2nd gear hesitation?
KOMBI NIKO
KOMBI NIKO is offline
PostPosted: Mon Sep 20, 2021 10:48 pm    Post subject: 2nd gear hesitation? Reply with quote
Hi guys, I'm having probs with a flat spot/ hesitation once I change down into 2nd and take off again. its only few a few seconds but dam annoying.
My set up is a freshly build 1641cc single port motor running a solex 31-3 pict carb, and a magaspark2 distributor. The carbie is running a 130 main jet and 55 fuel correction jet. No vacuum advance hooked up. Could this be a jetting issue or perhaps the magaspark? At idle it runs perfect and with the o2 meter hooked up its right in the middle for lean/richness. One thing I've noticed is if I turn the idle mixture screw all the way in at idle it doesn't kill the motor. Have checked for vacuum leaks and exhaust leaks all good.
https://www.instagram.com/demop_garage/
https://www.facebook.com/Demopgarage/
https://www.youtube.com/@DEMOPGARAGE/featured
johny__utah
johny__utah is offline
PostPosted: Tue Sep 21, 2021 3:08 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Sounds like a ignition/spark problem. I would say your condenser but it being magnaspark. Check your sparkplug gap.
1956 L31
1961 L346 L347
1963 L380 L289
Culito
11010101
Culito is offline
PostPosted: Tue Sep 21, 2021 3:22 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Vacuum advance never hurts on a heavy bus.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
KOMBI NIKO
PostPosted: Tue Sep 21, 2021 3:32 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
no vacuum port on the magnaspark Sad oh its a single cab too.
KOMBI NIKO
PostPosted: Tue Sep 21, 2021 3:34 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Cheers will look at that, ive also tried a 34 pict with the same results.
KOMBI NIKO
PostPosted: Sun Sep 26, 2021 4:11 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
So spark plug gaps are good, Went for another drive to try and work out when its spluttering and its after coasting and getting back on the gas. Feels like its not getting enough fuel for a few seconds then its all good again. On idle its fine with good throttle response.
Danwvw
Danwvw is offline
PostPosted: Sun Sep 26, 2021 4:42 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Probably something changed maybe you went to a 1 1/2" Header should be 1 3/8", perhaps you installed a cam? Try a different distributor, that is easy.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
busdaddy
busdaddy is offline
PostPosted: Sun Sep 26, 2021 5:03 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Lets discuss your float level and fuel pressure, something's not quite right with that mixture screw.
Слава Україні!
KOMBI NIKO
PostPosted: Sun Sep 26, 2021 10:54 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
the og header was the smaller, then because I planed to go with the 34 pict I modded the end to a 1 1/2". Once the the 34 didn't work I went back to the 30/31 pict with that alloy adapter. The cam is stock. I will try another distributor once we are allowed to travel again.
KOMBI NIKO
PostPosted: Sun Sep 26, 2021 10:58 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Yes, float level was my next thing to look at, how does one check this or adjust the level? I think there's one washer under the needle/seat. I don't think fuel pressure is an issue as its a brand new pump.
busdaddy
busdaddy is offline
PostPosted: Mon Sep 27, 2021 8:15 am    Post subject: Re: 2nd gear hesitation? Reply with quote
Brand new from where?, many aftermarket pumps put out some wild pressures.
Check it by disconnecting or pinching the fuel line to the carb and then removing the top, measure the distance from the top lip of the carb body to the top of the fuel in the bowl.
Слава Україні!
Danwvw
Danwvw is offline
PostPosted: Mon Sep 27, 2021 6:47 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
1641cc Bus would be best with a 1 3/8" Header or even a stock Bus Exhaust. That too big of exhaust and maybe a clogged intake manifold preheat riser is likely the problem.
My 1679: Building a Stock ish Type 1 engine for the 1971 VW Bus?
KOMBI NIKO
PostPosted: Tue Sep 28, 2021 12:59 am    Post subject: Re: 2nd gear hesitation? Reply with quote
It's running a stock 1500 exhaust, I can change out the manifold for a 1 3/8" one to see. Also I noticed the right side intake preheat tube is colder than the left side, might be blocked.
KOMBI NIKO
PostPosted: Tue Sep 28, 2021 1:01 am    Post subject: Re: 2nd gear hesitation? Reply with quote
cheers I will do this check. The fuel pump was from mick motors (Australia)
Danwvw
Danwvw is offline
PostPosted: Wed Sep 29, 2021 11:03 am    Post subject: Re: 2nd gear hesitation? Reply with quote
On a working preheat one side will be quite hot compared to the other. yeah it could be something like accelerator pump in the carb or even the engine is just cold.
KOMBI NIKO
PostPosted: Wed Sep 29, 2021 6:53 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
I've changed out the accelerator pump gasket and it does work well. Motor is off the choke when I drive it. One thing is the top of the manifold near the carbie is super cold once its warmed up.
Danwvw
Danwvw is offline
PostPosted: Thu Sep 30, 2021 1:32 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
Try to hook up the warm air to the carb if you still have the oil bath air cleaner etc... A new intake manifold & heat risers might help. One other thing would be to do some kind of single port dual carb set up better yet just get dual port heads for it and run dual 40 webers or Dell 36's. with dual port offset intake manifolds that don't need preheat because they bolt to the heads.
The engine can be made into a 1679cc by just changing to 88mm ThickWall Piston & Cylinders and running 92mm spec Dual Port Heads. Usually when modifying a single port to a dual port the 71 dog house fan shroud gets installed along with the better oil cooler they had but it's not totally necessary if you don't drive it too long too hard that could make it overheat with the single port's smaller cooling fan and it's Iron Oil Cooler. $25 "PAIR VW DUAL PORT CYLINDER TINS BLACK BUG BUS GHIA THING 113119303J 113119304H" e-bay
KOMBI NIKO
PostPosted: Thu Sep 30, 2021 7:53 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
[quote="Danwvw"]Try to hook up the warm air to the carb if you still have the oil bath air cleaner etc... A new intake manifold & heat risers might help. One other thing would be to do some kind of single port dual carb set up better yet just get dual port heads for it and run dual 40 webers or Dell 36's. with dual port offset intake manifolds that don't need preheat because they bolt to the heads.
The engine can be made into a 1679cc by just changing to 88mm ThickWall Piston & Cylinders and running 92mm spec Dual Port Heads. Usually when modifying a single port to a dual port the 71 dog house fan shroud gets installed along with the better oil cooler they had but it's not totally necessary if you don't drive it too long too hard that could make it overheat with the single port's smaller cooling fan and it's Iron Oil Cooler. $25 "PAIR VW DUAL PORT CYLINDER TINS BLACK BUG BUS GHIA THING 113119303J 113119304H" e-bay[/quot
Ill give that a go once I check the float level. The motor has only done 60 miles, so its brand new. You can see the single cab run here, https://www.youtube.com/watch?v=w3jDkns8t8s
KOMBI NIKO
PostPosted: Thu Sep 30, 2021 10:23 pm    Post subject: Re: 2nd gear hesitation? Reply with quote
just checked the fuel level with the top off and the float in place it was 1" or 25mm with the float removed it was 30mm. Not sure if that's too low?
