shaun86westfalia Samba Member
Posted: Sat Oct 16, 2021 6:53 pm Post subject: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
Hello, fellow Vanagon addicts! (sufferers?)
We are long time forum lurkers/loiterers, but first time posters. Please bear with me, as I try to give as much information as I can, which has led to my wife and I at the end of our ropes.
Our van is a 1986 Vanagon Westfailia with the 2.1 litre Digifant engine, and we are located in Calgary, Alberta, Canada. We bought the van back in 2018, and it ran very well for us up until the beginning of this summer.
Current odometer: 238,875
Where did it all go wrong, you might ask?
At the beginning of June we had a heat spell, and the van quit for the first time at the top of a pretty steep hill just outside of Calgary. I had been driving it in 30+ degree Celsius weather for about 45 minutes or so, when part way up the hill, the tachometer started bouncing around, and felt to me like it wouldn't shift, so naturally I let off the accelerator pedal, and POOF the engine just quit, so I pulled over to the shoulder. I thought that it was related to the heat, so I unpacked the back cargo area, opened the engine lid, and waited for 10-15 minutes. I was then able to restart the van by giving it some revs. It quit again at the top of the next hill because again, I had let off the accelerator. And then it quit a third time as I got off on the exit I needed, after a couple of less severe hills.
Over the course of the summer, we drove the van around the city in short stints, and it didn't quit at all. We thought for sure the issue was related to something with the heat and/or extended periods of driving.
We then proceeded to have our mechanic change out the following (all new parts) in 3 successive trips to the shop, when the prior part didn't help:
( 1 ) Ignition coil
( 2 ) Hall sender/sensor/generator
( 3 ) Fuel pump
( 4 ) Alternator (this was changed not as a result of the quitting issue, but because the bearing was going, and causing extreme shakes in the engine bay)
After the fuel pump was installed, we thought we had hit the jackpot. We did 4 hours one way in very similar heat, and then 4 hours back in similar heat, around 800 kilometres round trip. No issues at all.
Queue up a big road trip we had here in September. On the first day we had done several hundred kilometres with no issue. On day two, however, the tach was bouncing a little bit, but we didn't pay a lot of attention because we were following a semi-truck and it was quite windy. Then we got near the top of a big hill a bit later, the tach goes nuts, with the engine following suit -- either extreme revs, or almost complete loss of power. Letting off the accelerator at the top of the hill resulted in the van quitting dead near Kelowna.
We decided not to let it cool off this time, and instead start it up again, and found that it would start immediately AS LONG AS we also pushed the accelerator.
Now we're thinking maybe something in the EVAP system is clogged, or maybe even the ECU itself needs a reset... (we are just guessing at this point)
We get out to Vancouver and stop in to see some of the Westy specialist guys out there, but they could only give us a little time as drop-ins. They change out the following parts:
( 5 ) 2x Relays in the left side of the engine compartment for the fuel pump and power supply
( 6 ) Signal filter (GoWesty brand) for the airflow meter (AFM)
( 7 ) Idle control stabilizer unit (ICSU) (unrelated to the problem, but ours was dead for years with the 2-pin connector on the top of the engine disconnected)
Those guys started to hint at something electrical, if the problem persisted, but also thought that the EVAP system sounded resonable.
While we were out on Vancouver island the issue seemed to be getting worse, but as long as we stayed steady holding down the accelerator, or really punching it down, we could seemingly work through the issue and at least keep rolling.
Queue up a number of rainstorms, and now we're trying to get off of the Sunshine Coast back onto the mainland just north of Vancouver. In the rain on the way to the ferry, the van keeps quitting. We get onto the mainland, heading up towards Whister through Squamish, and the tach is just going nuts, and the extreme revving or losing power seems to be getting worse the wetter we get.
We call our mechanic, and he recommends:
( 8 ) disconnecting the oxygen/lamda sensor
We get up to Whistler from Squamish with not a single hesitation, so we naturally think THIS IS IT. Just a silly $20 USD oxygen sensor ($80 USD if we were to pay up for the GoWesty one with the new harness). This is FANTASTIC.
NOPE.
We go to leave Whistler, still wet conditions, hesitating like crazy even on the downhill. But not even right away: not until we were through Squamish and almost back into Vancouver, about an hour of driving before it acts up. False sense of security SMASHED, confidence level back down to ZERO. But hey, we've made it this far, we'll at least get home (about another 1000 kilometres to go after 3500 already).
We limp back to Calgary, and decide it is time to get a Bentley manual, Haynes manual, read How To Keep Your Volkswagen Alive cover-to-cover, roll up the sleeves, and become a partially self-sufficient Westy owner (FINALLY).
