Oil Pump Help?
Autobeetle555
Autobeetle555 is offline
PostPosted: Mon Sep 27, 2021 6:18 pm    Post subject: Oil Pump Help? Reply with quote
Have an AE case engine, believe it to be in stock 1600 configuration. When I bought it, the oil pump housing was installed but the gears had fallen out and were lost.
3 rivet cam.
According to the case age chart, this should be a 71-73 1600 DP. I largely agree with this.
I’m trying to figure out what to do for an oil pump. Bought a 26mm, and a 30mm. The 26mm is listed for 71+ model year, in addition to being 26mm.
The 26mm has the same size gears as the Schadek that fell apart; but the gears in the new 26mm are taller.
I intend on replacing the entire pump; but I’m just looking for some advice on which pump is the correct one to use, regardless of what I’ve purchased.
I’ll try to post a pic of the empty oil pump.
Autobeetle555
PostPosted: Mon Sep 27, 2021 6:24 pm    Post subject: Re: Oil Pump Help? Reply with quote
[/img]
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Sep 27, 2021 6:31 pm    Post subject: Re: Oil Pump Help? Reply with quote
So your case has 8mm studs. Your options are flat cam or dished for the pump. Remove the old pump case and look inside and see which cam you have.
26mm is all you need for a stock engine.
Glenn
Member #1009
#BlueSquare
Autobeetle555
PostPosted: Mon Sep 27, 2021 6:45 pm    Post subject: Re: Oil Pump Help? Reply with quote
Dished?
Autobeetle555
PostPosted: Mon Sep 27, 2021 6:48 pm    Post subject: Re: Oil Pump Help? Reply with quote
Mr. 010
Glenn is offline
Flat.
Dished cams are 4 rivet.
Glenn
Member #1009
#BlueSquare
Autobeetle555
PostPosted: Mon Sep 27, 2021 6:52 pm    Post subject: Re: Oil Pump Help? Reply with quote
Here’s the pump.
Mr. 010
Glenn is offline
PostPosted: Mon Sep 27, 2021 6:56 pm    Post subject: Re: Oil Pump Help? Reply with quote
You have a oil pump for a dished cam.
This is the oil pump you want: 111-115-107-AKHD
https://www2.cip1.com/c24-111-115-107-akhd/
Glenn
Member #1009
#BlueSquare
Autobeetle555
PostPosted: Mon Sep 27, 2021 7:52 pm    Post subject: Re: Oil Pump Help? Reply with quote
Thank you so much.
Cusser
Cusser is offline
PostPosted: Tue Sep 28, 2021 9:43 am    Post subject: Re: Oil Pump Help? Reply with quote
I really like the CB Performance Maxi2 combination pump/filter, has 26mm gears. CB sells two versions, for flat and for dished camshaft gears.
mikedjames
mikedjames is offline
PostPosted: Sun Oct 03, 2021 12:43 am    Post subject: Re: Oil Pump Help? Reply with quote
The 26mm Schadek pump in the CB Maxi 3 comes with the drive shaft set up for dished cam., it can be modified to fit flat cam gear by driving the shaft in until the pump cover end of the shaft is flush with the face of the gear. It is delivered 2.0mm below the surface of the gear.
Ancient vehicles and vessels
Autobeetle555
PostPosted: Mon Oct 04, 2021 8:35 pm    Post subject: Re: Oil Pump Help? Reply with quote
Can I use a 30MM geared pump if I want to?
Good or bad?
67rustavenger Premium Member
67rustavenger is online now
PostPosted: Mon Oct 04, 2021 9:04 pm    Post subject: Re: Oil Pump Help? Reply with quote
Good or bad?
Use a 26mm pump.
I do in a 2180 engine. And never have any oil pressure issues!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
