meridianVW Samba Member
Joined: May 02, 2010 Posts: 2 Location: Meridian Idaho
Posted: Thu Dec 19, 2019 7:18 pm Post subject: Re: Alignment Specs for all ACVWs |
This is all truly great information and I have a couple of comments.
I agree with the statement about ride height in regards to factory alignment specifications but as we all know we modify ride height regularly in our hobby.
These modified suspensions still need to be aligned and factory specs occasionally need to be modified.
SAI in basic terms is the angle formed by a line drawn through the suspension pivot points and true vertical. To SAI add the camber angle and that yields Included Angle. These 2 angles are very important for collision diagnosis.
I spent 25 years specializing in suspensions, steering and alignments and my recommendations would be to talk to the technician and you should quickly be able to determine if he’s the right guy to align your vehicle.
I’ve used bubble gauges, string system alignment machines and all the way to the new camera systems.
I stopped turning a wrench about 10 years ago and feel your pain in locating a sutible technician.
Awhile back I found a great deal on a Hunter alignment system that I couldn’t pass up. I figure it will take maybe 10-12 alignments to break even.
In the attached lower picture I would need to adjust the rear ride height to correct the rear camber angle.
I believe the tire wear will be minimal if any.
I’ll probably just lower the front!
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Thu Dec 19, 2019 8:50 pm Post subject: Re: Alignment Specs for all ACVWs |
Can't see photos. Getting error code 502. _________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Fri Dec 20, 2019 12:55 am Post subject: Re: Alignment Specs for all ACVWs |
It was mentioned that the alignment isn't that crucial because it's a beetle...
I disagree. If you look at the alignment range for the beetle is waay more exacting than the Golf. Those light front wheels need more attention, and the beetle's suspension is less forgiving for bad alignments.
When the last alignment guy told me he couldn't correct front camber (because he didn't know about the upper eccentric 36 mm cone, I just gave up on the idea of anyone knowing how to do it correctly.
And I would do everything to make it easy for them ( cleaned, all ball-joint threads cleaned and greased, steering box centered with steering wheel, provide them with specs), and yet, still they would screw it up.
I gave up. I'll pay for alignments, but I won't pay someone to DO them anymore.
This is the arrangement I have worked out with the local alignment shop's boss: I pay you a full alignment (130$ for me, instead of 160$ for customer), and you do nothing (except take the cash), and none of your guys have to lift a finger or waste a second. In exchange, I come at the end of the work day, and I can use the lift and alignment machine to do my own alignment, and take the time to do it right (the more wine you bring, the longer you have...). Its a modern electronic machine, no wires, and I just use it as a measuring tool just work with the readout. If they program in an alignment from the databank, it's sure to be wrong and get things mixed up...1300 for 1302, transporter for baywindow, etc... type 3...type what? Those machines just have short memories!
That way I can do it right, take my time, and do things like getting the rear perfect with the "unbolt spring-plate bolts and raise or lower arm before re-tightening" technique. No alignment guy is going to do that.
A buddy has one of those roll-over plates which tells you toe. It's good for little stuff where you know the rest is good, like just changing a steering ball-joint.
Good luck to all for getting what you want out of an alignment shop. |
tzepesh Samba Member
Posted: Fri Dec 20, 2019 1:36 am Post subject: Re: Alignment Specs for all ACVWs |
I totally agree to the importance of well-done alignment. Surprisingly, the database of my local alignment shop has the correct data for VW 1303 (I printed the specs from my book).
However, the reason for my question is different: I have Porsche 944 turbo brakes and Kerscher struts, and I am trying to determine the correct offset for the wheels in order to obtain a scrub area similar to stock. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1597 Location: The South Zone
Posted: Fri Dec 20, 2019 3:19 pm Post subject: Re: Alignment Specs for all ACVWs |
tzepesh wrote: |
Does anybody have the original pics to re-upload them? |
Have you tried e-mailing the guy who originally posted them? Here's his email (from page 1):
dan macmillan wrote: |
If anyone wants a bigger, clearer scan, email me at [email protected] subject ALIGNMENT SPECS |
Here are the specs for a '70 to '79 Type 1 Beetle, from my Bentley service manual (I think they're the same for the Karmann Ghia, but I'm not 100% on that):
Personally, I don't follow these specs to the letter. I was going to post a pic of my own specs, but I see I already did that two years ago back on page 2 (man, how time flies!). I like a bit more negative camber on the front than they want in the manual. The manual states +45' to +15' (+0.75° to +0.25°) as the acceptable range, which is all positive camber. I run the maximum negative camber possible using the stock adjuster: -32' (-0.54°), for better cornering. I run just under negative 1° 30' (1.5°) camber in the back, which is still within the limit, but it's about as far negative as the specs allow.