Going through the lists of things to try with Vanagon Intermittent Syndrome (besides #1, #2, #3 already mentioned), we start with all the small tune-up procedures, and perform the following:
( 9 ) Oil change with LiquiMoly 5W-50 (unrelated, but needed to be done after the long trip)
( 10 ) New distributor cap (Bosch)
( 11 ) New rotor (Bosch)
( 12 ) New ignition wires (Bremi)
( 13 ) New spark plugs (NGK BP6ET tri-tip)
( 14 ) Idle adjusted to right around 900rpms (we adjusted the screw at one point on the trip to allow more airflow to try and get it to run better, so we now dialed it back)
EDIT: Adding these next two tests since original post:
We borrow the following known-to-be-good parts from our mechanic:
( 15 ) Airflow meter mounted on air cleaner
( 16 ) ECU (same part number and revision number)
*Latest/current conditions* for quitting:
At this point, if the van has sat for long enough to cool completely (6-8 hours seems to do it), the quitting issue can be recreated quite easily. The van turns over great straight away. We let it idle for 2-3 minutes, it'll start idling roughly, and then quits dead in the driveway. To get it to start again, we can turn it over right away, but only by pushing the accelerator quite a bit. If we then let it idle on its own, it'll quit again almost right away. We can repeat this quitting event 2-3 times before the van is seemingly too warm to quit.
The other set of conditions under which it seems to quit are after it has been up closer to highways speeds (say 80-100km/hr) for a few minutes. It will often do the tach jumping show and dance, and then when we come to the next stop, it'll quit dead and require being turned over with accelerator being pushed.
Note: when the tachometer jumps around, the engine always is in-line with the RPMs, either revving hard, or lurching.
We get some fancy equipment to do some of our own testing, and perform the following:
( 17 ) Timing is perfectly set at 3000 rpm for 35 degrees advance
( 18 ) Compression test (cold, not warmed up, and "dry"): #1 = 130psi; #2 = 130psi; #3 = 105psi; #4 = 130psi
( 19 ) Fuel pressure test - 35psi holds steady right through the van quitting while sitting and idling, tapped in at the fuel feed T-junction
This tells us nothing really, but at least we got confirmation that probably the fuel pressure regulator is working okay.
And finally we arrive at today, where we find a copy of the Digifant Pro Training manual that has been so kindly updated by Kamz:
https://www.thesamba.com/vw/forum/viewtopic.php?t=725680
( 20 ) We run through all electrical tests on pages 40 & 41
Here are the results that appeared to be abnormal in some way:
Test fuel injectors and wiring for total resistance
12 at ECU and 87 at Fuel Pump Relay
Specifications: 3 to 5 ohms
Our result: 8.5 ohms (too much resistance? could this BE RELATED?)
Test throttle switch in closed position
6 and 11 at ECU
Specifications: 0 ohms
Our result: 0.8 ohms (low enough?)
Test fuel pump wiring
At components, wiring between fuel pump relay/ground and 2-pin connector
Specifications: Continuity on both wires, individually
Our result: Right wire (when looking down at connector from rear of vehicle) has continuity; Left wire, no reading at all on multimeter
( 21 ) Additionally, we ran the fuel injection relay checks from 24.32 of the Bentley)
With the ignition on, adapter B (on the left, Power Supply Relay) is supposed to get voltage approximate to the battery voltage on terminal 85 (on the right), but we get nothing on 85, and instead get the battery voltage on 86. Unsure if this matters, as both 85 & 86 appear to open when the relay is switched.
So...that's a very long-winded way of stating we are puzzled (to say the least).
Our plea is for any Vanagon Sherlock Holmes' out there to put on their double-brimmed hats, grab their magnifying glasses, and PLEASE (pretty please?) provide as much free advice as your heart can allow.
Thanks in advance!
Shaun (and Miranda) |
davlance01 Samba Member
Posted: Sat Oct 16, 2021 8:41 pm Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
Sounds like a really really really long way of saying you have a miss in one or more of your cylinders. Watch some "what is a misfire?" Videos.
Here's what you do before you spend a dime on anything else.
Get yourself a temperature gun from harbor freight, amazon.com or wherever you get cheap tools.
Like this one...
https://www.harborfreight.com/121-infrared-laser-thermometer-63985.html
Start the car and as it warms up hit the laser and grab the Temps on each cylinder by pointing at the exhaust as close to the head as you can get it. Now IF there is no significant differences in the Temps then take the car for a drive to get the exhaust good and hot and then check again.
Take note of the temperature of each cylinder, the ones that are cold are your dead cylinders. In other words a cylinder that isn't firing isn't creating exhaust either resulting in a colder or cold exhaust at the problem cylinder.
