DuaneVW Samba Member
Joined: October 14, 2021 Posts: 2 Location: Edmonton, Alberta, Canada
Posted: Thu Oct 14, 2021 2:59 pm Post subject: E25652 Engine Number - what type of engine is this? |
I have an engine that has the number E25652 as its identifier, what type of engine is this and what does the E represent? Here is a photo of the number and there also is a "W 5C" showing below it as well?
Here are more photos showing the engine itself, I hope they help in identifying what engine this is and why the number starts with a letter “E”?
Thank you,
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Thu Oct 14, 2021 3:20 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
How about a picture of the whole engine as well. Something doesn’t look right to me.
In fact the more I look at it the less it looks like any air cooled VW I have seen. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 767 Location: New England
Posted: Thu Oct 14, 2021 3:26 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
It looks like the original number was ground off. If the number is the original number it would be for a 1956 industrial engine, not sure what the "E" is for (exchange?). The only other 5 digit number I'm aware of that was stamped on that type of case would be the early Porsche engines. The Porsche numbers had the prefix "P" though, and asterisks if i remember correctly. The number could also have nothing to do with VW at all. The W5 and other miscellaneous stamps are factory inspection marks. More pics would help with identification. Any idea what it was running in last?
Dale M. Samba Member
Posted: Thu Oct 14, 2021 3:27 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
Looks like early 1200cc, 36 horse block... Don't think VW ever produced a "E" series engine... But they did produce a "E0" series around "67" to "70"...
Probably a reman engine number... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Fri Oct 15, 2021 6:06 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
I have added in more photos showing all angles of the engine. I believe it is a 36hp engine but I cannot figure out how to look up the specifics on the engine (when it was made)?
See the original post up top to see the other photos added.
Thanks! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Oct 15, 2021 6:21 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
It's a 36hp engine. looks really complete. But with the engine numbers ground off and restamped, you might not know what it originally was. Maybe go all CSI with some acid and see if you can bring the original numbers out aka recovering filed off numbers from a murder scene gun. Looks ez enough on CSI Miami..
You could post the numbers on the carb and distributor to get a date range. If you look REAL CLOSE at the distributor bell, there MIGHT be a date stamp on there.. Your looking for a two digit stamping.
Now, this is only relevant if the parts were not swapped at some point. |
Posted: Fri Oct 15, 2021 8:10 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
If you look in the valley on the left side of the generator pedestal you may find a series of numbers cast into the case. If I remember correctly the first number is the day of the month, the second is the month (Jan=1, Feb=2, and so on), the third is the shift/year a1,2, or 3 for the shift and the last number for the year( 1955=5,1956=6 1957=7 and so on). There is another set of numbers below the distributor on the left half of the case. They probably won't match the numbers on the right half of the case but that's normal. Case halves were cast weeks apart sometimes and machined together later.
So a case cast on October 15th 1956, 2nd shift would read 15 10 26. I think. If I'm wrong someone will correct me.
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Oct 15, 2021 8:31 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
Without a doubt you have a restamped indicating it's been rebuilt from someone other than the VW factory. No 36 hp engines had letters in their number- all numbers.
Your coil was manufactured in January of 1968 after 12v became standard so it is a 6v service replacement
Your distributor is most certainly a VJU 4 BR 8 from sometime between 1956-1960. It may hold a clue to the engines originality as above.
The fuel pump is an aftermarket replacement.
It came out of a beetle or perhaps a Ghia based upon the muffler and air filter. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Fri Oct 15, 2021 8:39 pm Post subject: Re: E25652 Engine Number - what type of engine is this? |
The air cleaner looks like a 58-60 type 1. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
