1969 Baja Bug - TX Build
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 10, 11, 12  Next
sailtexas186548
sailtexas186548 is offline
PostPosted: Thu Sep 16, 2021 6:54 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Still welding!
it's more fun loud and dirty
sailtexas186548
PostPosted: Fri Sep 17, 2021 7:49 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Alright the welding on the pan is done, more pics of the same haha but better than nothing. I have to say between the seam sealer, rust, dirt, and other crap I can’t get out the welding process has been less than fun - lots of popping, re cleaning, fires and smoke, dirtying up the torch, etc.
I have seam welded everything except the floor pan to tunnel seam on the inside which I have only stitch welded. I will be seam sealing this area since it is inside the passenger area and shouldn’t have the dirt/water blasting it like the bottom and exterior pan sections.
I was thinking black paint, but have been considering a grey or silver maybe? I haven’t seen many pans that weren’t black
sailtexas186548
PostPosted: Sat Sep 18, 2021 9:40 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Finished welding up the 1 million screw holes from the previous owner, along with some other random stuff, old fender mounts, antenna hole, etc.
I think one more day prepping and I can get some paint on the pan and body. Now to decide on color…
sailtexas186548
PostPosted: Sun Sep 19, 2021 6:21 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Pan is ready for primer, and the body is Getting close to ready, I’m finding a few more spots to touch with the welder but not much.
The bottom of the package tray is the last major area to clean up, I have been putting it off because it is the hardest spot to clean up…
sailtexas186548
PostPosted: Sat Sep 25, 2021 6:59 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Well i think im finished stripping the body. Working on paint selection now- thinking a single stage urethane but I have a decent amount of shopline clear and primer on the shelf so I could do BC/CC also. Not sure the bc/cc is right for this car though, it needs to be easy to repaint (not too concerned about it blending well, just scuff/spray and move on…). Obviously body work and appearance are second to durability
sailtexas186548
PostPosted: Sun Sep 26, 2021 4:29 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
I wasn’t able to find any Ss urethane today (Sunday, as expected) so I made a final pass with a fine wire wheel/cup on every surface, and wiped it down with mineral spirits. It’s looking really good now, another wipe down and it’s ready to spray.
More pics of the same!
sailtexas186548
PostPosted: Fri Oct 01, 2021 7:32 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Well it’s been raining non stop all week and will all weekend… just need a dry day to lay some paint
I ended up getting some cheap ppg epoxy primer and single stage acrylic urethane (white and black), there was a hole in the dam can!
sailtexas186548
PostPosted: Sat Oct 02, 2021 8:37 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
As predicted it has been raining, making it difficult to paint outside!
I have started getting some other parts ready to bolt on, I rebuilt the pedal assembly (2 actually) and painted them, will be able to assemble tomorrow.
sailtexas186548
PostPosted: Sun Oct 03, 2021 7:58 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Still bad weather for paint, it might have to wait for the next cold front.
Pedals went together without much drama (set on the left is going in this car)
Pulled all the engine parts off the shelf, I think I have everything I need to put it together. This is most of the stuff for the bottom end
Doing some final Prepping on the case, it has been sitting a few years now but it’s all full flowed, line bored, etc.
sailtexas186548
PostPosted: Tue Oct 12, 2021 4:27 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Got the crank cleaned up and started mic’ing everything up. #1 and #2 main bearing saddles are under spec about 2.577 and 2.5755, #3 is perfect, bearing IDs reflect the same condition so the case needs the line bore touched up. I could hone out #1 but #2 is a problem.
Wether looks perfect for painting this weekend coming up
sailtexas186548
PostPosted: Sat Oct 16, 2021 6:07 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Did final touch ups and wipe downs done, figured out how to hold everything so I can paint it in one go. Weather was great today but windy, the morning is supposed to be perfect so I will be up early to roll it out, hit it with a tack cloth, and let the paint fly.
sailtexas186548
PostPosted: Sun Oct 17, 2021 5:54 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
So after almost 7, that’s right SEVEN years since I started this project it’s back in paint! If I manage to complete this build, will it be the longest one in HBB off-road? Not the longest running build thread with multiple iterations and redos, but start to the the initial “first drive”?
Anyways here I am ready to spray:
Some primer shots:
Seam sealer (misplaced my dispenser so I cut the tube open and spread it by hand… less than ideal hahahah)
Black on the wheel wells, fire walls, heater channels, and inside of the doors and quarter panels:
Back into the garage to cure, need to tape the black off after 12hrs then spray the white before 72hrs:
I have to say I was dreading this, but the single stage acrylic urethane instead of my usual base clear was not bad at all. This is the 5th boat/car I’ve painted but the first single stage, I’m not sure I will go back unless it is a show piece
sailtexas186548
PostPosted: Sun Oct 17, 2021 8:44 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
with much effort the last of the DIY Bedliner is gone, and the one piece fiberglass front end is ready for paint. It’s got a few bumps and bruises so it matches the car perfectly
sailtexas186548
PostPosted: Mon Oct 18, 2021 6:55 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Ran out of light this evening, took a little longer to tape off than I expected. My 72hr recoat window is halfway gone, tomorrow has to be the day!
stevebaz
stevebaz is offline
PostPosted: Tue Oct 19, 2021 9:53 am    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
well it looks like your on a roll. now comes the hard part. putting it back together without scratching the shit out of it. I hate the whole putting it back together process. enjoy your journey. not many people stick with it so long.
sailtexas186548
PostPosted: Tue Oct 19, 2021 6:59 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
It has been a journey! I can see the finish line now.
Nothing like painting by moonlight… it looks just it was supposed to, no rust with quality paint and solid, but rough enough to have some character.
I pulled a little bit of the tape, will pull the rest tomorrow
sailtexas186548
PostPosted: Wed Oct 20, 2021 6:03 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Masking off, looks pretty good! Rearranged the shop, time to start throwing the suspension on and get the brakes together
Snoww_
Snoww_ is offline
PostPosted: Thu Oct 21, 2021 4:52 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Love this build Cool
1991 Tiico Vanagon Carat
1961 Baja Bug
plotch
plotch is offline
PostPosted: Fri Oct 22, 2021 5:04 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
As regards the body color- Holy Wow.
sailtexas186548
PostPosted: Sat Oct 23, 2021 2:07 pm    Post subject: Re: 1969 Baja Bug - TX Build Reply with quote
Thanks guys. The colors are ppg’s “gm fleet white” and “black” haha nothing special here. The white does not have a blue or grey or tan look, just a pure white so it’s really bright.
Transaxle is mounted, needs to come back out and get cleaned up of course. I opened up the bell housing mounts to 7/16” grade 8, same for the nose cone mount. I cut/modified the body side mount to fit the King Kong torsion adjuster, you can see how close it is compared to a stock mount. There is also a mid mount that is welded to the bottom up of the frame horns.
Mounts fully welded in and paint touched up:
Scraped the transaxle and wiped with mineral spirits, then sprayed it with foaming engine degreaser before a pressure wash.
Page 7 of 12
