space Samba Member
Posted: Sun Jul 11, 2021 8:50 pm Post subject: footwell repair |
im doing the bedliner "mod"
and am wondering what peeps are using to fill the factory holes once the pads are gone?
TIA
PS did a goog search and came up empty
T _________________ 82 westy
w:
2.5 JDM Subie
Rear discs
jimf909 Samba Member
Posted: Sun Jul 11, 2021 9:02 pm Post subject: Re: footwell repair |
What's the bedliner "mod"? Bedliner has so many applications nowadays. _________________ - Jim
Abscate wrote: |
kaalualu Samba Member
Joined: June 09, 2011 Posts: 274 Location: Big Island, Hawaii
Posted: Sun Jul 11, 2021 10:27 pm Post subject: Re: footwell repair |
I glued some old tokens underneath, covering holes, then sprayed the undercoating both sides. _________________ '84 Transporter 16" CLK's/LED's/ AT's/Mansi injectors
'86 Wolfey Weekender Westfalia AT's/otherwise stock
Sold-'82 TinTop Diesel |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32627 Location: Reading Pennsylvania
Posted: Mon Jul 12, 2021 3:31 am Post subject: Re: footwell repair |
Wow!
Thanks for the reminder!
Both of my front door foot wells are rusty, not to the point of being gone but they are indeed porous and you can see the road go by.
I need to properly weld in some new metal but I can see that this proper fix probably won't happen before the snow flies in 2021.
So, as a gap stop measure, slow the decay.
I am NOT a fan of silicones or fluid films or other creeping rust stop if you plan to properly make repairs in the future. The residue of such products is quite simply a PITA to clean up!
I think I will simply scrape off the loose scale and hit it with a few coats of Rustoleum Rusty Metal Primer.
I will then probably screw on a sheet of metal with a non silicone caulk between the new metal and rusty step to block water ingress.
Easy to do, easy to remove and no nasty residue to clean up when the time rolls around for a proper repair.
The genius who designed that foot pad attachment should be strung up!
Ghia
Vanagon
Beetle
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Mon Sep 27, 2021 11:57 am Post subject: Re: footwell repair |
djkeev wrote: |
Wow!
Dave |
Have you done your temporary repair yet, Dave? I'd love to see how it turns out. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
leecat Samba Member
Joined: September 13, 2012 Posts: 773 Location: Regina
Posted: Mon Sep 27, 2021 12:12 pm Post subject: Re: footwell repair |
We take out both rubber footwell covers after every trip and clean and dry both metal and rubber. I agree that's an awful design - practically built to guarantee rust. :/ |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Mon Sep 27, 2021 12:18 pm Post subject: Re: footwell repair |
Thanks. My footwells have seen better days but I probably won't do the full repair (who am I kidding--I probably won't get the full repair done) until spring. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Snoww_ Samba Member
Joined: September 25, 2015 Posts: 73 Location: California
Posted: Tue Sep 28, 2021 9:51 am Post subject: Re: footwell repair |
I pulled the rubber out and sealed the holes with some JB Weld SteelStick. A little janky but I'm just going to sand it down and cover with bedliner so ndb to me. _________________ 1991 Tiico Vanagon Carat
1961 Baja Bug |
4Gears4Tires Samba Member
Posted: Wed Sep 29, 2021 7:42 am Post subject: Re: footwell repair |
leecat wrote: |
Huh, I've never even thought about just welding the holes shut. They certainly do trap a lot of water below the rubber pad. I tried gluing it down to keep moisture out, but there's no reason I can't weld the holes shut, cut the plugs off the rubber cover, and then glue the cover down. Might reduce road noise too. _________________ '87 Syncro
