to the seats! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Fri Oct 01, 2021 5:58 pm Post subject: Re: 65 RHD squareback |
dave1 wrote: |
Hi all,
Thanks Dave |
It releases it when you open the door.
Open door, bar moves outward and pulls on the cable, pulling the locking piece inward on the seat so the seat back can go forward.
When the door is shut, the seat back is locked so it won't go forward on you in an accident.
If the piece in the door jam is moving and pulling on the cable, you might just need to adjust where it connects underneath the seat. It can be slid back and forth under the seat and locked in place with a wing nut to set it correctly to lock/unlock when the door opens/closes.
As someone else asked, do you have the cables in place and hooked to the seat? _________________ How to Post Photos
dave1 Samba Member
Posted: Sun Oct 03, 2021 7:00 am Post subject: Re: 65 RHD squareback |
Hi all,
Thank you all for the info/updates. I have now investigated the door switches for the front seats & manage to free the lever now operating. I'll attach pictures of car
Posted: Sun Oct 03, 2021 8:52 am Post subject: Re: 65 RHD squareback |
Good looking 'leather' dash.
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4189 Location: Pasadena CA/DTLA soon China
Posted: Sun Oct 03, 2021 2:43 pm Post subject: Re: 65 RHD squareback |
dave1 wrote: |
Hi all,
Thanks Dave
You sould clean up that rust on those bolts, before they "FREEZE" in rust. I belive stainless are available or good used ones.
Beautiful square, I wish it was sunroof!
Martin
allwagons
1965 sunroof Variant _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Posted: Mon Oct 04, 2021 8:35 am Post subject: Re: 65 RHD squareback |
ALLWAGONS wrote: |
You sould clean up that rust on those bolts, before they "FREEZE" in rust. I belive stainless are available or good used ones. |
That hinge has been worked on a bit - there at least two weld spots and two additional screws just above the hinge. |
