VanagonHaus Samba Member
Posted: Sat Oct 16, 2021 4:15 pm Post subject: Crank, no start | NO SPARK FROM DISTRIBUTOR?? |
New battery, new distributor (replaced today and timing not set yet as van won't start) and a new coil. I get a spark at the cable that connects the coil to distributor but I get no spart out of the sparkplug cables. I'm assuming the cable that connects the power to the distributor isn't grounded or there is a fuse issue.
I've checked two separate cables and same result, also fuel pump works and I've heard the injectors pulse.
Can anyone point me in a good direction here, I would appreciate it!
whafalia Samba Member
Joined: January 28, 2009 Posts: 685 Location: San Francisco
Posted: Sat Oct 16, 2021 5:44 pm Post subject: Re: Crank, no start | NO SPARK AT SPARKPLUGS? |
You put the rotor in? _________________ 84 westie 2.2 w/ digijet, AT |
Posted: Sat Oct 16, 2021 7:13 pm Post subject: Re: Crank, no start | NO SPARK AT SPARKPLUGS? |
Yup, I've been reading and have boiled it down to the part of the wiring harness that connects to the distributor / hall sensor. Must be a loose wire inside the connection piece. Will have to double-check tomorrow to see if my hunch is right.. |
davlance01 Samba Member
Posted: Sat Oct 16, 2021 8:46 pm Post subject: Re: Crank, no start | NO SPARK AT SPARKPLUGS? |
If it started before all the new parts then its your installation of the parts. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32594 Location: Reading Pennsylvania
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4777 Location: Bemidji, MN
Posted: Sun Oct 17, 2021 6:11 am Post subject: Re: Crank, no start | NO SPARK AT SPARKPLUGS? |
lift your rotor off again and double check the orientation of the rotor notch in the distributor shaft notch. sometimes you THINK it is aligned and pushed down when it is indeed riding on top of the shaft. while the cap is off, make sure the carbon button in the center of the cap is not broken/missing. _________________ -dan
www.thefixitworkshop.com |