After you identify the problem cylinders turn to the page in your Bently or pro training pdf and test your injectors at the cold cylinders before you do anything else. My digijet manual states 87cc (87 ml) in 30 seconds I imagine the digifont is the same but double check.
And never forget that money spent on diagnostic tools is better spent than money spent on fancy socket sets.
My money is on a clogged injector or 2. Please don't just pull the trigger on the parts cannon before being 100% sure the part your buying is fixing the issue. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
Posted: Sat Oct 16, 2021 9:48 pm Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
Thank you very much for the sound advice, we really appreciate it. We’ve ordered a temperature gun, and will be able to run the test you recommended as soon as it arrives (Monday).
Quick follow-up:
Should we be concerned about the 8.5 ohms resistance rating on the ECU pin 12 to fuel pump relay pin 87? Or is that a trial ballon to let float away? |
Posted: Sun Oct 17, 2021 3:40 am Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
Being that you are asking the question about the ohms in the wire I'm going to guess you do not know how to do a voltage drop test.
Watch this....
https://youtu.be/DfLyh43iihM
You own a old vw you got to know how to do a voltage drop test or you'll be driving yourself nuts
If I had a nickel for every wire end I had to replace I could buy me another van
Yes you should look closer at that high resistance wire, should you be concerned? Being concerned is reserved for people who do not know how to diagnose their own cars. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Posted: Sun Oct 17, 2021 6:09 am Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
djkeev wrote: |
On the 86 the tachometer is fed by a green wire that plugs onto the ignition coil.
Unplug it.
You won’t have any tach signal but the chances are good that you won’t stall out any more.
If this isn’t the problem? Well it was a cheap try!
Dave |
Never heard of that one but it makes sense.
One of the first things I learned in automotive diagnostic class was to stop looking for parts to buy and look for what's wrong. What you just said was a perfect example of that idea in action.
When you think about the issue that this guy is having it could be 50 different things, it could be a loose fuse supplying the coil, it could be the ignition switch, it could be any stupid wiring issue that you can think of. What is really important is these 2 things..
1...the engine has good bones, compression over 90 psi means his valvetrain is all good and his rings and cylinders are in good shape valves are adjusted properly.
2...it's either fuel, timing or electrical .
If it was in my shop and the exhaust Temps are all equal I'd be pulling those injectors doing a fuel dump test anyway then setting the timing, then voltage drop tests which would expose that rpm issue.
Whatever it is it's a stupid cheap fix he just needs to find it which is part of the fun. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Sun Oct 17, 2021 11:46 am Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
I have some thoughts on this conundrum:
1. The first thing that comes to mind for me is the symptom of the "bouncing tachometer." There are really only two possible causes for this tell-tale symptom. The first, which the OP already addressed, is a faulty Hall sender or related wiring. The second is a failure in the ECU printed-circuit board. These failures happen a lot more often than one would think. There is a "field repair" available and a more permanent repair - - replacing the ECU. For the "field repair", disconnect the battery, then the ECU connector, removed the ECU and turn it around 180 degrees and re-install. The object is to have the ECU harness pull on the Printed Circuit Board that it attaches to in the opposite direction. The harness directly attaches to the PCB (it should have been made with some kind of strain support) and can cause it to lose electrical contact where the thin copper traces extend over cracked parts of the PCB. Heat plays a role in causing expansion that opens the cracks. The ECU replacement you used may have this exact problem.
2. Another possibility is that the oxygen sensor coaxial cable is shorting from the inner signal wire to the out ground wire. This can happen in a fashion that is intermittent, although most Vanagons that develop this problem do not experience it in an intermittent fashion. Also, this would NOT cause the tach needle to bounce around. Here is a link addressing the oxygen sensor cable issue: https://www.thesamba.com/vw/forum/viewtopic.php?p=7283386
There are a number of important grounds in the engine compartment, at least one of which is likely contributing to the slightly high resistance noted at the fuel injectors. Ground fails can act intermittently. The terminal ends allow moisture to attack the copper strands under the wire insulation and that affected oxidized wire can be as much as 1/2" to 1". Where this is found, you must cut off the terminal, cut out the compromised wire and install a properly-crimped replacement terminal. This process also lets you eliminate a lot of other potential sources of the running issues. _________________ '86 Syncro Westy SVX |
Posted: Sun Oct 17, 2021 5:34 pm Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
So you want the guy to flip his ecu around, replace oxygen sensor wire and clip the ends of his ground wires back 1 inch?
