Has anyone had trouble setting up Kadrons?
Page: Previous  1, 2, 3
esde
esde is offline
PostPosted: Mon Sep 27, 2021 7:45 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Clatter wrote:
It's easy enough to check what size they are once you get them in-hand.
True, but for the money spent the customer shouldn't have to measure them. It just adds another step to trouble shooting. "Well hey, that jet might be too big or too small, or maybe they aren't the same size. But we don't know what's right or wrong because we don't know what they were supposed to be"
I ordered some carbs from Blackline a few years ago. Came back with a build sheet listing every jet, throttle plate settings, and the float height. Aircooled.net drops a note in the box listing the jets when you pay him to set them up for you.
I realize I'm way O/T so I'll retreat to the corner.
modok wrote:
Bug53
Bug53 is offline
PostPosted: Mon Sep 27, 2021 8:35 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
We should start a separate thread on commercial shop carburetor builds and harvest all the data we can. LOL!
Once I get back to my air cooled girl and measure the mains I will report back.
modok
modok is offline
PostPosted: Mon Sep 27, 2021 11:42 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
I remember this was a good one, covered most of the kadron specific stuff
https://www.thesamba.com/vw/forum/viewtopic.php?t=700554
Bug53
Bug53 is offline
PostPosted: Tue Sep 28, 2021 7:09 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Update.
Just prior to packing them up for the return trip back to Cali. I measured all the mains. So this is what we have. 61 Idles, 130 mains, H150-2 air correction.
Lingwendil
Lingwendil is offline
PostPosted: Wed Sep 29, 2021 11:46 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
61 idles are pretty durn big Confused
Honestly I bet it would have run well on 55's.
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
unclebilly
unclebilly is offline
PostPosted: Wed Sep 29, 2021 9:11 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
I have Kadrons on my Baja.
Make sure you loctite your air cleaner wing nuts on, one of my air cleaner lids came off and my engine injested dirt.
The kadron being right beside my tire didn’t help anything.
modok
modok is offline
PostPosted: Wed Sep 29, 2021 9:25 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Could happen to anybody.
I use locknuts
having to safety wire your wingnuts is just ironic, and having to loctite your wingnuts is no fun, so we invent the safety wingnut.
The final evolution..... of the wingnut that looks like you could turn it with your fingers but you actually can't.
lets get a wrench Razz
And for maximum pleasure.... ratcheting wrench!
oprn
oprn is offline
PostPosted: Thu Sep 30, 2021 4:44 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Common problem. My Buggy came to me in that condition, the right air cleaner was rattling around loose. The right side of the engine was burning oil badly otherwise I would still be running that 1600 DP.
Every Kadron buyer should be told up front this is a problem.
We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
Bug53
Bug53 is offline
PostPosted: Wed Oct 20, 2021 1:08 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
is a 132 main jet in Kadrons for my 1600 unthinkable ?
modok
modok is offline
PostPosted: Wed Oct 20, 2021 1:34 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
130 is normal IMO
Bug53
Bug53 is offline
PostPosted: Wed Oct 20, 2021 10:30 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
modok wrote:
130 is normal IMO
That's my opinion too but i went down to 127 and the cruise / light throttle popping was worse.
I think 132 is too rich but I may try
Alstrup
Alstrup is offline
PostPosted: Wed Oct 20, 2021 11:35 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Bug53 wrote:
modok wrote:
130 is normal IMO
That´s a clear indication that something else is off or wrong. You DO NOT cruise on the main circuit unless your cruise speed is above 50-60 mph dependant on the entire set up.
https://www.thesamba.com/vw/forum/viewtopic.php?t=435993
Bug53
Bug53 is offline
PostPosted: Wed Oct 20, 2021 5:53 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Absolutely correct. It did nothing measurable for the condition.
Cranking up the accelerator pumps did a measurable improvement prior to this which makes no sense. The the results were good.
How far in are some of the other Kadron acc. Pump adjusters on other cars?
Kaddie Shack gave me the carbs back with the plastic nuts barely touching.
I slowly turned mine in one turn at a time. Now they have a little more than 1/8” of thread showing.
I know I need to measure the actual output but one turn at a time “seat of the pants” tuning is to satisfy curiosities.
Lingwendil
PostPosted: Wed Oct 20, 2021 8:23 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
I ended up needing to turn them in so far that I needed spacers to get adequate squirt from them. I used the tips that screw onto the plug wire end of some spark plugs. Before that I wasn't able to tighten the adjustment nuts in enough.
Bug53
Bug53 is offline
PostPosted: Wed Oct 20, 2021 8:59 pm    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Wow!
Were these the Brazilian shit I have or an OG set?
Bug53
Bug53 is offline
PostPosted: Thu Oct 21, 2021 4:31 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
As far as Jetting I am basically at sea level. S0 my 130/60 setup as delivered from KS should do the trick? I think 55 would be better but that what KS seems to believe will work.
Lingwendil
PostPosted: Thu Oct 21, 2021 8:01 am    Post subject: Re: Has anyone had trouble setting up Kadrons? Reply with quote
Bug53 wrote:
Wow!
Brasilian is OG, if I'm not mistaken Confused
That's where they all came from originally. Anything else is basically an Empi knockoff. My set are fairly old, but have had a couple items replaced, If I'mnot mistaken the rebuild kits in them don't behave the same as far as the diphragms in the accelerator pumps, so sometimes you need to shim the adjustment nut for more stroke.
Got the tip from the Kadron manual by Frank Camper-
I'm sending you a PM too,if you don't mind Smile
Page 3 of 3
