The Roach
Page: Previous  1, 2, 3 ... 12, 13, 14, 15, 16  Next
vwfye
vwfye is offline
PostPosted: Sat Aug 21, 2021 1:14 pm    Post subject: Re: The Roach Reply with quote
Installed front fenders wiring included, hood pins and rear polycarbonate window today.
64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3"
Bobnotch
Bobnotch is offline
PostPosted: Sun Aug 29, 2021 12:34 am    Post subject: Re: The Roach Reply with quote
Looks good. So when will you do the windshield?
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
vwfye
vwfye is offline
PostPosted: Sun Aug 29, 2021 1:06 am    Post subject: Re: The Roach Reply with quote
When i can afford it
Bobnotch
Bobnotch is offline
PostPosted: Sun Aug 29, 2021 2:23 am    Post subject: Re: The Roach Reply with quote
I suppose goggles or your face shield will work for now. Wink Laughing
Tram wrote:
Tram wrote:
Max Welton
Max Welton is offline
PostPosted: Sun Aug 29, 2021 8:40 am    Post subject: Re: The Roach Reply with quote
Goggles and a scarf. Cool
Max
1967 Type-3 Fastback
vwfye
vwfye is offline
PostPosted: Sun Aug 29, 2021 10:08 am    Post subject: Re: The Roach Reply with quote
Nope. Not track legal yet.
vwfye
vwfye is offline
PostPosted: Wed Sep 01, 2021 11:05 pm    Post subject: Re: The Roach Reply with quote
The day I brought it home:
Now:
Done? No... but much closer to being something!
vwfye
vwfye is offline
PostPosted: Thu Sep 02, 2021 10:50 pm    Post subject: Re: The Roach Reply with quote
Next is adding a tab where circled to keep the fender off the rear of the 8 inch wide slicks.
vwfye
vwfye is offline
PostPosted: Fri Sep 03, 2021 3:12 pm    Post subject: Re: The Roach Reply with quote
I was having tire rub issues backing the red car up. Thought it was both sides...come to find out, the right side was almost 1.5" inboard! This is the same side that I had to reshape the rear fender around the light. Just got it all squarish again. No more rub!
I am very glad I happened to start on that side. Also, that car had negative camber and was rubbing. I raised the rear about an inch to lesson this a bit and still no rub. It was a good day!
Bobnotch
Bobnotch is offline
PostPosted: Sat Sep 04, 2021 6:03 pm    Post subject: Re: The Roach Reply with quote
Or you could have added a 1 inch strip of metal to the inner wheel well lip (the John J. method) of getting wider tires to fit in the rear. Looks good though if you fixed it correctly.
Tram wrote:
Tram wrote:
vwfye
vwfye is offline
PostPosted: Sat Sep 04, 2021 6:14 pm    Post subject: Re: The Roach Reply with quote
That was the plan initially, but it all fits with these wheels' offset.
vwfye
vwfye is offline
PostPosted: Tue Oct 05, 2021 9:16 am    Post subject: Re: The Roach Reply with quote
Next up is sorting out the front tie rods and coilover shocks on the T1 beam conversion for racing. I think I will start with 2000lb springs and see if they can support the nose with driver in the car. Race height is only 4 inches to the bottom of the beam... so things all change, even the tie rod length gets much shorter.
Bobnotch
Bobnotch is offline
PostPosted: Tue Oct 05, 2021 4:09 pm    Post subject: Re: The Roach Reply with quote
Any pics of it?
Tram wrote:
Tram wrote:
vwfye
vwfye is offline
PostPosted: Tue Oct 05, 2021 4:17 pm    Post subject: Re: The Roach Reply with quote
Nada
vwfye
vwfye is offline
PostPosted: Thu Oct 14, 2021 11:45 pm    Post subject: Re: The Roach Reply with quote
Ended up ordering new tie rods. Seems I have late BJ spindles and dog bone with early ball joints. That's a failure waiting to happen... so, just waiting for the new to arrive.
vwfye
vwfye is offline
PostPosted: Fri Oct 15, 2021 9:56 am    Post subject: Re: The Roach Reply with quote
Realized I will need to go to a 22x4x15 front runner tire to avoid rub at the height I want the nose at on the track. It's just money and time, correct?
W1K1
W1K1 is offline
PostPosted: Fri Oct 15, 2021 11:51 am    Post subject: Re: The Roach Reply with quote
I know the superbeetle spoiler certainly helps at high speeds to keep mine stable
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
Bobnotch
Bobnotch is offline
PostPosted: Sat Oct 16, 2021 11:16 am    Post subject: Re: The Roach Reply with quote
Yeah, but does he have the horse power to push it?
Tram wrote:
Tram wrote:
vwfye
vwfye is offline
PostPosted: Sat Oct 16, 2021 11:10 pm    Post subject: Re: The Roach Reply with quote
Not sure I want one on a drag car.
vwfye
vwfye is offline
PostPosted: Tue Oct 26, 2021 11:15 am    Post subject: Re: The Roach Reply with quote
The tie rods finally arrived! There is supposed to be a break in the rain later this week, so... We will see if my toe in/out can be remedied! If that happens, I will finally start to see some light at the end of the tunnel. Woot!
Page 13 of 16
