Bug53 Samba Member
Joined: February 22, 2021 Posts: 704 Location: Pawcatuck, CT.
Posted: Mon Sep 27, 2021 10:32 pm Post subject: 1968 Trunk Release - One year only design? |
My early 68 has yet another unique feature only on 68's.
Whoever did the body restoration on my beetle compromised the guide tube for my trunk release so it doesn't take the nice gradual curve to the latch. I'm guessing they messed it up while changing the fender.
It's a pretty rigid tube that isn't easy to shape.
To add to it they riveted the latch in place with some big assed pop rivets.
As we know 68 introduced the release button but the cable still comes out on the driver's side.
1969 they brought it to the glove box as they probably realized the trunk doesn't open every time you add fuel.
Is there a place to get the proper tube and cable because it's Murphy's law that the cable will one day break and I'll be screwed? |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Tue Sep 28, 2021 8:32 am Post subject: Re: 1968 Trunk Release - One year only design? |
Most of the parts suppliers have those parts. Easy to get. 68 is a one year only on the hood operating parts.
The big rivets, on the catch, were OEM. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Bug53 Samba Member
Posted: Tue Sep 28, 2021 9:25 am Post subject: Re: 1968 Trunk Release - One year only design? |
VW_Jimbo wrote: |
The big rivets, on the catch, were OEM. |
Plenty of sources for the cable.
Not so much for the steel tube. |
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Tue Sep 28, 2021 10:20 am Post subject: Re: 1968 Trunk Release - One year only design? |
I can't help you on finding the tube you need but you might want to check out what I did on my '69.
https://www.thesamba.com/vw/forum/viewtopic.php?t=692980&highlight=
Could possibly help someday.
ol' mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
AlmostHeavenWV_VW Samba Member
Posted: Tue Sep 28, 2021 10:25 am Post subject: Re: 1968 Trunk Release - One year only design? |
Steel tube? How about an appropriate sized brake metal brake line and bend it to your needs.
Or use a motorcycle/bicycle brake cable ad a full replacement or just rob the guide sleeve tube from it _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Tue Sep 28, 2021 4:34 pm Post subject: Re: 1968 Trunk Release - One year only design? |
Bug53 wrote: |
VW_Jimbo wrote: |
The steel tubing is available. Measure it. Then go to Google and type the size into the search bar. If you want to match it 100%, you will need to measure it in metric units. Millimeters to be exact.
I just went through this on my 54, with all of the tubing within the tunnel. I purchased the tubing from McMaster Carr
TDCTDI wrote: |
Bug53 Samba Member
Posted: Tue Sep 28, 2021 5:48 pm Post subject: Re: 1968 Trunk Release - One year only design? |
AlmostHeavenWV_VW wrote: |
Or use a motorcycle/bicycle brake cable ad a full replacement or just rob the guide sleeve tube from it |
The 68 and earlier cars have a solid steel cable not stranded like a motorcycle. |
Posted: Wed Sep 29, 2021 2:42 am Post subject: Re: 1968 Trunk Release - One year only design? |
Bug53 wrote: |
Sorry I'm not familiar with that set up and it was unclear what part they had boogers up.
Then also order some steel wire too and cut to your needs. I'd probably just get stainless to avoid rusting
https://www.mcmaster.com/stainless-steel-wire/ _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Sun Oct 17, 2021 7:54 pm Post subject: Re: 1968 Trunk Release - One year only design? |
My tube is missing on the 1968. Can someone tell me what the OD of the tube is? I have nothing to measure.
I removed the tube to repair some of the body and I cannot find it anywhere. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Bug53 Samba Member
Posted: Sun Oct 17, 2021 8:14 pm Post subject: Re: 1968 Trunk Release - One year only design? |
viiking wrote: |
I removed the tube to repair some of the body and I cannot find it anywhere. |
The piece that was stubbed into my interior happened to be the same size as 3/8" copper plumbing tubing which comes in short rolls of 10 or 25ft. at Home Depot.
I used a 3/8" compression to couple them, bent to tubing with a nice gradual bend down to the latch and held it in place with one strap just past the tank.
It is smooth a silk and easy to get lube into later.
The original Steel tube was not bent too smoothly by whoever installed it and the latch never returned without pushing it back in. Now it's great. |
hulbyw Samba Member
Joined: April 24, 2021 Posts: 127 Location: Australia
Posted: Sun Oct 17, 2021 8:42 pm Post subject: Re: 1968 Trunk Release - One year only design? |
viiking wrote: |
OD is 9mm.
Cheers |
Bug53 Samba Member
Posted: Sun Oct 17, 2021 8:50 pm Post subject: Re: 1968 Trunk Release - One year only design? |
hulbyw wrote: |
viiking wrote: |
OD is 9mm.
Cheers |
9mm=.354 (20 thousandths of an inch less than 3/8") |
Posted: Sun Oct 17, 2021 9:05 pm Post subject: Re: 1968 Trunk Release - One year only design? |
hulbyw wrote: |
viiking wrote: |
OD is 9mm.
Cheers |
Thanks mate! _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
