Dr. Denzel Samba Member
Joined: August 13, 2006 Posts: 17 Location: Ohio, U.S.A.
Posted: Tue Sep 28, 2021 12:35 pm Post subject: Front Suspension Arm (Trailing arm) Factory Alignment Tool Gauge |
One of the four front suspension arms on my car is bent. There is a VW factory tool for checking these arms.
Porsche 356 workshops had a similar tool, number P 70, which is similar or identical to the VW one, as the suspension arms appear to be identical. The Porsche one has a heacy base plate on which the suspensio arm is mounted. The illustration I have seems to also show a few other parts, a long cylindrical mandrel and one or two pieces which have a shape similar to a bushing.
What is the VW tool number for this factory tool?
Thank you.
Jim Perrin |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
wimkever Samba Member
Joined: July 16, 2004 Posts: 412 Location: Holland (the Netherlands)
Posted: Tue Sep 28, 2021 1:08 pm Post subject: Re: Front Suspnsion Arm (Trainling arm) Factory Alignment Tool,Gauge |
Dr. Denzel wrote: |
Thank you.
Jim Perrin |
The tool number is VW 282d _________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Tue Sep 28, 2021 1:39 pm Post subject: Re: Front Suspnsion Arm (Trainling arm) Factory Alignment Tool,Gauge |
It might be cheaper to just buy a replacement used arm than to hunt down the tool, and end up buying the arms anyway.
Tools are here:
https://www.thesamba.com/vw/archives/info/tools1.php
Are you thinking of this tool?
Posted: Tue Sep 28, 2021 6:51 pm Post subject: Re: Front Suspnsion Arm (Trainling arm) Factory Alignment Tool,Gauge |
Thanks for the responses, I've learned a lot. The tool I'm thinking of is VW 282b and its other versions.
KTPhil wrote ” It might be cheaper to just buy a replacement used arm than to hunt down the tool, and end up buying the arms anyway.”
In talking to the largest supplier of used 356 parts in the U.S., he said that 90 percent of the Porsche ones (which I believe are the same) he checks are bent! That’s why I’d like to be able to check used arms, rather than just buying a used one without checking it. (I don’t know how common it is for the VW arms to be bent.)
61snrf gave the reference: https://www.thesamba.com/vw/forum/viewtopic.php?t=689146, which I found to be very helpful.
Jim Perrin |
KTPhil Samba Member
Posted: Tue Sep 28, 2021 7:27 pm Post subject: Re: Front Suspnsion Arm (Trainling arm) Factory Alignment Tool,Gauge |
282b is for Buses. You are in a Bug forum. |
Posted: Thu Sep 30, 2021 8:12 am Post subject: Re: Front Suspension Arm (Trailing arm) Factory Alignment Tool Gauge |
KTPhil wrote:
"282b is for Buses. You are in a Bug forum."
You are correct that the tool is for buses. However, I believe it is also for passenger cars based on the following:
I have my VW-factory-issued "Special Service Tools 1957" book in front of me, which was issued August 1957. This book only shows the 282b version of this tool. The description for the tool is:
"Fur VW-Personenwagen und -Transporter".
I checked Goggle Translate, and it said that Personenwagen translates to Passenger Car. |
