theduck Samba Member
Joined: March 05, 2006 Posts: 236 Location: hesperia california
Posted: Sat Oct 16, 2021 11:26 pm Post subject: Blinker issue |
Hello all ,and hope all is well.I own a 67 type 1 Bug.12 volt.So my blinkers use to work.But now only the left one(drivers) works.The other one ,right side,flashes very fast.I have the 9 pin flasher box.I changed it once with used one same issue.Also when I step on my brakes,the 9 pin box clicks. So I checked the fuse and it is good.And I checked for power to the right blinker in the rear.None,dead, Any help? Thx,theduck |
Pops67Beetle Samba Member
Joined: January 03, 2021 Posts: 127 Location: Queens, NY
Posted: Sun Oct 17, 2021 2:49 am Post subject: Re: Blinker issue |
Sounds like you may have a bad bulb or a poor ground on the side that blinks fast. Start by pulling the bulbs on the affected side, clean the contacts and check to be sure the bulbs are still good. _________________ When I close my eyes I’m a little kid riding in the cubby..... Priceless!
13 y/o son’s quote while watching us replace the pedal cluster…. “Who says the Germans lost the war.”
67 Beetle bought new, 95% stock. |
6T5 square Samba Member
Joined: September 15, 2005 Posts: 1081 Location: Dover, DE
Posted: Sun Oct 17, 2021 8:15 am Post subject: Re: Blinker issue |
Back in the day a fast blinker meant a burnt bulb. I agree with pops _________________ John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot |
Posted: Sun Oct 17, 2021 9:31 pm Post subject: Re: Blinker issue |
Hello,and thx,for the replies.I did change the bulbs.And no luck.I used my continuity tester at the front and rear blinker.The front blinked had juice,but the rear didn't. So i also cleaned the ground screw on the rear.I will double check.And get back to all.Thx,theduck |
vwoldbug Samba Member
Posted: Sun Oct 17, 2021 10:37 pm Post subject: Re: Blinker issue |
There is a wiring diagram on the samba in the technical section. Find the connections and check for power. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33882 Location: Conejo Valley, CA
Posted: Mon Oct 18, 2021 8:07 am Post subject: Re: Blinker issue |
That 9-pin box needs to be grounded via the mounting flange/screw. Lack of that ground will often make the box click with the brakes. |
