plywoodkid Samba Member
Joined: April 17, 2018 Posts: 217 Location: Ventura County, CA
Posted: Sun Sep 26, 2021 10:06 pm Post subject: Original Location of Transmission Ground Strap |
All,
1970 Bus. Original Transmission (Been Rebuilt).
I know there has been past threads regarding the Transmission Grounding Strap. However, I cannot find where the exact original placement of the strap is.
I also checked the Bentley. Maybe I'm missing something.
I realize that it probably doesn't matter since you can ground anywhere on the tranny to the chassis.
Does any one have a picture or can explain the original location points for installation on Early Bays?
I would appreciate it. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Sun Sep 26, 2021 10:43 pm Post subject: Re: Original Location of Transmission Ground Strap |
You can just about see it in your owners manual:
Do yourself one better, and inspect the studs on your transaxle for a clean mounting point and enough threads left on the studs to engage the nut with the strap in place. A cone-shaped wire wheel in a Dremel is my favorite way to clean ground strap mounting points. Sometimes the holes in new straps are large enough to warrant a fender washer.
www.airschooled.com |
Posted: Sun Sep 26, 2021 10:50 pm Post subject: Re: Original Location of Transmission Ground Strap |
Left side of the nose cone about halfway up, to a stud on the left side of the torsion tube. |
Posted: Mon Sep 27, 2021 7:52 pm Post subject: Re: Original Location of Transmission Ground Strap |
Thanks All.
Finished Product.
Torque: 14 lbs on 13 mm nut on tranny
Torque: 25 lbs on 17 mm nut on torsion mount
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Mon Sep 27, 2021 9:24 pm Post subject: Re: Original Location of Transmission Ground Strap |
stud is on the trailing arm mount _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Mon Sep 27, 2021 9:30 pm Post subject: Re: Original Location of Transmission Ground Strap |
skills@eurocarsplus wrote: |
stud is on the trailing arm mount |
correct.
From Samba Gallery
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Sep 27, 2021 9:53 pm Post subject: Re: Original Location of Transmission Ground Strap |
Thanks guys……I finally found the stud. It’s on the passenger side, so I have to swap sides.
Should the end mounted to the transmission go to the 13 mm bolts or the 11mm bolts? |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Tue Sep 28, 2021 1:19 am Post subject: Re: Original Location of Transmission Ground Strap |
plywoodkid wrote: |
The transmission mount bolt, where you first connected the ground strap, is no good at all since it's isolated
from the chassis (i.e. ground) by rubber. The stock location for the strap is on one of the 8 mm studs (which
I suppose you mean above by "13 mm bolt") on the final drive housing. _________________ '67 bug: seized by the authorities
SGKent Samba Member
Posted: Tue Sep 28, 2021 6:14 am Post subject: Re: Original Location of Transmission Ground Strap |
plywoodkid wrote: |
do it like the photo. The stud should be on the left side, driver side arm bracket. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Tue Sep 28, 2021 10:10 am Post subject: Re: Original Location of Transmission Ground Strap |
All,
Thanks. I just corresponded a bit with SGKent.
What appears to be different, is that my chassis stud is on the passenger side vice the driver’s side.
With that said, I would assume that this doesn’t change the logic of the connection.
The Chassis connection is now a no brainer, it’s the transmission connection spot that is in question. |
Elibomrod Samba Member
Posted: Tue Sep 28, 2021 10:11 am Post subject: Re: Original Location of Transmission Ground Strap |
Noticed that your ground strap won’t work as fitted in the picture.
You have bolted to the part of the transmission Mount which is insulated from the main body with rubber.
Would only work on body side of mount, or ideally as per pictures later on in thread. |
Posted: Tue Sep 28, 2021 10:14 am Post subject: Re: Original Location of Transmission Ground Strap |
Oops repeat should have read the later posts |
mikewire Samba Member
Joined: March 22, 2010 Posts: 805 Location: San Antonio, TX
Posted: Tue Sep 28, 2021 11:44 am Post subject: Re: Original Location of Transmission Ground Strap |
plywoodkid wrote: |
All,
Mine is also on the passenger's side...maybe it's an early Bay thing? Here's another angle:
_________________ -Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue |
Posted: Tue Sep 28, 2021 1:16 pm Post subject: Re: Original Location of Transmission Ground Strap |
Thanks Mike, I was beginning to think I was losing it. Looks like yours is on the 2nd Bolt of the case of the transmission.
I’ll swap it out tonight. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Tue Sep 28, 2021 8:09 pm Post subject: Re: Original Location of Transmission Ground Strap |
I just cleaned and tightened mine. I recall it being on the passenger side as well. ‘71 bus. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Tue Sep 28, 2021 9:02 pm Post subject: Re: Original Location of Transmission Ground Strap |
It's on the passenger side on my 68 as well. Been messing with brake lines back on that passenger rear wheel and the strap occasionally gets in the way. _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
Posted: Wed Sep 29, 2021 4:25 pm Post subject: Re: Original Location of Transmission Ground Strap |
Thanks All…..correction
Passenger Side Stud…..
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3579 Location: viroqua wi.
Posted: Wed Sep 29, 2021 4:59 pm Post subject: Re: Original Location of Transmission Ground Strap |
plywoodkid wrote: |
Now that you have it in the correct place take it back off and make it functional. |
Westfalia73 Samba Member
Joined: June 07, 2016 Posts: 121 Location: New Zealand
Posted: Wed Sep 29, 2021 5:49 pm Post subject: Re: Original Location of Transmission Ground Strap |
bsairhead wrote: |
plywoodkid wrote: |
Plus the Ny-Lock nuts above the ones where you have your strap are not doing anything. No threads are in the Ny-Lock part. _________________ 1973 tintop westfalia weekender.
1973 beetle.
1981 Brazilian baywindow kombi. |
Posted: Wed Sep 29, 2021 7:26 pm Post subject: Re: Original Location of Transmission Ground Strap |
I’m missing something on the “make it functional” comment.
Not being sarcastic….I’m not getting it. |