1.5 hour free voltage drop course will take less time.
https://youtu.be/YaYtCVBodpw
And accomplish more. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
DigiMatrix Samba Member
Joined: April 20, 2010 Posts: 449 Location: Up North Canada
Posted: Sun Oct 17, 2021 6:40 pm Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
shaun86westfalia wrote: |
Quick follow-up:
I would definitely check your out your resistance reading.
First, check the resistance of one of your injectors between the 2 pins at the injector with the injector plug off. Based on the specs given they should be between 12 and 20 ohms. The injectors are batch fired which means they are connected in parallel. The equation is:
1/RT = 1/R1 + 1/R2 + 1/R3 +1/R4 where RT is total resistance (what you measured - 8.5 ohms) and R1 - resistance of injector 1 and R2 = resistance of injector 2 etc.
For example if the resistance of your injectors is 17 ohms, based on the formula from above,
4 injectors in parallel should give a reading of 4.25 ohms
3 injectors in parallel should give a reading of 5.67 ohms (1 injector un-plugged)
2 injectors in parallel should give a reading of 8.5 ohms (2 injectors un-plugged)
1 injector in parallel should give a reading of 17 ohms (3 injectors un-plugged)
This may not be your case, but the math would indicate you have 2 injectors unplugged or really poor connections. Definitely worth checking your injector wiring. _________________ _________________
'91 Syncro Westfalia
soon to be 2.5 liter stroker WBX 10:1 comp
Digifant ECU with knock sensor and custom
cylinder selective knock control by me |
Posted: Mon Oct 18, 2021 6:07 pm Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
Thanks to everyone for their responses. I found a bit of time to try out some of the suggestions.
djkeev wrote: |
Unplug it. |
Thanks for this suggestion, Dave. I actually found two green wires paired together at the top of the ignition coil. When I unplugged the whole plug, the van wouldn't start. I then tried just one side of the plug at a time, and then it started with one of the wires attached. I went for about a ten minute test drive, which seemed fine, but then the van still quit while idling once I had stopped.
davlance01 wrote: |
Take note of the temperature of each cylinder, the ones that are cold are your dead cylinders. In other words a cylinder that isn't firing isn't creating exhaust either resulting in a colder or cold exhaust at the problem cylinder. |
Thanks davlance01. I received my temperature gun, and tried this test a few times. Even with the engine just started idling, I pointed the laser at the exhaust pipes for each cylinder underneath the van, right where the pipe meets the engine next to the valve covers, and got 200-250 Celsius right away. After letting it run, I got 350-400 at those same points, at all 4 exhaust spots.
Hopefully I ran that test correctly...
I also grabbed my stethoscope at this point, and I listened to each fuel injector firing. They all sounded like a nice jackhammer sound, and all at about the same cadence.
davlance01 wrote: |
After you identify the problem cylinders turn to the page in your Bently or pro training pdf and test your injectors at the cold cylinders before you do anything else. My digijet manual states 87cc (87 ml) in 30 seconds I imagine the digifont is the same but double check. |
I would love to run this test, but I actually have no clue how. I referenced the Digifant Pro Training Manual that Kamz updated:
There, on page 19, I see the same specs as your Digijet, 87ml in 30 seconds. But the manual references special devices I don't have in my toolkit (US 4480/3).
Any rookie (step-by-step) advice on how to test each injector for fuel dump/volume with basic tools?
davlance01 wrote: |
Watch this....
You own a old vw you got to know how to do a voltage drop test or you'll be driving yourself nuts |
I watched the video, and it was a really great introduction, thanks. I can now say I understand the concept, but (bear with me, I'm a newbie) I have no idea how to apply the voltage drop concept in execution. I just have no clue where I should be putting my red and black leads for my multimeter in order to test for voltage drop with the van running.
The test that was concerning was that I was supposed to see 3 to 5 ohms touching pin 12 at the ECU, and pin 87 at the fuel pump relay, but I got 8.5 ohms.
Where do I begin chasing that down, if you don't mind me asking a basic question?
Or maybe I have to spend more time watching this video you also kindly handed over to us...
I was just wondering if there wasn't something Vanagon specific that could maybe help me go down the correct rabbit hole though...?
Howesight wrote: |
For the "field repair", disconnect the battery, then the ECU connector, removed the ECU and turn it around 180 degrees and re-install. The object is to have the ECU harness pull on the Printed Circuit Board that it attaches to in the opposite direction. |
Thank you, Howesight. I have flipped the ECU, and mounted on the outside of its protective cover. I now have to wait until morning to see if it makes a difference, when the van runs really rough in the morning and will easily quit during idle.