I also like a fuzz more negative toe (toe out) in the rear tires than the manual calls for. I have mine set at -18' (-0.3°) toe out. I feel this better counteracts the camber thrust from the high negative camber, and also helps promote oversteer, which, in my opinion, is the same thing as reducing understeer- a common malady in rear-engined vehicles. But probably the main reason is that I'm too lazy to crawl under the car and loosen up all the bolts in the spring arms just to take out 3' of toe!
The manual states to set toe with a full gas tank and the car unladen, but I like to put 100 pounds in the driver's seat as well, to better simulate how the car actually sits when I'm driving it (I weigh more than 100 pounds, by the way; I just don't want to ruin my nice upholstery with too many free weights!).
At any rate, the car feels very stable in a straight line, corners well and shows very little wear on the tires with the specs I run on my machine, in case anyone has a similarly modified suspension and wants to copy them. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Posted: Fri Dec 20, 2019 3:24 pm Post subject: Re: Alignment Specs for all ACVWs |
meridianVW wrote: |
SAI in basic terms is the angle formed by a line drawn through the suspension pivot points and true vertical. To SAI add the camber angle and that yields Included Angle. . . |
Thanks for posting this! For years and years I have been using the term "Scrub Angle", when I really meant to say "Included Angle".
Old dog, new trick! _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
Posted: Sat Dec 21, 2019 1:09 am Post subject: Re: Alignment Specs for all ACVWs |
tzepesh wrote: |
However, the reason for my question is different: I have Porsche 944 turbo brakes and Kerscher struts, and I am trying to determine the correct offset for the wheels in order to obtain a scrub area similar to stock. |
I have made very approximate measurements of scrub, by spreading chalk on a dark floor, rolling on to it, and turning the steering from lock to lock. You can gently roll back the wheel, and see the center of the swirl, on the tire and on the ground.
In any case, even if it not accurate, you can see if it's centered on the tire, and, if not, to which side it's offset.
I don't know how much Kersher struts or 944 brakes move stuff, but I know their brakes increase the track by 8 mm, 4 per side. I expect the 944 is even more.
Damn, I'd love to try a beetle with 944T brakes...they worked so great on a much heavier car, I can't imagine on a light beetle...... . |
AlmostHeavenWV_VW Samba Member
Posted: Sun Dec 22, 2019 4:56 pm Post subject: Re: Alignment Specs for all ACVWs |
Likely not the original photos in the beginning of this thread,but here's a post from Glenn
Glenn wrote: |
Print this since I bet not many shops have the specs.
_________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Fri May 21, 2021 12:28 pm Post subject: Re: Alignment Specs for all ACVWs |
Did I read this right that a 74 standard is speced with positive camber in the front? _________________ '74 - front disks/lots more work to do |
SandwichKing Samba Member
Joined: September 04, 2021 Posts: 2 Location: Lake Jackson, TX
Posted: Tue Sep 28, 2021 7:20 am Post subject: Re: Alignment Specs for all ACVWs |
I'm new to this so I hope I'm doing this correctly. If not I'm sure someone will point it out. Oh well, here goes.
I picked up a 1971 Super Beetle back in January. Absolutely love it. First one I've bought.
I replaced all the steering linkage ie. tie rods and ends, center link, and steering damper and bushing and new ball joints. Swapped drums for disc up front and added adjustable struts to lower it 1.5 - 2 inches.
Took it to get it aligned and now the end of the bolt for the ball joint grinds on the inside of the right wheel when making a sharp right turn. Took it back to shop and was told the right wheel has a different backset than the others and/or the wheel is warped.
Any suggestions? |
Ian Samba Moderator
Posted: Tue Sep 28, 2021 2:01 pm Post subject: Re: Alignment Specs for all ACVWs |
Take both front wheels off and measure their offset or look for an ET stamp on the back side. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
sharkskinman Lateral Lunatic
Joined: April 26, 2006 Posts: 4030 Location: Deep In My Own Psyche
Posted: Thu Mar 07, 2024 1:04 am Post subject: Re: Alignment Specs for all ACVWs |
Ok
So with Widened or shortened beam!
And with the wheels (toe in) correct between each other
How do you make sure the Wheels are Straight to the Car/Beam
And can You use a Simple Magnetic Angle Finder for the Castor _________________ 74 Mexi Swamp Thing. 70 square volksrod (Swamp Rat)..65 C10
Me of Course wrote: |
Extremity is relative to how far your willing to jump |
Ward Cleaver wrote: |
You ever try a pink golf ball, Wally? Why, the wind shear alone on a pink golf ball can take the head off a 90-pound midget at over 300 yards |
PS4 "NKOGNEATO" |