Howesight wrote: |
Another possibility is that the oxygen sensor coaxial cable is shorting from the inner signal wire to the out ground wire. This can happen in a fashion that is intermittent, although most Vanagons that develop this problem do not experience it in an intermittent fashion. |
Are there easy ways to test the oxygen sensor without a CO tester? The Digifant pro training manual had me test pins 2 & 13 at the ECU with the sensor disconnected and then connected. While disconnected, the reading was 0 ohms. While connected, it was supposed to be infinite ohms, and we got absolutely nothing on the multimeter. Is that a dead sensor?
Howesight wrote: |
The terminal ends allow moisture to attack the copper strands under the wire insulation and that affected oxidized wire can be as much as 1/2" to 1". Where this is found, you must cut off the terminal, cut out the compromised wire and install a properly-crimped replacement terminal. This process also lets you eliminate a lot of other potential sources of the running issues. |
I will keep this one in my back pocket for the moment. I had already serviced a lot of my grounds when the problem started. I used deoxit on all of them, and also replaced the connectors where they looked shoddy. I might have to do a little more work in this area later if none of the other diagnostics turn anything up.
DigiMatrix wrote: |
This may not be your case, but the math would indicate you have 2 injectors unplugged or really poor connections. Definitely worth checking your injector wiring. |
Thanks for confirming the math, DigiMatrix.
I have tested the injectors themselves, and each of them is just under 17 ohms. If I plug in 4, 3, 2, or 1 injectors, and test pins 12 & 14 at the ECU, I get almost exactly those numbers (4.3 ohms, 5.8 ohms, 8.5 ohms, 17 ohms).
But those values are at the ECU. I also confirmed the same numbers at the injectors themselves. So with 1 disconnected, I would see 8.5 ohms. With 2 disconnected, 5.8 ohms. With 3 disconneced, if I test at any and all the 3, it looks like one is connected with 17 ohms showing.
The question is (a repeat of my question to davlance01 above): why am I seeing 8.5 ohms when I do the test of pin 12 at ECU with pin 87 at the fuel pump relay? Any advice on how to chase that potential problem down?
djkeev wrote: |
Probably NOT your problem but worth looking at are the two connectors on the Power Steering speed boost Valve at the pump fitting.
These connectors are alive and infused when the key is on.
On most older units the terminal insulators are long gone by now. |
Sorry, Dave, I couldn't even find these to check them! I must just be too new to all this to even know where those reside... |
Posted: Mon Oct 18, 2021 9:52 pm Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
If you are getting the correct reading between 12 and 14 at the ECU then you are good. I could see a test saying measure resistance between terminal 12 and 87 of the Digifant Control relay (as it is connected to pin 14 of the ECU) - or 86 of the Fuel pump relay. I think someone made a mistake when they changed this test. If you look at the original Pro Training manual (part # WSP 521 148 00) the only electrical tests for the injectors is between terminal 12 and 14 at the ECU connector, the individual injector resistance (14 to 18 ohms) and an LED test at the injector plugs themselves (one at a time with all plugs disconnected) _________________ _________________
Posted: Tue Oct 19, 2021 9:56 am Post subject: Re: Vanagon Intermittent Syndrome - HELP! (Warning: long read) |
Why are you checking 12 and 87?
Your supposed to be checking pin 12 and 14 at the ecm connector
with only 1 injector plugged in at a time.
Do the test correctly...
1. Unplug all injectors
2. Plug in injector at cylinder 1
3. Check ohms between 12 and 14 at connector
4. Unplug injector at cylinder 1
5. Plug in injector at cylinder 2
6. Check ohms between 12 and 14 at connector
Then the same at cylinder 3 and 4.
They all need to be between 15 and 20 ohms, if they are that's not your problem move on to the next test, if they aren't between 15 and 20 ohms check the injector in question by placing the probe on the 2 male blade connectors on the injector itself, if the injector is good but the reading through the wiring harness is not then the problem is in the harness.
With all that said given the exhaust temps I doubt you have a fuel delivery issue or ignition issue, I'm not saying you don't have a issue there because I'm not there looking at it.
Keep that temp gun in the van with you so if you're out on the road and the van starts running like crap then you can do a quick test again. Also, shoot it at your transmission and bearings once in a while to make sure nothing is getting hot there. All rubber seals and gaskets start to melt above 300F so make sure your well below that on everything but the exhaust.
In the back of the Bently is your wiring diagram, it will be the most used part of that book, in the wiring diagram positive is on top and grounds at the bottom, instructions to read the wiring diagram is in the Bently as well.
Don't be like a dog chasing its tail, test test and test again until you are confident of the resolve to the issue or complaint. _________________ Life is short and the road is long so if you want to see it all you have to drive fast! |
